path: root/drivers/dma
2019-05-03dma: ti: k3-udma: Do not touch RT registers before channel configurationPeter Ujfalusi
Upcoming sysfw (2019.03) will not open the channelized firewalls during init, it only going to do so in response to the channel configuration message. Remove the channel state checks done before the channel configuration and move it after the configuration for warning purposes. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com> Reviewed-by: Grygorii Strashko <grygorii.strashko@ti.com>
2019-05-03drivers: dma: ti: k3-udma: Extract packet data only when Meta data is not NULLKeerthy
Currently packet data is wrongly extracted when metadata is NULL. Fix it and negate the if check. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Grygorii Strashko <grygorii.strashko@ti.com> Reviewed-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
2019-04-13Merge tag 'mips-pull-2019-04-12' of git://git.denx.de/u-boot-mipsTom Rini
- mt76xx: add USB support, small fixes - ath79: small fixes, add support for QCA9563 SoC and AP152 reference board - mscc: small fixes, add network support for JR2 and ServalT SoCs - bmips: small fixes, enable more drivers for ARM specific BCM6858 and BCM63158 SoCs - MIPS: fix redundant relocation of initrd images
2019-04-12dma: bcm6348: check if driver is enabled before send/recvÁlvaro Fernández Rojas
This patch prevents errors when running tftpput. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
2019-04-11dma: ti: add driver to K3 UDMAVignesh R
The UDMA-P is intended to perform similar (but significantly upgraded) functions as the packet-oriented DMA used on previous SoC devices. The UDMA-P module supports the transmission and reception of various packet types. The UDMA-P also supports acting as both a UTC and UDMA-C for its internal channels. Channels in the UDMA-P can be configured to be either Packet-Based or Third-Party channels on a channel by channel basis. The initial driver supports: - MEM_TO_MEM (TR mode) - DEV_TO_MEM (Packet mode) - MEM_TO_DEV (Packet mode) Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Vignesh R <vigneshr@ti.com>
2018-12-19dma: add bcm6348-iudma supportÁlvaro Fernández Rojas
BCM6348 IUDMA controller is present on multiple BMIPS (BCM63xx) SoCs. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-12-07test: dma: add dma-uclass testGrygorii Strashko
Add a sandbox DMA driver implementation (provider) and corresponding DM test. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Álvaro Fernández Rojas <noltari@gmail.com>
2018-12-07dma: add channels supportÁlvaro Fernández Rojas
This adds channels support for dma controllers that have multiple channels which can transfer data to/from different devices (enet, usb...). DMA channle API: dma_get_by_index() dma_get_by_name() dma_request() dma_free() dma_enable() dma_disable() dma_prepare_rcv_buf() dma_receive() dma_send() Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> [grygorii.strashko@ti.com: drop unused dma_get_by_index_platdata(), add metadata to send/receive ops, add dma_prepare_rcv_buf(), minor clean up] Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-07dma: move dma_ops to dma-uclass.hÁlvaro Fernández Rojas
Move dma_ops to a separate header file, following other uclass implementations. While doing so, this patch also improves dma_ops documentation. Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-08Convert CONFIG_APBH_DMA et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_APBH_DMA CONFIG_APBH_DMA_BURST CONFIG_APBH_DMA_BURST8 Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Stefan Agner <stefan.agner@toradex.com> [trini: Add in MMC as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-19drivers: dma: ti-edma3: add support for memory fillTero Kristo
Add support for simple memory fill operation. With large data sizes it is much faster to use EDMA for memory fill rather than CPU. Signed-off-by: Tero Kristo <t-kristo@ti.com>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-06-01dm: Rename dev_addr..() functionsSimon Glass
These support the flat device tree. We want to use the dev_read_..() prefix for functions that support both flat tree and live tree. So rename the existing functions to avoid confusion. In the end we will have: 1. dev_read_addr...() - works on devices, supports flat/live tree 2. devfdt_get_addr...() - current functions, flat tree only 3. of_get_address() etc. - new functions, live tree only All drivers will be written to use 1. That function will in turn call either 2 or 3 depending on whether the flat or live tree is in use. Note this involves changing some dead code - the imx_lpi2c.c file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Use dm.h header when driver mode is usedSimon Glass
