path: root/drivers/i2c/rcar_i2c.c
2019-03-08i2c: rcar_i2c: Move FSDA check to rcar_i2c_recoverIsmael Luceno Cortes
Cosmetic change. Any call to the recover function would need to do the same check afterwards, so it's sensible to make it part of the function. Signed-off-by: Ismael Luceno <ismael.luceno@silicon-gears.com>
2019-03-08i2c: rcar_i2c: Set the slave address from rcar_i2c_xferIsmael Luceno Cortes
It needs to be done for both reads and writes, so do it at rcar_i2c_xfer to avoid duplication. Signed-off-by: Ismael Luceno <ismael.luceno@silicon-gears.com> Reviewed-by: Marek Vasut <marek.vasut+renesas@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2019-03-08i2c: rcar_i2c: Don't mask errors with EREMOTEIO at rcar_i2c_xferIsmael Luceno Cortes
Fix rcar_i2c_xfer return value, previously it was always returning -EREMOTEIO when dealing with errors from calls to the read/write functions. Signed-off-by: Ismael Luceno <ismael.luceno@silicon-gears.com> Reviewed-by: Marek Vasut <marek.vasut+renesas@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2019-03-08i2c: rcar_i2c: Fix sending of slave addressesIsmael Luceno Cortes
Do the reset before clearing the MSR, otherwise it may result in a read or write operation instead if the start condition is repeated. Signed-off-by: Ismael Luceno <ismael.luceno@silicon-gears.com> Reviewed-by: Marek Vasut <marek.vasut+renesas@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2019-03-08i2c: rcar_i2c: Add comments about registers & valuesIsmael Luceno Cortes
Document the meaning of macros related to registers and values to be written to them. Signed-off-by: Ismael Luceno <ismael.luceno@silicon-gears.com> Reviewed-by: Marek Vasut <marek.vasut+renesas@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2019-03-08i2c: rcar_i2c: Setup SCL/SDA delay at rcar_i2c_set_speedIsmael Luceno Cortes
Setting up the delay only needs to be done once; move it to rcar_i2c_set_speed so it's done at initialization time. Signed-off-by: Ismael Luceno <ismael.luceno@silicon-gears.com> Reviewed-by: Marek Vasut <marek.vasut+renesas@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2019-03-07i2c: rcar_i2c: Add Gen3 SoC supportMarek Vasut
Add support for R-Car Gen3 SoCs into the driver, which encompases the Gen3 SoC extra timing register handling and 64bit build fixes. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de>
2018-05-20i2c: rcar_i2c: Add DM and DT capable I2C driverMarek Vasut
Add derivative of the rcar_i2c driver which is capable of probing itself from DM and uses DT. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Heiko Schocher <hs@denx.de> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-05-20i2c: rcar_i2c: Remove the driverMarek Vasut
Remove the rcar_i2c driver, since it's no longer used by any board and will be superseded by a DM and DT capable variant. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Heiko Schocher <hs@denx.de> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-12-05dm: i2c: Add a note to I2C drivers which need conversionSimon Glass
Maintainers need to be notified more directly of the need to convert these drivers. Add a note to the top each affected file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2014-11-10i2c: rcar_i2c: Fix order of restart and clear statusNobuhiro Iwamatsu
In case of repeated START condition, the restart has to be kicked before clear status (MSR register). If it is kicked after clear status, R-Car I2C may transfer data (TXD register) or receive data (RXD register) instead of transferring slave address (MAR register). Signed-off-by: Ryo Kataoka <ryo.kataoka.wt@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-01-13rcar_i2c: Clear status before start master receiveNobuhiro Iwamatsu
Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-01-13rcar_i2c: Fix receiving wait conditionHisashi Nakamura
2013-10-17i2c: Add support for Renesas rcarNobuhiro Iwamatsu
This supports i2c controller for Renesas rcar. Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
