path: root/drivers/fsl_pci_init.c
2007-10-24fsl_pci_init enable COMMAND_MEMORY if inbound windowEd Swarthout
Patch 16e23c3f removed PCSRBAR allocation. But passing zero windows to pciauto_setup_device has the side effect of not getting COMMAND_MEMORY set. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
2007-08-30Revert "Fix MPC8544DS PCIe3 scsi."Ed Swarthout
This reverts commit 9468e680. Commit 16e23c3f5da removing allocation of PCSRBAR is sufficient. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
2007-08-29Fix MPC8544DS PCIe3 scsi.Kumar Gala
<ed.swarthout@freescale.com> The problem is pciauto_setup_device() getting called from fsl_pci_init.c is allocating memory space it doesn't need. Signed-off-by: Ed Swarthout <ed.swarthout@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-29fsl_pci_init - Remove self PCSRBAR allocationEd Swarthout
CPU physical address space was being wasted by allocating a PCSRBAR PCI inbound region to it's memory space. As a rule, PCSRBAR should be left alone since it does not affect transactions from self and other masters may have changed it. Signed-off-by: Ed Swarthout <ed.swarthout@freescale.com>
2007-08-10fsl_pci_init cleanup.Ed Swarthout
Do not enable normal errors created during probe (master abort, perr, and pcie Invalid Configuration access). Add CONFIG_PCI_NOSCAN board option to prevent bus scan. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2007-08-06Make MPC8641's PCI/PCI-E driver a common driver for many FSL parts.Ed Swarthout
All of the PCI/PCI-Express driver and initialization code that was in the MPC8641HPCN port has now been moved into the common drivers/fsl_pci_init.c. In a subsequent patch, this will be utilized by the 85xx ports as well. Common PCI-E IMMAP register blocks for FSL 85xx/86xx are added. Also enable the second PCI-Express controller on 8641 by getting its BATS and CFG_ setup right. Fixed a u16 vendor compiler warning in AHCI driver too. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Zhang Wei <wei.zhang@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