This header includes things that are needed to make driver build. Adjust existing users to include that always, even if other dm/ includes are present Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-23drivers: dma: ti-edma3: convert driver to adopt driver modelMugunthan V N
adopt ti-edma3 driver to device driver model Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-02-23dma: Kconfig: Add TI_EDMA3 entryMugunthan V N
Add TI_EDMA3 entry on Kconfig with help description. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-02-23dm: implement a DMA uclassMugunthan V N
Implement a DMA uclass so that the devices like ethernet, spi, mmc etc can offload the data transfers from/to the device and memory. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-01-24imx: apbh_dma: Update APBH-DMA for MX7DPeng Fan
Update APBH-DMA driver and head files to support i.MX7D Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2015-10-22dma: keystone_nav: Fix linkram sizeVitaly Andrianov
Fix Linkram size. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-08-18dma: lpc32xx: add DMA driverSylvain Lemieux
Incorporate DMA driver from legacy LPCLinux NXP BSP. The files taken from the legacy patch are: - lpc32xx DMA driver - lpc3250 header file DMA registers definition. The legacy driver was updated and clean-up as part of the integration with the latest u-boot. Signed-off-by: Sylvain Lemieux <slemieux@tycoint.com> Acked-by: Marek Vasut <marex@denx.de> Tested-by: Vladimir Zapolskiy <vz@mleia.com>
2015-08-17dma: ti-edma3: Add helper function to support edma3 transferVignesh R
Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2014-11-06dma: keystone_nav: remove spurious qm_cfg verificationKhoronzhuk, Ivan
The verification qm_cfg existence is done at ksnav_init(). So, there is no need to verify it after initialization. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-10-23dma: ti-edma3: introduce edma3 driverKhoronzhuk, Ivan
The EDMA3 controller’s primary purpose is to service data transfers that you program between two memory-mapped slave endpoints on the device. Typical usage includes, but is not limited to the following: - Servicing software-driven paging transfers (e.g., transfers from external memory, such as SDRAM to internal device memory, such as DSP L2 SRAM) - Servicing event-driven peripherals, such as a serial port - Performing sorting or sub-frame extraction of various data structures - Offloading data transfers from the main device DSP(s) - See the device-specific data manual for specific peripherals that are accessible via the EDMA3 controller Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-23dma: keystone_nav: generalize driver usageKhoronzhuk, Ivan
The keystone_nav driver is general driver intended to be used for working with queue manager and pktdma for different IPs like NETCP, AIF, FFTC, etc. So the it's API shouldn't be named like it works only with one of them, it should be general names. The names with prefix like netcp_* rather do for drivers/net/keystone_net.c driver. So it's good to generalize this driver to be used for different IP's and delete confusion with real NETCP driver. The current netcp_* functions of keystone navigator can be used for other settings of pktdma, not only for NETCP. The API of this driver is used by the keystone_net driver to work with NETCP, so net driver also should be corrected. For convenience collect pkdma configurations in drivers/dma/keystone_nav_cfg.c. Acked-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-23dma: keystone_nav: move keystone_nav driver to driver/dma/Khoronzhuk, Ivan
The keystone_nav is used by drivers/net/keystone_net.c driver to send and receive packets, but currently it's placed at keystone arch sources. So it should be in the drivers directory also. It's separate driver that can be used for sending and receiving pktdma packets by others drivers also. This patch just move this driver to appropriate directory and doesn't add any functional changes. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-09-24cosmetic: replace MIN, MAX with min, maxMasahiro Yamada
The macro MIN, MAX is defined as the aliase of min, max, respectively. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24kconfig: add blank Kconfig filesMasahiro Yamada
This would be useful to start moving various config options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-08-09omap: clean-up dead configsMasahiro Yamada
