In preparation to making the MPC85xx GPIO driver useable for a broader
range of SoCs, rename the driver file.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Fix some style violations in the MPC85XX GPIO driver.
Make the pca953x_gpio driver compatible with a live device tree.
Fix some style violations in the pca953x_gpio driver.
Add DT compatible string for RCar Gen2.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Add allwinner,sun50i-h5-pinctrl compatible for H5 boards.
Signed-off-by: Chris Blake <chrisrblake93@gmail.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
[jagan: remove external link and format commit message]
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
The command portion of the GPIO driver can only be used in full SPL so
re-work to guard the command related portions and mark it as static.
Cc: Dan Murphy <dmurphy@ti.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
Use available DM stm32f7_gpio.c and pinctrl_stm32.c drivers
instead of board GPIO initialization.
Remove stm32_gpio.c which is no more used and migrate
structs stm32_gpio_regs and stm32_gpio_priv into
arch-stm32f4/gpio.h to not break compilation.
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
Since commit 051ba9e082f7 ("Kconfig: mx6ull: Deselect MX6UL from
CONFIG_MX6ULL") CONFIG_MX6ULL does not select CONFIG_MX6UL anymore, so
take this into consideration in all the checks for CONFIG_MX6UL.
This fixes a boot regression.
Reported-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Stefan Agner <stefan@agner.ch>
Tested-by: Breno Lima <breno.lima@nxp.com>
Tested-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Tested-by: Jörg Krause <joerg.krause@embedded.rocks>
This driver really is DM GPIO one and so we need to have a correct
dependency, because DM alone doesn't provide required for CMD_GPIO
call and we're seeing build failures like this:
---------------------->8---------------------
cmd/built-in.o: In function 'do_gpio':
.../cmd/gpio.c:188: undefined reference to 'gpio_request'
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Eugeniy Paltsev <paltsev@synopsys.com>
Add generic compatible to the GPIO driver for Gen3 SoCs.
Add new compatible to the GPIO driver for R8A77995 D3 SoC.
Add new compatible to the GPIO driver for R8A77970 V3M SoC.
When requesting a GPIO, set the PFC GPSR register to GPIO mode,
otherwise the GPIO cannot work.
Same macros are defined in various places. Collect them into
include/linux/bitops.h like Linux.
The HSDK can manage some pins via CREG registers block.
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Uniformize STMicroelectronics copyrights headers for STM32
related code.
First, I implemented this driver as per-bank model, but it was
a design mistake.
- There are 31 banks in the maximum case. It is painful to add
so many nodes to DT.
- The IRQ control registers are shared between banks. Per-bank
design is a problem for Linux. The counterpart for Linux turned
around to the single node model.
Rework based on the driver for Linux.
These checks cannot fail since driver model will not call a driver's
method if it cannot fully create the driver data structures.
It is confusing to have these checks and others might copy them. Drop this
code.
In U-Boot -ENODEV means that there is no device. When there is a problem
with the device, drivers should return an error like -ENXIO or -EREMOTEIO.
When the device tree properties cannot be read correct , they should
return -EINVAL.
Update various GPIO drivers to follow this rule, to help with consistency
for future driver writers.
Reported-by: Adam Ford <aford173@gmail.com>
These three drivers all use U_BOOT_DEVICE rather than device tree to
create devices, so have to do manual allocation of platform data. This is
not true for new platforms.
Add a more explicit comment so that people do not copy this approach with
new boards.
It does not look like this driver needs to use a bind() method. It does
not manually create devices with device_bind() nor does it create devices
using U_BOOT_DEVICE(). It seems to only use device tree.
Therefore the manual allocation of platform data is not needed and is
confusing. Also platform data should be set up by the ofdata_to_platdata()
method, not bind().
Update the driver in case others use it as a model in future.
Add GPIO driver for the Renesas RCar SoCs . The driver currently supports
only the RCar Gen3 R8A7795 and R8A7796 SoCs, but is easily extensible for
the other RCar SoCs as well.
This driver is meant to replace the pinmux part of SH_GPIO_PFC driver.
Remove a comment claiming that this driver only supports the RK3288,
as we also use it on the RK3368, RK3399 and (most likely) on other
variants.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Version-changes: 2
- use the dev_read_addr_ptr function in rk_gpio.c
Update the Rockchip GPIO-bank driver to support a live tree.
Version-changes: 2
A few years ago STM32F1 SoCs support has been added :
0144caf22ce6acd5c gpio: stm32: add stm32f1 support
2d18ef2364fd3561a ARMv7M: add STM32F1 support
But neither STM32F1 dedicated defconfig nor board was
associated to these commits.
Got confirmation from Tom Rini and Matt Porter to remove
all this code [1]
[1] http://u-boot.10912.n7.nabble.com/Remove-STM32F1-support-td301603.html
CONFIG_CMD_TCA642X
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
This driver is not used in U-Boot. Drop it and its associated CONFIG
options.
It does not seem worth having an option to enable another sub-command in
this legacy driver. Drop this option so that the sub-command is always
available.
CONFIG_CMD_PCA953X
This converts Intel ICH6 GPIO driver to Kconfig, and add it to the
imply list of platform drivers.
Update the GPIO driver to support a live device tree.
Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Tested-on: Beaver, Jetson-TK1
Change is consistent with other SOCs and it is in preparation
for adding SOMs. SOC's related files are moved from cpu/ to
mach-imx/<SOC>.
This change is also coherent with the structure in kernel.
