path: root/drivers/gpio/gpio-uclass.c
2018-07-19gpio: dm: Support manual relocation for gpioMichal Simek
Relocate gpio ops as was done by: "dm: Add support for all targets which requires MANUAL_RELOC" (sha1: 484fdf5ba058b07be5ca82763aa2b72063540ef3) Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-06gpio: uclass: Fix debug stringMario Six
A debug string still has the old name of a function being called; update it. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-06gpio: add static to get_function()Masahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: gpio: Add live tree supportSimon Glass
Add support for requesting GPIOs with a live device tree. This involves adjusting the function signature for the legacy function gpio_request_by_name_nodev(), so fix up all callers. Signed-off-by: Simon Glass <sjg@chromium.org> Fixes to stm32f746-disco.c: Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-01dm: gpio: Refactor to prepare for live tree supportSimon Glass
Move the main part of the GPIO request function into a separate function so that it can be used by the live tree function when added. Update the xlate method to use a node reference. Update all GPIO drivers to handle the modified xlate() method. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-12gpio-uclass.c: Fix comparison of unsigned expression warningTom Rini
We declare that gpio_base (which is the base for counting gpios, not an address) is unsigned. Therefore the comparison with >= 0 is always true. As the desire is to allow for this base number to be 0, we can just drop this check. Reported by clang-3.8. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-03dm: gpio: Add methods for open drain settingmario.six@gdsys.cc
Certain GPIO devices have the capability to switch their GPIOs into open-drain mode, that is, instead of actively driving the output (Push-pull output), the pin is connected to the collector (for a NPN transistor) or the drain (for a MOSFET) of a transistor, respectively. The pin then either forms an open circuit or a connection to ground, depending on the state of the transistor. This patch adds functions to the GPIO uclass to switch GPIOs to open-drain mode on devices that support it. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2016-05-17dm: gpio: add a default gpio xlate routineEric Nelson
Many drivers use a common form of offset + flags for device tree nodes. e.g.: <&gpio1 2 GPIO_ACTIVE_LOW> This patch adds a common implementation of this type of parsing and calls it when a gpio driver doesn't supply its' own xlate routine. This will allow removal of the driver-specific versions in a handful of drivers and simplify the addition of new drivers. Signed-off-by: Eric Nelson <eric@nelint.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-03-17gpio: Use const where possibleSimon Glass
Some functions do not change the struct gpio_desc parameter. Update these to use const so this is clear. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-17gpio: Add a function to obtain a GPIO vector valueSimon Glass
We can use GPIOs as binary digits for reading 'strapping' values. Each GPIO is assigned a single bit and can be set high or low on the circuit board. We already have a legacy function for reading these values. Add one that supports driver model. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-25bug.h: move BUILD_BUG_* defines to include/linux/bug.hMasahiro Yamada
BUILD_BUG_* macros have been defined in several headers. It would be nice to collect them in include/linux/bug.h like Linux. This commit is cherry-picking useful macros from include/linux/bug.h of Linux 4.4. I did not import BUILD_BUG_ON_MSG() because it would not work if it is used with include/common.h in U-Boot. I'd like to postpone it until the root cause (the "error()" macro in include/common.h causes the name conflict with "__attribute__((error()))") is fixed. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-20dm: gpio: Allow the uclass to work without printf()Simon Glass
For SPL we don't really need sprintf() and with tiny-printf this is not available. Allow this to be dropped in SPL when using tiny-printf. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05dm: gpio: Check a GPIO is valid before using itSimon Glass
Since a gpio_desc is allowed to be invalid we should return an error indicating that the operation cannot be completed. This can happen if the GPIO is optional - e.g. some devices may have a reset line and some may not. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21dm: gpio: Add dm_gpio_request() to manually request a GPIOSimon Glass
This function can be used for testing to manually request a GPIO for use, without resorting to the legacy GPIO API. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21dm: gpio: Add dm_gpio_lookup_name() to look up a GPIO nameSimon Glass
Provide a driver-model function to look up a GPIO name. Make the standard function use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-08dm: gpio: uclass: Add flag to control sequence numberingBhuvanchandra DV
Like SPI and I2C few GPIO controllers also have multiple chip instances. This patch adds the flag 'DM_UC_FLAG_SEQ_ALIAS' in gpio_uclass driver to control device sequence numbering. By defalut the dev->r_seq for gpio_uclass will alwalys returns -1, which leads the gpio driver probe failure when using the driver with device trees. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
2015-05-13dm: gpio: Add error handling and a function to claim vector GPIOsSimon Glass
gpio_get_values_as_int() should return an error if something goes wrong. Also provide gpio_claim_vector(), a function to request the GPIOs and set them to input mode. Otherwise callers have to do this themselves. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-04-18dm: gpio: Add an implementation for gpio_get_number()Simon Glass
This has a prototype but no implementation. It returns the global GPIO number given a gpio_desc. It is useful for debugging in some cases. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: gpio: request list: return the count if requests max_count reachedPrzemyslaw Marczak
