path: root/drivers/firmware
2019-05-03firmware: ti_sci: Always request response from firmwareAndrew F. Davis
TI-SCI firmware will only respond to messages when the TI_SCI_FLAG_REQ_ACK_ON_PROCESSED flag is set. Most messages already do this, set this for the ones that do not. Signed-off-by: Andrew F. Davis <afd@ti.com> Tested-by: Alejandro Hernandez <ajhernandez@ti.com> Acked-by: Nishanth Menon <nm@ti.com>
2019-05-03firmware: ti_sci: Fix TISCI mailbox receive timeout handlingAndreas Dannenberg
An earlier commit converted the TISCI receive timeouts to be specified in ms rather than us however it failed to take this change into account when passing the actual timeout to be used when invoking the mailbox receive API. This leads to the actual timeout to be 1,000 times shorter than expected and as a result certain TISCI operations would fail. Fix the issue by converting the timeout declared in ms to us on the fly as expected by the respective API. Fixes: fd6b40b1ba20 ("firmware: ti_sci: Add support for NAVSS resource management") Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-04-26firmware: ti_sci: Modify auth_boot TI-SCI API to match new versionAndrew F. Davis
SYSFW version 2019.01 introduces a slightly modified version of this API, add support for it here. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Andreas Dannenberg <dannenberg@ti.com>
2019-04-26firmware: ti_sci: Add support for firewall managementAndrew F. Davis
TI-SCI message protocol provides support for controlling the firewall configurations available in SoC. Introduce support for the set of TI-SCI message protocol APIs that provide us with this capability of controlling firewalls. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Andreas Dannenberg <dannenberg@ti.com>
2019-04-12firmware: Add support for querying msmc memoryLokesh Vutla
DMSC can use certain amount of msmc memory available in the system. Also certain part of msmc memory can be marked as L3 cache using board config. But users might not know what size is being used and the remaining available msmc memory. In order to fix this TISCI protocol provides a messages that can query the available msmc memory in the system. Add support for this message. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-04-11firmware: ti_sci: Add support for NAVSS resource managementGrygorii Strashko
Texas Instruments' System Control Interface (TI-SCI) Message Protocol abstracts management of NAVSS resources, like PSI-L pairing and unpairing, UDMAP tx/rx/flow configuration and Rings. This patch adds support for requesting and configuring such resources from TI-SCI firmware. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Vignesh R <vigneshr@ti.com>
2018-12-12firmware: psci: introduce SPL_ARM_PSCI_FWPeng Fan
Introduce a new macro SPL_ARM_PSCI_FW Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2018-12-02efi_loader: PSCI reset and shutdownHeinrich Schuchardt
When an operating system started via bootefi tries to reset or power off this is done by calling the EFI runtime ResetSystem(). On most ARMv8 system the actual reset relies on PSCI. Depending on whether the PSCI firmware resides the hypervisor (EL2) or in the secure monitor (EL3) either an HVC or an SMC command has to be issued. The current implementation always uses SMC. This results in crashes on systems where the PSCI firmware is implemented in the hypervisor, e.g. qemu-arm64_defconfig. The logic to decide which call is needed based on the device tree is already implemented in the PSCI firmware driver. During the EFI runtime the device driver model is not available. But we can minimize code duplication by merging the EFI runtime reset and poweroff code with the PSCI firmware driver. As the same HVC/SMC problem is also evident for the ARMv8 do_poweroff and reset_misc routines let's move them into the same code module. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Sumit Garg <sumit.garg@linaro.org> Tested-by: Sumit Garg <sumit.garg@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-29dm: test: Add "/firmware" node scan testRajan Vaja
Add a test which verifies that all subnodes under "/firmware" nodes are scanned. Signed-off-by: Rajan Vaja <rajan.vaja@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org> Added 'imply FIRMWARE' to sandbox Kconfig to fix test failures, fixed ordering of lines in arch/sandbox/dts/test.dts and test/dm/Makefile, updated #if condition in drivers/firmware/firmware-uclass.c: Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-29firmware: Add FIRMWARE config prompt stringRajan Vaja
There is no prompt string for FIRMWARE config. Without this, FIRMWARE config cannot be enabled through menuconfing or config file. Fix this by adding prompt summary. Signed-off-by: Rajan Vaja <rajan.vaja@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-11dm: firmware: Automatically bind child devicesAndreas Dannenberg
