path: root/drivers/gpio/Makefile
2015-03-04dm: tegra: Enable driver model in SPL and adjust the GPIO driverSimon Glass
Use the full driver model GPIO and serial drivers in SPL now that these are supported. Since device tree is not available they will use platform data. Remove the special SPL GPIO function as it is no longer needed. This is all in one commit to maintain bisectability. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-28Merge branch 'u-boot-sunxi/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-07-23dm: gpio: Don't use the driver model uclass for SPLSimon Glass
Driver model does not support SPL yet, so we should not use the GPIO uclass for SPL. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-18sunxi: add gpio driverIan Campbell
This patch enables CONFIG_CMD_GPIO for the Allwinner (sunxi) platform as well as providing the common gpio API (gpio_request/free, direction in/out, get/set etc). Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Ma Haijun <mahaijuns@gmail.com> Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Cc: Henrik Nordström <henrik@henriknordstrom.net> Cc: Tom Cubie <Mr.hipboi@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com>
2014-03-04dm: Add GPIO support and testsSimon Glass
Add driver model support for GPIOs. Since existing GPIO drivers do not use driver model, this feature must be enabled by CONFIG_DM_GPIO. After all GPO drivers are converted over we can perhaps remove this config. Tests are provided for the sandbox implementation, and are a sufficient sanity check for basic operation. The GPIO uclass understands the concept of named banks of GPIOs, with each GPIO device providing a single bank. Within each bank the GPIOs are numbered using an offset from 0 to n-1. For example a bank named 'b' with 20 offsets will provide GPIOs named b0 to b19. Anonymous GPIO banks are also supported, and are just numbered without any prefix. Each time a GPIO driver is added to the uclass, the GPIOs are renumbered accordinging, so there is always a global GPIO numbering order. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com> Signed-off-by: Viktor Křivák <viktor.krivak@gmail.com> Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com>
2014-02-22gpio: kona: Add Kona gpio driverDarwin Rambo
Add support for the Kona GPIO controller found on Broadcom mobile SoCs. Signed-off-by: Darwin Rambo <drambo@broadcom.com> Reviewed-by: Steve Rae <srae@broadcom.com> Reviewed-by: Markus Mayer <markus.mayer@linaro.org> Reviewed-by: Tim Kryger <tkryger@linaro.org>
2013-11-08Add support for SX151x SPI GPIO ExpandersViktar Palstsiuk
Signed-off-by: Viktar Palstsiuk <viktar.palstsiuk@promwad.com>
2013-10-31drivers: convert makefiles to Kbuild styleMasahiro Yamada
2013-07-30gpio: tca642x: Add the tca642x gpio expander driverDan Murphy
Add the tca642x gpio expander driver Datasheet: http://www.ti.com/product/tca6424a Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-05-13bfin: Move gpio support for bf54x and bf60x into the generic driver folder.Sonic Zhang
The gpio spec for bf54x and bf60x differ a lot from the old gpio driver for bf5xx. A lot of machine macros are used to accomodate both code in one gpio driver. This patch split the old gpio driver and move new gpio2 support to the generic gpio driver folder. - To enable gpio2 driver, macro CONFIG_ADI_GPIO2 should be defined in the board's config header file. - The gpio2 driver supports bf54x, bf60x and future ADI processors, while the older gpio driver supports bf50x, bf51x, bf52x, bf53x and bf561. - All blackfin specific gpio function names are replaced by the generic gpio APIs. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2013-05-09gpio: Add support for microblaze xilinx GPIOMichal Simek
Microblaze uses gpio which is connected to the system reset. Currently gpio subsystem wasn't used for it. Add gpio driver and change Microblaze reset logic to be done via gpio subsystem. There are various configurations which Microblaze can have that's why gpio_alloc/gpio_alloc_dual(for dual channel) function has been introduced and gpio can be allocated dynamically. Adding several gpios IP is also possible and supported. For listing gpio configuration please use "gpio status" command This patch also remove one compilation warning: microblaze-generic.c: In function 'do_reset': microblaze-generic.c:38:47: warning: operation on '*1073741824u' may be undefined [-Wsequence-point] Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-20gpio: Build the da8xx_gpio code for the davinci644x deviceHolger Hans Peter Freyther
The differences include the number of GPIOs and that one is not required to set the pinmux on request. Signed-off-by: Holger Hans Peter Freyther <holger@freyther.de>
2012-12-06x86: gpio: Add GPIO driver for Intel ICH6 and later.Bill Richardson
Implement <asm-generic/gpio.h> functions for Intel ICH6 and later. Only GPIOs 0-31 are handled by this code. Signed-off-by: Bill Richardson <wfrichar@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-03ARM : Add GPIO Driver and IOMUX definition for S3C2440Gabriel Huau
It's now possible to use the gpio driver interface for s3c2440. This patch add iomux definitions too. Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr>
2012-09-01ARM: add basic support for the Broadcom BCM2835 SoCStephen Warren
This SoC is used in the Raspberry Pi, for example. For more details, see: http://www.broadcom.com/products/BCM2835 http://www.raspberrypi.org/wp-content/uploads/2012/02/BCM2835-ARM-Peripherals.pdf. Initial support is enough to boot to a serial console, execute a minimal set of U-Boot commands, download data over a serial port, and boot a Linux kernel. No storage or network drivers are implemented. GPIO driver originally by Vikram Narayanan <vikram186@gmail.com> with many fixes from myself. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2012-09-01snowball: Add support for ux500 based snowball boardMathieu J. Poirier