The following configs are not defined at all. - CONFIG_OMAP1510 - CONFIG_OMAP_1510P1 - CONFIG_OMAP_SX1 - CONFIG_OMAP3_DMA - CONFIG_OMAP3_ZOOM2 - CONFIG_OMAP_INNOVATOR Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com>
2013-10-31drivers: convert makefiles to Kbuild styleMasahiro Yamada
2013-08-09dma: apbh: Add special circular mode for LCDMarek Vasut
Add special function that executes a specially crafted circular DMA descriptor. The function doesn't wait for the descriptor to finish the transfer, since the descritor never finishes. This is useful when operating a SmartLCD through the LCDIF interface, as the LCDIF does not give us any means to have continuous refresh of the SmartLCD. Instead, the RUN bit in the LCDIF CTRL register must be triggered manually. This can be worked around by starting an DMA transfer which continuously sets the RUN bit. This function allows starting exactly such transfer. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-04-22dma: Add i.MX6 support to drivers/dma/apbh_dma.cStefan Roese
This will be used by the i.MX6 NAND support. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2013-04-22imx: Move some header files from arch-mxs to imx-commonStefan Roese
The following headers are moved to a i.MX common location: - regs-common.h - regs-apbh.h - regs-bch.h - regs-gpmi.h - dma.h This way this header can be re-used also by other i.MX platforms. For example the i.MX6 which will need it for the upcoming NAND support. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2013-01-28mxs: dma: Fix APBH DMA driver for MX23Marek Vasut
The MX23 has less channels for the APBH DMA, sligtly different register layout and some bits in those registers are placed differently. Reflect this in the driver. This patch fixes MMC/DMA issue on MX23. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2012-09-01MX28: DMA: Prolong the DMA timeoutMarek Vasut
Load from SPI flash can create a long DMA chain, which can take long time to transfer. Change the DMA timeout to roughly 10s to prevent such long chains misreporting errors. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <festevam@gmail.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2012-09-01mxs: Convert sys_proto.h prefixes to 'mxs'Otavio Salvador
The sys_proto.h functions (except the boot modes) are compatible with i.MX233 and i.MX28 so we use 'mxs' prefix for its methods. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2012-09-01mxs: prefix register structs with 'mxs' prefixOtavio Salvador
2012-04-16DMA: Split the APBH DMA init into block and channel initMarek Vasut
This fixes the issue where mxs_dma_init() was called either twice or never, without introducing any new init hooks. The idea is to allow each and every device using the APBH DMA block to configure and request only the channels it uses, instead of making it call init for all the channels as is now. The common DMA block init part, which only configures the block, is then called from CPUs arch_cpu_init() call. NOTE: This patch depends on: http://patchwork.ozlabs.org/patch/150957/ Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-03-29i.MX28: Add cache support into the APBH DMA driverMarek Vasut
The desc_append() now flushes descriptors into RAM. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2011-12-06MXS: Add static annotations to dma driverMarek Vasut
Some functions were internal to the apbh dma driver, so annotate them static. Some of the functions weren't used at all so drop them. This makes the U-Boot binary smaller by about 1500 bytes. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-12-06apbh_dma: return error value on timeoutWolfram Sang
When a timeout occurs, the return value is prepared but never returned. Fix that. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Marek Vasut <marek.vasut@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-11-11iMX28: Add APBH DMA driverMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-10-27omap3: Add interface for omap3 DMASimon Schwarz
Adds an interface to use the OMAP3 DMA. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-07-06fsl_dma: fix support for 83xx DMA engineIra W. Snyder
Commit 359ec4931944adb885882deb9b781e4095eabc94 broke support for the Freescale DMA engine on the 83xx parts. This is due to using registers which do not exist on 83xx. Remove the attribute register accesses from the 83xx build. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Cc: York Sun <yorksun@freescale.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-08-31powerpc/8xxx: Fix dma for 36bit addressingYork Sun
Use more bits to support 36-bit addressing Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