To support scenarios where a firmware device node has subnodes that have their own drivers automatically scan the DT and bind those when the firmware device gets bound. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-11firmware: ti_sci: Add support for processor control servicesLokesh Vutla
TI-SCI message protocol provides support for controlling of various physical cores available in SoC. In order to control which host is capable of controlling a physical processor core, there is a processor access control list that needs to be populated as part of the board configuration data. Introduce support for the set of TI-SCI message protocol apis that provide us with this capability of controlling physical cores. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-11firmware: ti_sci: Add support for reboot core serviceAndreas Dannenberg
Since system controller now has control over SoC power management, it needs to be explicitly requested to reboot the SoC. Add support for it. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2018-09-11firmware: ti_sci: Add support for clock controlLokesh Vutla
In general, we expect to function at a device level of abstraction, however, for proper operation of hardware blocks, many clocks directly supplying the hardware block needs to be queried or configured. Introduce support for the set of SCI message protocol support that provide us with this capability. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2018-09-11firmware: ti_sci: Add support for device controlAndreas Dannenberg
TI-SCI message protocol provides support for management of various hardware entitites within the SoC. Introduce the fundamental device management capability support to the driver protocol as part of this change. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2018-09-11firmware: ti_sci: Add support for board configurationAndreas Dannenberg
TI-SCI message protocol provides support for board configuration to assign resources and other board related operations. Introduce the board configuration capability support to the driver protocol as part of this change. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-11firmware: Add basic support for TI System Control Interface (TI SCI) protocolLokesh Vutla
Texas Instrument's System Control Interface (TI SCI) message protocol is used in Texas Instrument's System on Chip (SoC) such as those in the K3 family AM654 SoC to communicate between various compute processors with a central system controller entity. The TI SCI message protocol provides support for management of various hardware entities within the SoC. Add support driver to allow communication with system controller entity within the SoC using the mailbox client. This is mostly derived from the TI SCI driver in Linux located at drivers/firmware/ti_sci.c. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-12-04drivers: firmware: psci: use pr_* log functions instead of printf()Masahiro Yamada
In Linux, the warning messages are printed out by pr_warn(). We can use Linux-like log functions in tree-wide. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: core: Rename of_device_is_compatible()Simon Glass
The of_ prefix conflicts with the livetree version of this function. Rename it to avoid problems when we add livetree support. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: core: Replace of_offset with accessor (part 2)Simon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Fix up inclusion of common.hSimon Glass
It is good practice to include common.h as the first header. This ensures that required features like the DECLARE_GLOBAL_DATA_PTR macro, configuration options and common types are available. Fix up some files which currently don't do this. This is necessary because driver model will soon start using global data and configuration in the dm/read.h header file, included via dm.h. The gd->fdt_blob value will be used to access the device tree and CONFIG options will be used to determine whether to support inline functions in the header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Use dm.h header when driver mode is usedSimon Glass
This header includes things that are needed to make driver build. Adjust existing users to include that always, even if other dm/ includes are present Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-18sysreset: psci: support system reset in a generic way with PSCIMasahiro Yamada
If the system is running PSCI firmware, the System Reset function (func ID: 0x80000009) is supposed to be handled by PSCI, that is, the SoC/board specific reset implementation should be moved to PSCI. U-Boot should call the PSCI service according to the arm-smccc manner. The arm-smccc is supported on ARMv7 or later. Especially, ARMv8 generation SoCs are likely to run ARM Trusted Firmware BL31. In this case, U-Boot is a non-secure world boot loader, so it should not be able to reset the system directly. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
