path: root/drivers/fpga/socfpga.c
2016-01-16arm: socfpga: set the fpga global bit to disable HPS to FPGA signalsDinh Nguyen
We should be setting the FPGA Interface Group global bit that will correctly disable all interfaces between the FPGA and HPS. Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-08-08arm: socfpga: Fix FPGA bitstream programming routineMarek Vasut
In case the FPGA bitstream is aligned to 4 bytes, skip the part of the assembler which handles unaligned bitstream. Otherwise, that part will loop indefinitelly. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2014-10-06arm: socfpga: fpga: Add SoCFPGA FPGA programming interfacePavel Machek
Add code necessary to program the FPGA part of SoCFPGA from U-Boot with an RBF blob. This patch also integrates the code into the FPGA driver framework in U-Boot so it can be used via the 'fpga' command. Signed-off-by: Pavel Machek <pavel@denx.de> Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> V2: Move the not-CPU specific stuff into drivers/fpga/ and base this on the cleaned up altera FPGA support.