The function gpio_request_list_by_name_nodev() returned -ENOSPC error, when the loop count was greater than requested count. This was wrong, because function should return the requested gpio count, when meets the call request without errors. Now, the loop ends on requested max_count. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-16dm: core: Add dev_get_uclass_priv() to access uclass private dataSimon Glass
Add a convenience function to access the private data that a uclass stores for each of its devices. Convert over most existing uses for consistency and to provide an example for others. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: gpio: Add better functions to request GPIOsSimon Glass
At present U-Boot sort-of supports the standard way of reading GPIOs from device tree nodes, but the support is incomplete, a bit clunky and only works for GPIO bindings where #gpio-cells is 2. Add new functions to request GPIOs, taking full account of the device tree binding. These permit requesting a GPIO with a simple call like: gpio_request_by_name(dev, "cd-gpios", 0, &desc, GPIOD_IS_IN); This will request the GPIO, looking at the device's node which might be this, for example: cd-gpios = <&gpio TEGRA_GPIO(B, 3) GPIO_ACTIVE_LOW>; The GPIO will be set to input mode in this case and polarity will be honoured by the GPIO calls. It is also possible to request and free a list of GPIOs. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: gpio: Add a driver GPIO translation methodSimon Glass
Only the GPIO driver knows about the full GPIO device tree binding used by a device. Add a method to allow the driver to provide this information to the uclass, including the GPIO offset within the device and flags such as the polarity. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: gpio: Add a native driver model APISimon Glass
So far driver model's GPIO uclass just implements the existing GPIO API. This has some limitations: - it requires manual device tree munging to support GPIOs in device tree (fdtdec_get_gpio() and friends) - it does not understand polarity - it is somewhat slower since we must scan for the GPIO device each time - Global GPIO numbering can change if other GPIO drivers are probed - it requires extra steps to set the GPIO direction and value The new functions have a dm_ prefix where necessary to avoid name conflicts but we can remove that when it is no-longer needed. The new struct gpio_desc holds all required information about the GPIO. For now this is intended to be stored by the client requesting the GPIO, but in future it might be brought into the uclass in some way. With these changes the old GPIO API still works, and uses the driver model API underneath. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21dm: gpio: Add a function to read an ID from a list of GPIOsSimon Glass
For board IDs a common approach is to set aside several GPIOs for use in determining the board ID. This can provide information about board features and the revision. Add a function that turns a list of GPIOs into an integer by assigning each GPIO to a single bit. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-23dm: gpio: Add gpio_requestf() helper for printf() stringsSimon Glass
Add a helper which permits a printf()-style format string for the requester string. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-23dm: Move the function for getting GPIO status into the uclassSimon Glass
This function can be more easily tested if it is in the uclass. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-23dm: gpio: Add gpio_get_function() and friendsSimon Glass
Add helpers to the uclass to allow finding out the pin function. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-23dm: gpio: Implement GPIO reservation in the uclassSimon Glass
We have several GPIO drivers now and all are doing similar things to record which GPIOs are reserved. Move this logic into the uclass to make the drivers similar. We retain the request()/free() methods since currently one driver does use these for setting up the pin. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-23dm: gpio: Support numbered GPIOsSimon Glass
At present banks must be named and it is not possible to refer to GPIOs by number in driver model. Some boards use numbering - e.g. OMAP. It is fairly easy to support by detecting the absense of a bank name (which starts with a letter). Add support for numbered GPIOs in addition to the existing bank support. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2014-06-20dm: Use case-insensitive comparison for GPIO banksSimon Glass
We want 'N0' and 'n0' to mean the same thing, so ensure that case is not considered when naming GPIO banks. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-27dm: rename device struct to udeviceHeiko Schocher
using UBI and DM together leads in compiler error, as both define a "struct device", so rename "struct device" in include/dm/device.h to "struct udevice", as we use linux code (MTD/UBI/UBIFS some USB code,...) and cannot change the linux "struct device" Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Marek Vasut <marex@denx.de>
2014-03-04dm: Add GPIO support and testsSimon Glass
Add driver model support for GPIOs. Since existing GPIO drivers do not use driver model, this feature must be enabled by CONFIG_DM_GPIO. After all GPO drivers are converted over we can perhaps remove this config. Tests are provided for the sandbox implementation, and are a sufficient sanity check for basic operation. The GPIO uclass understands the concept of named banks of GPIOs, with each GPIO device providing a single bank. Within each bank the GPIOs are numbered using an offset from 0 to n-1. For example a bank named 'b' with 20 offsets will provide GPIOs named b0 to b19. Anonymous GPIO banks are also supported, and are just numbered without any prefix. Each time a GPIO driver is added to the uclass, the GPIOs are renumbered accordinging, so there is always a global GPIO numbering order. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com> Signed-off-by: Viktor Křivák <viktor.krivak@gmail.com> Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com>
