path: root/drivers/gpio/da8xx_gpio.c
2013-03-11Merge u-boot/master into u-boot-ti/masterTom Rini
In master we had already taken a patch to fix the davinci GPIO code for CONFIG_SOC_DM646X and in u-boot-ti we have additional patches to support DA830 (which is CONFIG_SOC_DA8XX && !CONFIG_SOC_DA850). Resolve these conflicts manually and comment the #else/#endif lines for clarity. Conflicts: arch/arm/include/asm/arch-davinci/gpio.h drivers/gpio/da8xx_gpio.c Signed-off-by: Tom Rini <trini@ti.com>
2013-02-20gpio: Build the da8xx_gpio code for the davinci644x deviceHolger Hans Peter Freyther
The differences include the number of GPIOs and that one is not required to set the pinmux on request. Signed-off-by: Holger Hans Peter Freyther <holger@freyther.de>
2013-02-18da8xx: Add the missing pinmux for da830 to the gpio driverTomas Novotny
The pinmux was generated from linux/arch/arm/mach-davinci/da830.c as of kernel version 3.7.5. If the driver is used for the da850, then SoC variant must be specified by CONFIG_SOC_DA850. Signed-off-by: Tomas Novotny <tomas@novotny.cz> Cc: Tom Rini <trini@ti.com>
2012-01-09gpio: Replace ARM gpio.h with the common API in include/asm-genericJoe Hershberger
ARM boards should use the generic GPIO API This means changing gpio to unsigned type Remove the unused gpio_toggle() function which is not part of the API Comment that free should not modify pin state Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> fixed merge conflict in da8xx_gpio.c, tegra2_gpio.c, and extended to the new mxs_gpio.c. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-12-09drivers/gpio/da8xx_gpio.c: Fix build warningAnatolij Gustschin
Fix: da8xx_gpio.c: In function 'gpio_toggle_value': da8xx_gpio.c:208:23: warning: variable 'bank' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-09-11Minor coding style cleanup.Wolfgang Denk
2011-08-03DA8xx: add generic GPIO driverLaurence Withers
Add a generic GPIO driver for the DaVinci DA8xx processors. It is turned on by defining CONFIG_DA8XX_GPIO and fulfills the generic GPIO interface specified in <asm/gpio.h> . The driver has support for both manipulating GPIO pins as well as automatically configuring the pin multiplexor registers to set the pin function to GPIO. Signed-off-by: Laurence Withers <lwithers@guralp.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
