path: root/drivers/i2c/ihs_i2c.c
2015-11-12i2c: ihs_i2c: Fix hold_bus controlDirk Eibach
Bus has to be held for repeated start regardless of read/write access. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Acked-by: Heiko Schocher <hs@denx.de>
2015-11-12i2c: ihs_i2c: Use macro bestpracticesDirk Eibach
Reinhard Pfau complained that macros in ihs_i2c do not follow best practices. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Acked-by: Heiko Schocher <hs@denx.de>
2015-11-12i2c: ihs_i2c: Dual channel supportDirk Eibach
Support two i2c masters per FPGA. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Acked-by: Heiko Schocher <hs@denx.de>
2014-09-24cosmetic: replace MIN, MAX with min, maxMasahiro Yamada
The macro MIN, MAX is defined as the aliase of min, max, respectively. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-07board: gdsys: Make gdsys osd hardware detection more robustDirk Eibach
2014-07-07i2c: IHS I2C master driverDirk Eibach
IHS I2C master support was merely a hack in the osd driver. Now it is a proper u-boot I2C framework driver, supporting the v2.00 master features. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
