There is no Kconfig option for this code, but it seems to be useful. Add
one.
one.
At this point, the remaining places where we have a symbol that is
defined as CONFIG_... are in fairly odd locations. While as much dead
code has been removed as possible, some of these locations are simply
less obvious at first. In other cases, this code is used, but was
defined in such a way as to have been missed by earlier checks. Perform
a rename of all such remaining symbols to be CFG_... rather than
CONFIG_...
This is always defined to 5, so use that as the default.
Cc: Michal Simek <michal.simek@amd.com>
Reviewed-by: Michal Simek <michal.simek@amd.com>
The fs_loader device is used to pull in settings via the chosen node.
However, there was no library function for this, so arria10 was doing it
explicitly. This function subsumes that, and uses ofnode_get_chosen_node
instead of navigating the device tree directly. Because fs_loader pulls
its config from the environment by default, it's fine to create a device
with nothing backing it at all. Doing this allows enabling
CONFIG_FS_LOADER without needing to modify the device tree.
Signed-off-by: Sean Anderson <sean.anderson@seco.com>
Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
Perform a simple rename of CONFIG_FPGA_DELAY to CFG_FPGA_DELAY
CONFIG_SYS_FPGA_CHECK_BUSY
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS namespace do
not easily transition to Kconfig. In many cases they likely should come
from the device tree instead. Move these out of CONFIG namespace and in
to CFG namespace.
Instead of using DEBUG or LOG_DEBUG the driver still had its own
definition for debug output.
Signed-off-by: Alexander Dahl <ada@thorsis.com>
Signed-off-by: Michal Simek <michal.simek@amd.com>
Link: https://lore.kernel.org/r/20221007122003.11239-11-ada@thorsis.com
Link: https://lore.kernel.org/r/20221007122003.11239-10-ada@thorsis.com
Link: https://lore.kernel.org/r/20221007122003.11239-9-ada@thorsis.com
Link: https://lore.kernel.org/r/20221007122003.11239-8-ada@thorsis.com
Link: https://lore.kernel.org/r/20221007122003.11239-7-ada@thorsis.com
Link: https://lore.kernel.org/r/20221007122003.11239-6-ada@thorsis.com
Warning appears if built with FPGA_DEBUG defined:
CC drivers/fpga/virtex2.o
/mnt/data/adahl/src/u-boot/drivers/fpga/virtex2.c: In function ‘virtex2_ssm_load’:
/mnt/data/adahl/src/u-boot/drivers/fpga/virtex2.c:333:11: warning: format ‘%d’ expects argument of type ‘int’, but argument 4 has type ‘size_t’ {aka ‘long unsigned int’} [-Wformat=]
PRINTF("%s:%d:done went active early, bytecount = %d\n",
__func__, __LINE__, bytecount);
/mnt/data/adahl/src/u-boot/drivers/fpga/virtex2.c:25:37: note: in definition of macro ‘PRINTF’
#define PRINTF(fmt, args...) printf(fmt, ##args)
/mnt/data/adahl/src/u-boot/drivers/fpga/virtex2.c: In function ‘virtex2_ss_load’:
/mnt/data/adahl/src/u-boot/drivers/fpga/virtex2.c:468:12: warning: format ‘%d’ expects argument of type ‘int’, but argument 4 has type ‘size_t’ {aka ‘long unsigned int’} [-Wformat=]
Link: https://lore.kernel.org/r/20221007122003.11239-5-ada@thorsis.com
The additional comma messes up the arguments.
CC drivers/fpga/spartan3.o
/mnt/data/adahl/src/u-boot/drivers/fpga/spartan3.c: In function ‘spartan3_sp_load’:
/mnt/data/adahl/src/u-boot/drivers/fpga/spartan3.c:118:11: warning: too many arguments for format [-Wformat-extra-args]
PRINTF ("%s: Function Table:\n"
/mnt/data/adahl/src/u-boot/drivers/fpga/spartan3.c:18:37: note: in definition of macro ‘PRINTF’
#define PRINTF(fmt,args...) printf (fmt ,##args)
Fixes: 875c78934ee2 ("Add Xilinx Spartan3 family FPGA support Patch by Kurt Stremerch, 14 February 2005")
Link: https://lore.kernel.org/r/20221007122003.11239-4-ada@thorsis.com
That extra comma messes up format arguments.
