path: root/drivers/fpga
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-18FPGA: fix support for non-Lattice devicesWolfgang Denk
Commit 3b8ac464 "FPGA: add support for downloading Lattice bitstream" added support for Lattice devices, but failed to add #ifdef's that are needed when building for non-Lattice devices, which results in build failures like these: Configuring for GEN860T board... drivers/fpga/libfpga.a(fpga.o): In function `fpga_dev_info': /home/wd/git/u-boot/work/drivers/fpga/fpga.c:145: undefined reference to `lattice_info' drivers/fpga/libfpga.a(fpga.o): In function `fpga_dump': /home/wd/git/u-boot/work/drivers/fpga/fpga.c:269: undefined reference to `lattice_dump' drivers/fpga/libfpga.a(fpga.o): In function `fpga_load': /home/wd/git/u-boot/work/drivers/fpga/fpga.c:233: undefined reference to `lattice_load' make: *** [u-boot] Error 1 Add the missing code. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2010-10-13FPGA: add support for downloading Lattice bitstreamStefano Babic
The patch adds support to load a Lattice's bitstream image (called VME file) into a Lattice FPGA. The code containing the state machine delivered as part of Lattice's ispVMtools is integrated. The FPGA is programmed using the JTAG interface. The board maintainer must provide accessors to drive the JTAG signals TCK, TMS, TDI and to get the value of the input signal TDO. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-03-24add block write function to spartan3 slave serial loadWolfgang Wegner
Using seperate function calls for each bit-bang of slave serial load can be painfully slow. This patch adds the possibility to supply a block write function that loads the complete block of data in one call (like it can already be done with Altera FPGAs). On an MCF5373L (240 MHz) loading an XC3S4000 this reduces the load time from around 15 seconds to around 3 seconds Signed-off-by: Wolfgang Wegner <w.wegner at astro-kom.de>
2009-10-03fpga: Remove relocation fixupsPeter Tyser
PPC boards are the only users of the current FPGA code which is littered with manual relocation fixups. Now that proper relocation is supported for PPC boards, remove FPGA manual relocation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-02-21fpga: Fix Spartan III FPGA bootingMatthias Fuchs
This patch does some minor fixing of the Xilinx Spartan III FPGA boot code: - Fixed call order of post configuration callback and success message printing (result of copy-paste?) - remove obsolete comment - minor coding style cleanup Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2009-02-21fpga: Fix Spartan II FPGA bootingMatthias Fuchs
This patch does some minor fixing of the Xilinx Spartan II FPGA boot code: - Fixed call order of post configuration callback and success message printing (result of copy-paste?) - relocate post configuration callback only when it is implemented - remove obsolete comment - minor coding style cleanup Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-12-05FPGA: move fpga drivers to drivers/fpgaJean-Christophe PLAGNIOL-VILLARD
