path: root/drivers/fpga/xilinx.c
2016-01-27fpga: xilinx: Check for substring in device ID validationSiva Durga Prasad Paladugu
Check for substrings in deviceID validation check so that it can support xa bitstreams also. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-01-21fpga: xilinx: Show fpga info if definedMichal Simek
Show fpga_op->info even if desc->iface_fns is not defined. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-01-21fpga: xilinx: Check if fpga operations are definedMichal Simek
Ensure that operations are correctly setup. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-06-11m68k: Fix warnings with gcc 4.6Simon Glass
Most of the warnings seem to be related to using 'int' for size_t. Change this and fix up the remaining warnings and problems. For bootm, the warning was masked by others, and there is an actual bug in the code. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-20fpga: Added support to load bit stream from SD/MMCSiva Durga Prasad Paladugu
Added support to load a bitstream image in chunks by reading it in chunks from SD/MMC. Command format: loadfs [dev] [address] [image size] [blocksize] <interface> [<dev[:part]>] <filename> Example: fpga loadfs 0 1000000 3dbafc 4000 mmc 0 fpga.bin Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-20fpga: Define bitstream type based on command selectionMichal Simek
Clean up partial, full and compressed bitstream handling. U-Boot supports full bitstream loading and partial based on detection which is not 100% correct. Extending fpga_load/fpga_loadbitstream() with one more argument which stores bitstream type. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: xilinx: Simplify load/dump/info function handlingMichal Simek
Connect FPGA version with appropriate operations to remove huge switch-cases for every FPGA family. Tested on Zynq. Spartan2/Spartan3/Virtex2 just compile test. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: xilinx: Avoid CamelCase for in Xilinx_descMichal Simek
No functional changes. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: virtex2: Avoid CamelCaseMichal Simek
2014-05-13fpga: spartan3: Avoid CamelCaseMichal Simek
2014-05-13fpga: spartan2: Avoid CamelCaseMichal Simek
2013-05-06fpga: Check device name against bitstream nameMichal Simek
Ensure that wrong bitstream won't be loaded to current device. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-05-06fpga: zynq: Add support for loading bitstreamMichal Simek
Devcfg device requires to load bitstream in binary format. But u-boot also has an option for loading bitstream in bit format. Let's handle both cases by zynqpl driver. Also add suport for loading partial bitstreams. The first driver version was done by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-05-06fpga: Change the first parameter in fpga_loadbitstreamMichal Simek
All fpga functions use devnum as int. Only fpga_loadbitstream is using it as unsinged long dev. This patch synchronize it. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-05-06cmd: fpga: Move fpga_loadbitstream to fpga.cMichal Simek
In bitstream decoding you can directly check device which you want to load and in fpga.c are fpga_validate and fpga_dev_info functions which should be used for it. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-01Consolidate bool typeYork Sun
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99. All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0. Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files. Signed-off-by: York Sun <yorksun@freescale.com>
2011-08-01fpga: constify to fix build warningWolfgang Denk
Fix compiler warning: cmd_fpga.c:318: warning: passing argument 3 of 'fit_image_get_data' from incompatible pointer type Adding the needed 'const' here entails a whole bunch of additonal changes all over the FPGA code. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andre Schwarz <andre.schwarz@matrix-vision.de> Cc: Murray Jensen <Murray.Jensen@csiro.au> Acked-by: Andre Schwarz<andre.schwarz@matrix-vision.de>
2009-10-03fpga: Remove relocation fixupsPeter Tyser
PPC boards are the only users of the current FPGA code which is littered with manual relocation fixups. Now that proper relocation is supported for PPC boards, remove FPGA manual relocation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-05FPGA: move fpga drivers to drivers/fpgaJean-Christophe PLAGNIOL-VILLARD