CC drivers/fpga/spartan2.o
/mnt/data/adahl/src/u-boot/drivers/fpga/spartan2.c: In function ‘spartan2_sp_load’:
/mnt/data/adahl/src/u-boot/drivers/fpga/spartan2.c:112:11: warning: too many arguments for format [-Wformat-extra-args]
/mnt/data/adahl/src/u-boot/drivers/fpga/spartan2.c:12:37: note: in definition of macro ‘PRINTF’
/mnt/data/adahl/src/u-boot/drivers/fpga/spartan3.c:117:11: warning: too many arguments for format [-Wformat-extra-args]
/mnt/data/adahl/src/u-boot/drivers/fpga/spartan3.c:17:37: note: in definition of macro ‘PRINTF’
Fixes: e221174377d7 ("Initial revision")
Link: https://lore.kernel.org/r/20221007122003.11239-3-ada@thorsis.com
Those drivers could not be built anymore without those options present.
Link: https://lore.kernel.org/r/20221007122003.11239-2-ada@thorsis.com
For future DM based FPGA drivers and for now to have a meaningful
logging class for old FPGA drivers.
Suggested-by: Michal Simek <michal.simek@amd.com>
Suggested-by: Simon Glass <sjg@chromium.org>
Signed-off-by: Alexander Dahl <post@lespocky.de>
Link: https://lore.kernel.org/r/20220930120430.42307-2-post@lespocky.de
This is not needed and we should avoid typedefs. Use the struct instead
and rename it to indicate that it really is a legacy struct.
Globally replace all occurances of WATCHDOG_RESET() with schedule(),
which handles the HW_WATCHDOG functionality and the cyclic
infrastructure.
Tested-by: Tom Rini <trini@konsulko.com> [am335x_evm, mx6cuboxi, rpi_3,dra7xx_evm, pine64_plus, am65x_evm, j721e_evm]
The drivers informs the user that a post config was not run after FPGA
configuration. This message is unnecessary in SPL because the
ps7_post_config function is called via spl_board_prepare_for_boot
function before jump_to_image_no_args function from board_init_r
function.
Signed-off-by: Stefan Herbrechtsmeier <stefan.herbrechtsmeier@weidmueller.com>
Link: https://lore.kernel.org/r/20220808145331.24723-1-stefan.herbrechtsmeier-oss@weidmueller.com
Add supporting new compatible string "u-boot,zynqmp-fpga-enc" to
handle loading encrypted bitfiles.
This feature requires encrypted FSBL, as according to UG1085:
"The CSU automatically locks out the AES key, stored in either BBRAM
or eFUSEs, as a key source to the AES engine if the FSBL is not
encrypted. This prevents using the BBRAM or eFUSE as the key source
to the AES engine during run-time applications."
Signed-off-by: Adrian Fiergolski <adrian.fiergolski@fastree3d.com>
Co-developed-by: Oleksandr Suvorov <oleksandr.suvorov@foundries.io>
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@foundries.io>
Tested-by: Adrian Fiergolski <adrian.fiergolski@fastree3d.com>
Link: https://lore.kernel.org/r/20220722141614.297383-14-oleksandr.suvorov@foundries.io
Add supporting new compatible string "u-boot,zynqmp-fpga-ddrauth" to
handle loading authenticated images (DDR).
Based on solution by Jorge Ramirez-Ortiz <jorge@foundries.io>
Tested-by: Ricardo Salveti <ricardo@foundries.io>
Link: https://lore.kernel.org/r/20220722141614.297383-13-oleksandr.suvorov@foundries.io
Check whether the FPGA ZynqMP driver supports the given bitstream
image type.
Link: https://lore.kernel.org/r/20220722141614.297383-12-oleksandr.suvorov@foundries.io
Reduce the function code by calling xilinx_pm_request() once only.
Use the same variable bsize_req to store either bstream size in bytes
or an address of bstream size according to a type required by the
firmware version. Remove obsolete debug().
Link: https://lore.kernel.org/r/20220722141614.297383-11-oleksandr.suvorov@foundries.io
These flags may be used to check whether an FPGA driver is able to
load a particular FPGA bitstream image.
Link: https://lore.kernel.org/r/20220722141614.297383-10-oleksandr.suvorov@foundries.io
Add a "compatible" string to binary flag converter, which uses
a callback str2flag() of given FPGA driver if available.
Link: https://lore.kernel.org/r/20220722141614.297383-8-oleksandr.suvorov@foundries.io
Link: https://lore.kernel.org/r/20220722141614.297383-7-oleksandr.suvorov@foundries.io
This flag is used to check whether a Xilinx FPGA driver is able to
Link: https://lore.kernel.org/r/20220722141614.297383-6-oleksandr.suvorov@foundries.io
Add a call to convert FPGA "compatible" string to a binary flag.
