path: root/drivers/gpio/omap_gpio.c
2013-08-19SPDX-License-Identifier: fixing some problematic GPL-2.0 filesWolfgang Denk
Unlike the other patches in this series so far, this commit fixes a ambiguity in the license terms for some OMAP files: the code was originally derived from the Linux kernel sources, where it was clearly marked as GPL-2.0 (i. e. without the "or later" part), but the U-Boot version had a GPL-2.0+ file header added, apparently without permission / relicensing from the original authors of the code. Insert a GPL-2.0 SPDX-License-Identifier to fix this. Signed-off-by: Wolfgang Denk <wd@denx.de> cc: Tom Rix <Tom.Rix@windriver.com> Cc: Tom Rini <trini@ti.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Tom Rini <trini@ti.com>
2013-07-02ARM: OMAP: GPIO: Fix valid range and enable usage of all GPIOs on OMAP5Axel Lin
The omap_gpio driver is used by AM33XX, OMAP3/4, OMAP54XX and DRA7XX SoCs. These SoCs have different gpio count but currently omap_gpio driver uses hard coded 192 which is wrong. This patch fixes this issue by: 1. Move define of OMAP_MAX_GPIO to all arch/arm/include/asm/arch-omap*/gpio.h. 2. Update gpio bank settings and enable GPIO modules 7 & 8 clocks for OMAP5. Thanks for Lubomir Popov to provide valuable comments to fix this issue. Signed-off-by: Axel Lin <axel.lin@ingics.com> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Acked-by: Heiko Schocher <hs@denx.de>
2012-12-10gpio: add gpio_is_valid() to omap_gpio APINikita Kiryanov
Add gpio_is_valid() to omap_gpio API Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-09-01dm: Move OMAP GPIO driver to drivers/gpio/Marek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: U-Boot DM <u-boot-dm@lists.denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
