path: root/drivers/fpga/zynqpl.c
2014-11-23fs: API changes enabling extra parameter to return size of type loff_tSuriyan Ramasami
The sandbox/ext4/fat/generic fs commands do not gracefully deal with files greater than 2GB. Negative values are returned in such cases. To handle this, the fs functions have been modified to take an additional parameter of type "* loff_t" which is then populated. The return value of the fs functions are used only for error conditions. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Update board/gdsys/p1022/controlcenterd-id.c, drivers/fpga/zynqpl.c for changes] Signed-off-by: Tom Rini <trini@ti.com>
2014-05-20fpga: Added support to load bit stream from SD/MMCSiva Durga Prasad Paladugu
Added support to load a bitstream image in chunks by reading it in chunks from SD/MMC. Command format: loadfs [dev] [address] [image size] [blocksize] <interface> [<dev[:part]>] <filename> Example: fpga loadfs 0 1000000 3dbafc 4000 mmc 0 fpga.bin Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-20fpga: zynqpl: Clean partial bitstream handlingMichal Simek
Do not do partial bitstream detection based on bitstream size and use bitstream_type argument which is passed from the fpga core. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-20fpga: Define bitstream type based on command selectionMichal Simek
Clean up partial, full and compressed bitstream handling. U-Boot supports full bitstream loading and partial based on detection which is not 100% correct. Extending fpga_load/fpga_loadbitstream() with one more argument which stores bitstream type. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: zynq: Use helper function zynq_validate_bitstreamSiva Durga Prasad Paladugu
Use helper function zynq_validate_bitstream so that the code can be reused easily for different cases of dma transfer. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: zynq: Use helper functions for zynq dmaSiva Durga Prasad Paladugu
Use zynq_dma_xfer_init, zynq_align_dma_buffer, zynq_dma_transfer helper function performing dma transfers so that the code can be reused easily for different cases of dma transfer. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: zynq: Remove sparse warningsMichal Simek
Warnings: drivers/fpga/zynqpl.c:150:32: warning: Using plain integer as NULL pointer drivers/fpga/zynqpl.c:152:16: warning: Using plain integer as NULL pointer Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: xilinx: Simplify load/dump/info function handlingMichal Simek
Connect FPGA version with appropriate operations to remove huge switch-cases for every FPGA family. Tested on Zynq. Spartan2/Spartan3/Virtex2 just compile test. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: xilinx: Avoid CamelCase for in Xilinx_descMichal Simek
No functional changes. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-03-04sizes.h - consolidate for all architecturesAlexey Brodkin
Copied from Linux sources "include/linux/sizes.h" commit 413541dd66d51f791a0b169d9b9014e4f56be13c Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Tom Rini <trini@ti.com> Acked-by: Stefan Roese <sr@denx.de> [trini: Add bcm Kona platforms to the patch] Signed-off-by: Tom Rini <trini@ti.com>
2014-02-06fpga: zynq: Correct fpga load when buf is not alignedNovasys Ingenierie
When ARCH_DMA_MINALIGN is greater than header size of the bit file, and buf is not aligned, new_buf address became greater then buf_start address and the load_word loop corrupts bit file data. A work around is to decrease new_buf of ARCH_DMA_MINALIGN, it might corrupt data before buf but permits to load correctly. Signed-off-by: Stany MARCEL <smarcel@novasys-ingenierie.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-11-06fpga: zynqpl: Do not place bitstream below 1MBMichal Simek
DMA doesn't work when src is placed below 1MB limit. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-11-06fpga: zynqpl: Add dcache flush supportJagannadha Sutradharudu Teki
Buffers must be cache and dma aligned. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-08-12fpga: zynqpl: Clear loopback mode during device initSoren Brinkmann
Some versions of the Zynq first stage boot loader enable PCAP loopback during boot regardless of whether or not the boot image includes PL configuration. This behavior only appears in certain boot modes (notably QSPI boot). Attempting to configure the PL with the loopback bit set will result in timeouts and will prevent successful configuration. In order to avoid this problem, and to avoid dependency on the version of the FSBL used to boot the system, ensure that the loopback enable bit is cleared when loading the driver. Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-08-12fpga: zynqpl: Add support for zc7100 device.Michal Simek
- Add support for zc7100 device. - FPGA programming on few of the SOC(zc7100) takes more than 1sec, hence increased the program time by 4sec to sync' all soc's. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-05-06fpga: zynq: Add support for loading bitstreamMichal Simek
Devcfg device requires to load bitstream in binary format. But u-boot also has an option for loading bitstream in bit format. Let's handle both cases by zynqpl driver. Also add suport for loading partial bitstreams. The first driver version was done by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