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: John Rigby <john.rigby@linaro.org> Acked-by: Tom Rini <trini@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Conflicts: drivers/gpio/Makefile
2012-09-01dm: Move OMAP GPIO driver to drivers/gpio/Marek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: U-Boot DM <u-boot-dm@lists.denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-08-08sh: Add support pin function control using GPIONobuhiro Iwamatsu
Renesas SH and R-Mobile set up device using PFC. This provide the framework. Most codes were brought from linux kernel. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-07-07GPIO: Add SPEAr GPIO driverStefan Roese
Tested on x600 (SPEAr600). Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07gpio: tegra2: rename tegra2_gpio.* to tegra_gpio.*Tom Warren
In anticipation of Tegra3 support, continue removing/renaming Tegra2-specific files. No functional changes (yet). Updated copyrights to 2012. Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-12sandbox: gpio: add basic driver for simulating GPIOsSimon Glass
This provides a way of simulating GPIOs by setting values which are seen by the normal gpio_get/set_value() calls. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-01-09mpc83xx: Add a GPIO driver for the MPC83XX familyJoe Hershberger
Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-11-21Merge branch 'master' of git://git.denx.de/u-boot-niosWolfgang Denk
* 'master' of git://git.denx.de/u-boot-nios: nios2: Offer ft_board_setup() capability and call fdt_fixup_ethernet(). board/nios2-generic: Use altera_pio driver and remove board specific driver gpio: Add driver for Altera's PIO core nios2: Pseudo implement dcache_status/enable/disable()
2011-11-11iMX28: Add GPIO controlMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-10-28gpio: Add driver for Altera's PIO coreJoachim Foerster
This driver may handle multiple PIO cores and thus needs to be setup by calling the altera_pio_init() function within the early board setup routine. The driver comes with some extras, see below the copyleft header. Signed-off-by: Joachim Foerster <joachim.foerster@missinglinkelectronics.com> Tested-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2011-10-22gpio: Add PCA9698 40-bit I2C I/O portDirk Eibach
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
2011-09-30gpio: Add GPIO driver framework for Marvell SoCsAjay Bhargav
This patch adds generic GPIO driver framework support for Marvell SoCs. To enable GPIO driver define CONFIG_MARVELL_GPIO and for GPIO commands define CONFIG_CMD_GPIO in your board configuration file. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-08-03DA8xx: add generic GPIO driverLaurence Withers
Add a generic GPIO driver for the DaVinci DA8xx processors. It is turned on by defining CONFIG_DA8XX_GPIO and fulfills the generic GPIO interface specified in <asm/gpio.h> . The driver has support for both manipulating GPIO pins as well as automatically configuring the pin multiplexor registers to set the pin function to GPIO. Signed-off-by: Laurence Withers <lwithers@guralp.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-07-04GPIO: Tegra2: add GPIO driver for Tegra2Tom Warren
2010-12-16gpio: Add Multi-Function-Pin configuration driver for Marvell SoCsPrafulla Wadaskar
Most of the Marvell SoCs has Multi Function Pin (MFP) configuration registers For ex. ARMADA100. These registers are programmed to expose the specific functionality associated with respective SoC Pins This driver provides configuration APIs, using them, configuration need to be done in board specific code for ex- following code configures MFPs 107 and 108 for UART_TX/RX functionality int board_early_init_f(void) { u32 mfp_cfg[] = { /* Console on UART1 */ MFP107_UART1_RXD, MFP108_UART1_TXD, MFP_EOC /*End of configureation*/ }; /* configure MFP's */ mfp_config(mfp_cfg); return 0; } Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-09-29Use common function to set GPIOs for MX3 and MX5Stefano Babic
The patch adds support for setting gpios to the MX51 processor and change name to the corresponding functions for MX31. In this way, it is possible to get rid of nasty #ifdef switches related to the processor type. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-08-26ARMV7: S5P: rename from CONFIG_S5PC1XX to CONFIG_S5PMinkyu Kang
Use the same configuration around S5P SoCs. (s5pc100, s5pc110, s5pc210 and so on) Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-04-30SAMSUNG: make s5p common gpio functionsMinkyu Kang
Because of s5pc1xx gpio is same as s5p seires SoC, move gpio functions to drvier/gpio/ and modify structure's name from s5pc1xx_ to s5p_. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-02-12add a new AT91 GPIO driverJens Scharsig
* add a real AT91 GPIO driver instead of header inline code * resolve the mixing of port and pins * change board config files to use new driver * add macros to gpio to realize backward compatibility Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2009-07-23Kirkwood: add Marvell Kirkwood gpio driverDieter Kiermaier
Signed-off-by: Dieter Kiermaier <dk-arm-linux@gmx.de> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Tested-by: Heiko Schocher <hs@denx.de>
2009-02-24i.MX31: add a simple gpio driverGuennadi Liakhovetski
This is a minimal driver, so far only managing output. It will be used by the mxc_spi.c driver. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-12-19Add support for PCA953x I2C gpio devicesPeter Tyser
Initial support for NXP's 4 and 8 bit I2C gpio expanders (eg pca9537, pca9557, etc). The CONFIG_PCA953X define enables support for the devices while the CONFIG_CMD_PCA953X define enables the pca953x command. The CONFIG_CMD_PCA953X_INFO define enables an 'info' sub-command which provides summary information for the given pca953x device. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
