path: root/drivers/fpga/zynqpl.c
2020-06-24fpga: zynqpl: Flush dcache only for non-bitstream dataT Karthik Reddy
In case of aes decryption destination address range must be flushed before transferring decrypted data to destination. Signed-off-by: T Karthik Reddy <t.karthik.reddy@xilinx.com> Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-06-24fpga: zynqpl: Check if aes engine is enabledIbai Erkiaga
AES engine cannot be used if has not been enabled at boot time with an encrypted boot image. Signed-off-by: Ibai Erkiaga <ibai.erkiaga-elorza@xilinx.com> Acked-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-06-24fpga: zynqpl: Check fpga config completionT Karthik Reddy
This patch checks fpga config completion when a bitstream is loaded into PL. Signed-off-by: T Karthik Reddy <t.karthik.reddy@xilinx.com> Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-06-24fpga: zynqpl: Correct PL bitstream loading sequence for zynqaesSiva Durga Prasad Paladugu
Correct the PL bitstream loading sequence for zynqaes command by clearing the loaded PL bitstream before loading the new encrypted bitstream using the zynq aes command. This was done by setting the PROG_B same as in case of fpgaload commands. This patch fixes the issue of loading the encrypted PL bitstream onto the PL in which a bitstream has already been loaded successfully. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-05-18common: Drop linux/delay.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-02common: Move some cache and MMU functions out of common.hSimon Glass
These functions belong in cpu_func.h. Another option would be cache.h but that code uses driver model and we have not moved these cache functions to use driver model. Since they are CPU-related it seems reasonable to put them here. Move them over. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-04-16arm: zynq: Add an info message about post configSiva Durga Prasad Paladugu
Post configuration cant be run at u-boot as u-boot didn't has any info about the design.So,this patch adds an info message that post config was not run and needs to be run manually if needed. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-04-16fpga: Replace char * with const char * for filenameTien Fong Chee
Ensure the string for filename is always constant, otherwise it can be corrupted by the writing. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19drivers: fpga: zynqpl: fix compilation with SPLLuis Araneda
Disable the use of function zynq_loadfs when compiling the driver for the SPL, as the following filesystem functions are not found by the linker: - fs_set_blk_dev - fs_read - fs_set_blk_dev - fs_read - fs_read Signed-off-by: Luis Araneda <luaraneda@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-19xilinx: zynq: Add support to secure imagesSiva Durga Prasad Paladugu
This patch basically adds two new commands for loadig secure images. 1. zynq rsa adds support to load secure image which can be both authenticated or encrypted or both authenticated and encrypted image in xilinx bootimage(BOOT.bin) format. 2. zynq aes command adds support to decrypt and load encrypted image back to DDR as per destination address. The image has to be encrypted using xilinx bootgen tool and to get only the encrypted image from tool use -split option while invoking bootgen. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09fpga: zynq: Add delay after PCFG_PROG_B changeSiva Durga Prasad Paladugu
There is delay needed after PCFG_PROGB change if AES key source is efuse. This fixes the issue of encrypted bitstream loading with AES efuse as key source. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-01-10fpga: zynqmp: Remove empty functionsMichal Simek
Xilinx core files will take care about it. There is no need to have these functions because they do nothing. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-11-19Move console definitions into a new console.h fileSimon Glass
The console includes a global variable and several functions that are only used by a small subset of U-Boot files. Before adding more functions, move the definitions into their own header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-23fs: API changes enabling extra parameter to return size of type loff_tSuriyan Ramasami
The sandbox/ext4/fat/generic fs commands do not gracefully deal with files greater than 2GB. Negative values are returned in such cases. To handle this, the fs functions have been modified to take an additional parameter of type "* loff_t" which is then populated. The return value of the fs functions are used only for error conditions. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Update board/gdsys/p1022/controlcenterd-id.c, drivers/fpga/zynqpl.c for changes] Signed-off-by: Tom Rini <trini@ti.com>
