path: root/drivers/gpio/dwapb_gpio.c
2018-11-29gpio: dwapb_gpio: fix binding without bank-name propertySimon Goldschmidt
As a preparation for merging the socfpga gen5 devicetree files from Linux, this patch makes the dwapb gpio driver work correctly without the 'bank-name' property on the gpio-controller nodes. This property is not present in the Linux drivers and thus is not present in the Linux devicetrees. It is only used to access pins via bank name. This fallback is necessary since without it, the driver will return an error code which will lead to an error in U-Boot startup. The bank names will still be added to the default board device trees in follow-up patch, but other boards using this driver and not including the bank name should also work with the socfpga.dtsi without adding the bank-name property. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2018-10-03gpio: dwapb_gpio: Change to use devm_kcalloc()Ley Foon Tan
Change to use managed resource function devm_kcalloc(), so it will auto free memory when driver is removed. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2018-09-15gpio: dwapb_gpio: Change to use dev_read_addr()Ley Foon Tan
This changes the driver to use dev_read_addr() which is safe both for flat trees and live trees. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2018-09-15gpio: dwapb_gpio: Add reset ctrl to driverLey Foon Tan
Add code to reset all reset signals as in gpio DT node. A reset property is an optional feature, so only print out a warning and do not fail if a reset property is not present. If a reset property is discovered, then use it to deassert, thus bringing the IP out of reset. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2018-09-15gpio: dwapb_gpio: Enable get_function supportLey Foon Tan
Enabled get_function support for dwapb where the function will return the state of GPIO port. Signed-off-by: Chin Liang See <chin.liang.see@intel.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-11-21gpio: dwapb: Add support for port BPhil Edworthy
The IP supports two ports, A and B, each providing up to 32 gpios. The driver already creates a 2nd gpio bank by reading the 2nd node from DT, so this is quite a simple change to support the 2nd bank. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-13libfdt: Bring in upstream stringlist functionsSimon Glass
These have now landed upstream. The naming is different and in one case the function signature has changed. Update the code to match. This applies the following upstream commits by Thierry Reding <treding@nvidia.com> : 604e61e fdt: Add functions to retrieve strings 8702bd1 fdt: Add a function to get the index of a string 2218387 fdt: Add a function to count strings Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-23gpio: Add DW APB GPIO driverMarek Vasut
Add driver for the DesignWare APB GPIO IP block. This driver is DM capable and probes from DT. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org>
