path: root/drivers/i2c/ast_i2c.h
2017-05-08aspeed: Add I2C Drivermaxims@google.com
Add Device Model based I2C driver for ast2500/ast2400 SoCs. The driver is very limited, it only supports master mode and synchronous byte-by-byte reads/writes, no DMA or Pool Buffers. Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