2014-05-20fpga: Added support to load bit stream from SD/MMCSiva Durga Prasad Paladugu
Added support to load a bitstream image in chunks by reading it in chunks from SD/MMC. Command format: loadfs [dev] [address] [image size] [blocksize] <interface> [<dev[:part]>] <filename> Example: fpga loadfs 0 1000000 3dbafc 4000 mmc 0 fpga.bin Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-20fpga: zynqpl: Clean partial bitstream handlingMichal Simek
Do not do partial bitstream detection based on bitstream size and use bitstream_type argument which is passed from the fpga core. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-20fpga: Define bitstream type based on command selectionMichal Simek
Clean up partial, full and compressed bitstream handling. U-Boot supports full bitstream loading and partial based on detection which is not 100% correct. Extending fpga_load/fpga_loadbitstream() with one more argument which stores bitstream type. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: zynq: Use helper function zynq_validate_bitstreamSiva Durga Prasad Paladugu
Use helper function zynq_validate_bitstream so that the code can be reused easily for different cases of dma transfer. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: zynq: Use helper functions for zynq dmaSiva Durga Prasad Paladugu
Use zynq_dma_xfer_init, zynq_align_dma_buffer, zynq_dma_transfer helper function performing dma transfers so that the code can be reused easily for different cases of dma transfer. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: zynq: Remove sparse warningsMichal Simek
Warnings: drivers/fpga/zynqpl.c:150:32: warning: Using plain integer as NULL pointer drivers/fpga/zynqpl.c:152:16: warning: Using plain integer as NULL pointer Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: xilinx: Simplify load/dump/info function handlingMichal Simek
Connect FPGA version with appropriate operations to remove huge switch-cases for every FPGA family. Tested on Zynq. Spartan2/Spartan3/Virtex2 just compile test. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: xilinx: Avoid CamelCase for in Xilinx_descMichal Simek
No functional changes. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-03-04sizes.h - consolidate for all architecturesAlexey Brodkin
Copied from Linux sources "include/linux/sizes.h" commit 413541dd66d51f791a0b169d9b9014e4f56be13c Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Tom Rini <trini@ti.com> Acked-by: Stefan Roese <sr@denx.de> [trini: Add bcm Kona platforms to the patch] Signed-off-by: Tom Rini <trini@ti.com>
2014-02-06fpga: zynq: Correct fpga load when buf is not alignedNovasys Ingenierie
When ARCH_DMA_MINALIGN is greater than header size of the bit file, and buf is not aligned, new_buf address became greater then buf_start address and the load_word loop corrupts bit file data. A work around is to decrease new_buf of ARCH_DMA_MINALIGN, it might corrupt data before buf but permits to load correctly. Signed-off-by: Stany MARCEL <smarcel@novasys-ingenierie.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-11-06fpga: zynqpl: Do not place bitstream below 1MBMichal Simek
DMA doesn't work when src is placed below 1MB limit. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-11-06fpga: zynqpl: Add dcache flush supportJagannadha Sutradharudu Teki
Buffers must be cache and dma aligned. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-08-12fpga: zynqpl: Clear loopback mode during device initSoren Brinkmann
Some versions of the Zynq first stage boot loader enable PCAP loopback during boot regardless of whether or not the boot image includes PL configuration. This behavior only appears in certain boot modes (notably QSPI boot). Attempting to configure the PL with the loopback bit set will result in timeouts and will prevent successful configuration. In order to avoid this problem, and to avoid dependency on the version of the FSBL used to boot the system, ensure that the loopback enable bit is cleared when loading the driver. Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-08-12fpga: zynqpl: Add support for zc7100 device.Michal Simek
- Add support for zc7100 device. - FPGA programming on few of the SOC(zc7100) takes more than 1sec, hence increased the program time by 4sec to sync' all soc's. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-05-06fpga: zynq: Add support for loading bitstreamMichal Simek
Devcfg device requires to load bitstream in binary format. But u-boot also has an option for loading bitstream in bit format. Let's handle both cases by zynqpl driver. Also add suport for loading partial bitstreams. The first driver version was done by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
