The checks for CFG_EEPROM_PAGE_WRITE_ENABLE and
CFG_EEPROM_PAGE_WRITE_BITS in various temperature
sensor drivers are not necessary
On AMCC Arches board DTT_I2C_DEV_CODE is different then canyonlands
and glacier.
Signed-off-by: Victor Gallardo <vgallardo@amcc.com>
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
Clean Makefile
Move device specific values to driver for better reading
On AD7414 the first value upon bootup is not read correctly.
This is most likely because of the 800ms update time of the
temp register in normal update mode. To get current values
each time we issue the "dtt" command including upon powerup
we switch into one-short mode.
This patch fixes the problem on AD7414 equipped boards (Sequoia,
Canyonlands etc), that temp value printed in the bootup log was
incorrect.
When the LM73 temperature sensor measures a temperature below 0 C, the
current driver does not perform sign extension, so the result returned is
512 C too high. This patch fixes the problem, and does general cleanup
of the code.
Signed-off-by: Larry Johnson <lrj@acm.org>
When the LM75 temperature sensor measures a temperature below 0 C, the
256 C too high. This patch fixes the problem.
(1) Remove unused symbol "CFG_EEPROM_PAGE_WRITE_ENABLE".
(2) Use conditional Makefile.o.
This driver is based on the driver for the LM75.
drivers/rtc/Makefile
