path: root/drivers/gpio
2010-02-12add a new AT91 GPIO driverJens Scharsig
* add a real AT91 GPIO driver instead of header inline code * resolve the mixing of port and pins * change board config files to use new driver * add macros to gpio to realize backward compatibility Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-01-23Kirkwood: Upgated licencing for files imported from linux source to GPLv2 or ↵Prafulla Wadaskar
later These are few files directly imported from Linux kernel source. Those are not modifyed at all ar per strategy. These files contains source with GPLv2 only whereas u-boot expects GPLv2 or latter These files are updated for the same from prior permission from original writes Acked-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-07-23Kirkwood: add Marvell Kirkwood gpio driverDieter Kiermaier
Signed-off-by: Dieter Kiermaier <dk-arm-linux@gmx.de> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Tested-by: Heiko Schocher <hs@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-24i.MX31: add a simple gpio driverGuennadi Liakhovetski
This is a minimal driver, so far only managing output. It will be used by the mxc_spi.c driver. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-12-19Add support for PCA953x I2C gpio devicesPeter Tyser
Initial support for NXP's 4 and 8 bit I2C gpio expanders (eg pca9537, pca9557, etc). The CONFIG_PCA953X define enables support for the devices while the CONFIG_CMD_PCA953X define enables the pca953x command. The CONFIG_CMD_PCA953X_INFO define enables an 'info' sub-command which provides summary information for the given pca953x device. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
