path: root/drivers/gpio/altera_pio.c
2015-11-18altera_pio: change ioremap to map_physmemThomas Chou
Change ioremap() to map_physmem(), as it is more used in u-boot. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de>
2015-10-23nios2 : convert altera_pio to driver modelThomas Chou
Convert altera_pio to driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Chin Liang See <clsee@altera.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2011-10-28gpio: Add driver for Altera's PIO coreJoachim Foerster
This driver may handle multiple PIO cores and thus needs to be setup by calling the altera_pio_init() function within the early board setup routine. The driver comes with some extras, see below the copyleft header. Signed-off-by: Joachim Foerster <joachim.foerster@missinglinkelectronics.com> Tested-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
