path: root/drivers/gpio/s5p_gpio.c
2013-06-25gpio: s5p_gpio: Call s5p_gpio_set_value() instead of open-codeAxel Lin
Call s5p_gpio_set_value() to avoid code duplication. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-11-15gpio:fix: Proper handling of GPIO subsystem parts at Samsung devicesŁukasz Majewski
Now proper GPIO parts numbering is handled at Samsung devices. This fix is necessary for code using GPIO located at other banks than first. Test HW: - Exynos4210 - Trats - S5PC110 - goni Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-01-09gpio: Replace ARM gpio.h with the common API in include/asm-genericJoe Hershberger
ARM boards should use the generic GPIO API This means changing gpio to unsigned type Remove the unused gpio_toggle() function which is not part of the API Comment that free should not modify pin state Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> fixed merge conflict in da8xx_gpio.c, tegra2_gpio.c, and extended to the new mxs_gpio.c. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-09-04i2c:gpio:s5p: I2C GPIO Software implementation (via soft_i2c)Łukasz Majewski
This patch adds support for software I2C for GONI and Universal C210 reference targets. It adds support for access to GPIOs by number, not as it is present, by bank and offset. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Cc: Heiko Schocher <hs@denx.de>
2011-09-03gpio:samsung s5p_ suffix add for GPIO functionsŁukasz Majewski
This change is driven by need of general gpio_* functions, which as their parameter are accepting the GPIO pin number, NOT block and pin. This makes the code alike to omap, and allows for using more generic frameworks (e.g. software I2C). Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-06-14s5pc1xx: gpio: bug fix at gpio_set_pull functionMinkyu Kang
When set to PULL_NONE, gpio_set_pull function is returned without write the register. This patch fixed it. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-04-30SAMSUNG: make s5p common gpio functionsMinkyu Kang
Because of s5pc1xx gpio is same as s5p seires SoC, move gpio functions to drvier/gpio/ and modify structure's name from s5pc1xx_ to s5p_. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