Link: https://lore.kernel.org/r/20220722141614.297383-5-oleksandr.suvorov@foundries.io
It allows using this feature without enabling the "fpga loads"
command.
Co-developed-by: Adrian Fiergolski <adrian.fiergolski@fastree3d.com>
Link: https://lore.kernel.org/r/20220722141614.297383-2-oleksandr.suvorov@foundries.io
This converts the following to Kconfig: SYS_FPGA_PROG_FEEDBACK
Link: https://lore.kernel.org/r/20220721133122.32428-3-ada@thorsis.com
After commit 8cca60a2cbf2 ("Kconfig: Remove some symbols from the
whitelist") downstream builds failed for boards setting this in
include/configs/…
Link: https://lore.kernel.org/r/20220721133122.32428-2-ada@thorsis.com
For some reason, on the Mercury+ AA1 module, calling
fpgamgr_wait_early_user_mode immediately after writing the peripheral
bitstream leaves the fpga in a broken state (ddr calibration hangs).
Adding a delay before the first sync word is written seems to fix this.
Inspecting the fpgamgr registers before and after the delay,
imgcfg_FifoEmpty is the only bit that changes. Waiting for this bit
(instead of a hardcoded delay) also fixes the issue.
Signed-off-by: Paweł Anikiel <pan@semihalf.com>
Apply some optimizations to speed up bitstream loading
(both for full and split periph/core bitstreams):
* Change the size of the first fs read, so that all the subsequent
reads are aligned to a specific value (called MAX_FIRST_LOAD_SIZE).
This value was chosen so that in subsequent reads the fat fs driver
doesn't have to allocate a temporary buffer in get_contents
(assuming 8KiB clusters).
* Change the buffer size to a larger value when reading to ddr
(but not too large, because large transfers cause a stack overflow
in the dwmmc driver).
CONFIG_FPGA_STRATIX_V
Double peripheral RBF configuration are needed on some devices or boards
to stabilize the IO configuration system.
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
Signed-off-by: Sin Hui Kho <sin.hui.kho@intel.com>
Reviewed-by: Tien Fong Chee <tien.fong.chee@intel.com>
Create common macro TARGET_SOCFPGA_SOC64 for Stratix10 and Agilex.
Signed-off-by: Siew Chin Lim <elly.siew.chin.lim@intel.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze
Xilinx changes for v2021.04-rc3
qspi:
- Support for dual/quad mode
- Fix speed handling
clk:
- Add clock enable function for zynq/zynqmp/versal
gem:
- Enable clock for Versal
- Fix error path
- Fix mdio deregistration path
fpga:
- Fix buffer alignment for ZynqMP
xilinx:
- Fix reset reason clearing in ZynqMP
- Show silicon version in SPL for Zynq/ZynqMP
- Fix DTB selection for ZynqMP
- Rename zc1275 to zcu1275 to match DT name
Due to pointer arithmetic, "sizeof(u32) * ARCH_DMA_MINALIGN" is
subtracted. It seems that the original intention was to just subtract
ARCH_DMA_MINALIGN. Fix it.
Signed-off-by: Michael Walle <michael@walle.cc>
At present this function does not accept a size for the FIT. This means
that it must be read from the FIT itself, introducing potential security
risk. Update the function to include a size parameter, which can be
invalid, in which case fit_check_format() calculates it.
For now no callers pass the size, but this can be updated later.
Also adjust the return value to an error code so that all the different
types of problems can be distinguished by the user.
Reported-by: Bruce Monroe <bruce.monroe@intel.com>
Reported-by: Arie Haenel <arie.haenel@intel.com>
Reported-by: Julien Lenoir <julien.lenoir@intel.com>
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
In non-secure mode (EL2), FPGA reconfiguration driver calls the
SMC/PSCI services provided by ATF to configure the FPGA.
Signed-off-by: Chee Hong Ang <chee.hong.ang@intel.com>
Enable FPGA full reconfiguration support with Intel FPGA SDM
Mailbox driver for Agilex.
Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com>
Ensure watchdog reset is not triggered if the fpga
reconfiguration is taking too long.
Rename Stratix10 FPGA driver to Intel FPGA SDM Mailbox driver
because it is using generic SDM (Secure Device Manager) Mailbox
interface shared by other platform (e.g. Agilex) as well.
if conditions should match.
Fixes: a18d09ea384f ("fpga: zynqmp: Add secure bitstream loading for ZynqMP")