CC: Fabio Estevam <fabio.estevam@nxp.com>
CC: Akshay Bhat <akshaybhat@timesys.com>
CC: Ken Lin <Ken.Lin@advantech.com.tw>
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Heiko Schocher <hs@denx.de>
CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
CC: Christian Gmeiner <christian.gmeiner@gmail.com>
CC: Stefan Roese <sr@denx.de>
CC: Patrick Bruenn <p.bruenn@beckhoff.com>
CC: Troy Kisky <troy.kisky@boundarydevices.com>
CC: Nikita Kiryanov <nikita@compulab.co.il>
CC: Otavio Salvador <otavio@ossystems.com.br>
CC: "Eric Bénard" <eric@eukrea.com>
CC: Jagan Teki <jagan@amarulasolutions.com>
CC: Ye Li <ye.li@nxp.com>
CC: Peng Fan <peng.fan@nxp.com>
CC: Adrian Alonso <adrian.alonso@nxp.com>
CC: Alison Wang <b18965@freescale.com>
CC: Tim Harvey <tharvey@gateworks.com>
CC: Martin Donnelly <martin.donnelly@ge.com>
CC: Marcin Niestroj <m.niestroj@grinn-global.com>
CC: Lukasz Majewski <lukma@denx.de>
CC: Adam Ford <aford173@gmail.com>
CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr>
CC: Boris Brezillon <boris.brezillon@free-electrons.com>
CC: Soeren Moch <smoch@web.de>
CC: Richard Hu <richard.hu@technexion.com>
CC: Wig Cheng <wig.cheng@technexion.com>
CC: Vanessa Maegima <vanessa.maegima@nxp.com>
CC: Max Krummenacher <max.krummenacher@toradex.com>
CC: Stefan Agner <stefan.agner@toradex.com>
CC: Markus Niebel <Markus.Niebel@tq-group.com>
CC: Breno Lima <breno.lima@nxp.com>
CC: Francesco Montefoschi <francesco.montefoschi@udoo.org>
CC: Jaehoon Chung <jh80.chung@samsung.com>
CC: Scott Wood <oss@buserror.net>
CC: Joe Hershberger <joe.hershberger@ni.com>
CC: Anatolij Gustschin <agust@denx.de>
CC: Simon Glass <sjg@chromium.org>
CC: "Andrew F. Davis" <afd@ti.com>
CC: "Łukasz Majewski" <l.majewski@samsung.com>
CC: Patrice Chotard <patrice.chotard@st.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
CC: Hans de Goede <hdegoede@redhat.com>
CC: Masahiro Yamada <yamada.masahiro@socionext.com>
CC: Stephen Warren <swarren@nvidia.com>
CC: Andre Przywara <andre.przywara@arm.com>
CC: "Álvaro Fernández Rojas" <noltari@gmail.com>
CC: York Sun <york.sun@nxp.com>
CC: Xiaoliang Yang <xiaoliang.yang@nxp.com>
CC: Chen-Yu Tsai <wens@csie.org>
CC: George McCollister <george.mccollister@gmail.com>
CC: Sven Ebenfeld <sven.ebenfeld@gmail.com>
CC: Filip Brozovic <fbrozovic@gmail.com>
CC: Petr Kulhavy <brain@jikos.cz>
CC: Eric Nelson <eric@nelint.com>
CC: Bai Ping <ping.bai@nxp.com>
CC: Anson Huang <Anson.Huang@nxp.com>
CC: Sanchayan Maity <maitysanchayan@gmail.com>
CC: Lokesh Vutla <lokeshvutla@ti.com>
CC: Patrick Delaunay <patrick.delaunay@st.com>
CC: Gary Bisson <gary.bisson@boundarydevices.com>
CC: Alexander Graf <agraf@suse.de>
CC: u-boot@lists.denx.de
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Current code does not set output level in bcm6345_gpio_direction_output,
fix it.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
This is no longer used in U-Boot. Drop it.
This PMIC driver (power and GPIO) is used by the sandbox SPMI tests.
Update the drivers to support a live device tree so that the tests pass.
Add support for requesting GPIOs with a live device tree.
This involves adjusting the function signature for the legacy function
gpio_request_by_name_nodev(), so fix up all callers.
Fixes to stm32f746-disco.c:
Use the new dev_read...() functions to access the device tree, so that a
live tree can be used.
Move the main part of the GPIO request function into a separate function
so that it can be used by the live tree function when added. Update the
xlate method to use a node reference.
Update all GPIO drivers to handle the modified xlate() method.
At present devices use a simple integer offset to record the device tree
node associated with the device. In preparation for supporting a live
device tree, which uses a node pointer instead, refactor existing code to
access this field through an inline function.
It is good practice to include common.h as the first header. This ensures
that required features like the DECLARE_GLOBAL_DATA_PTR macro,
configuration options and common types are available.
Fix up some files which currently don't do this. This is necessary because
driver model will soon start using global data and configuration in the
dm/read.h header file, included via dm.h. The gd->fdt_blob value will be
used to access the device tree and CONFIG options will be used to
determine whether to support inline functions in the header file.
This function should not be used outside the core driver-model code.
Update it to use dm_scan_fdt_dev() instead.
These support the flat device tree. We want to use the dev_read_..()
prefix for functions that support both flat tree and live tree. So rename
the existing functions to avoid confusion.
In the end we will have:
1. dev_read_addr...() - works on devices, supports flat/live tree
2. devfdt_get_addr...() - current functions, flat tree only
3. of_get_address() etc. - new functions, live tree only
All drivers will be written to use 1. That function will in turn call
either 2 or 3 depending on whether the flat or live tree is in use.
Note this involves changing some dead code - the imx_lpi2c.c file.
