path: root/drivers/firmware/firmware-uclass.c
2017-06-01dm: Fix up inclusion of common.hSimon Glass
It is good practice to include common.h as the first header. This ensures that required features like the DECLARE_GLOBAL_DATA_PTR macro, configuration options and common types are available. Fix up some files which currently don't do this. This is necessary because driver model will soon start using global data and configuration in the dm/read.h header file, included via dm.h. The gd->fdt_blob value will be used to access the device tree and CONFIG options will be used to determine whether to support inline functions in the header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Use dm.h header when driver mode is usedSimon Glass
This header includes things that are needed to make driver build. Adjust existing users to include that always, even if other dm/ includes are present Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-18sysreset: psci: support system reset in a generic way with PSCIMasahiro Yamada
If the system is running PSCI firmware, the System Reset function (func ID: 0x80000009) is supposed to be handled by PSCI, that is, the SoC/board specific reset implementation should be moved to PSCI. U-Boot should call the PSCI service according to the arm-smccc manner. The arm-smccc is supported on ARMv7 or later. Especially, ARMv8 generation SoCs are likely to run ARM Trusted Firmware BL31. In this case, U-Boot is a non-secure world boot loader, so it should not be able to reset the system directly. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
