path: root/drivers/dma
2012-04-16DMA: Split the APBH DMA init into block and channel initMarek Vasut
This fixes the issue where mxs_dma_init() was called either twice or never, without introducing any new init hooks. The idea is to allow each and every device using the APBH DMA block to configure and request only the channels it uses, instead of making it call init for all the channels as is now. The common DMA block init part, which only configures the block, is then called from CPUs arch_cpu_init() call. NOTE: This patch depends on: http://patchwork.ozlabs.org/patch/150957/ Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-03-29i.MX28: Add cache support into the APBH DMA driverMarek Vasut
The desc_append() now flushes descriptors into RAM. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2011-12-06MXS: Add static annotations to dma driverMarek Vasut
Some functions were internal to the apbh dma driver, so annotate them static. Some of the functions weren't used at all so drop them. This makes the U-Boot binary smaller by about 1500 bytes. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-12-06apbh_dma: return error value on timeoutWolfram Sang
When a timeout occurs, the return value is prepared but never returned. Fix that. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Marek Vasut <marek.vasut@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-11-11iMX28: Add APBH DMA driverMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-10-27omap3: Add interface for omap3 DMASimon Schwarz
Adds an interface to use the OMAP3 DMA. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-07-06fsl_dma: fix support for 83xx DMA engineIra W. Snyder
Commit 359ec4931944adb885882deb9b781e4095eabc94 broke support for the Freescale DMA engine on the 83xx parts. This is due to using registers which do not exist on 83xx. Remove the attribute register accesses from the 83xx build. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Cc: York Sun <yorksun@freescale.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-08-31powerpc/8xxx: Fix dma for 36bit addressingYork Sun
Use more bits to support 36-bit addressing Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-26ColdFire: Fix compile warning messagesTsiChung Liew
Change %08lX to %08X in board.c. Remove unused variable 'oscillator' in mcf5227x/cpu_init.c and 'scm2' in mcf532x/cpu_init.c. Provide argument type cast in drivers/dma/MCD_dmaApi.c. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-07-0283xx: Add support for fsl_dma driverPeter Tyser
Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Reviewed-by: Ira W. Snyder <iws@ovro.caltech.edu> Tested-by: Ira W. Snyder <iws@ovro.caltech.edu> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-01fsl_dma: Make DMA transactions snoopablePeter Tyser
Make DMA transactions snoopable so that CPUs can keep caches up-to-date. This allows dma transactions to be used for operations such as memory copies without any additional cache control operations. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-01fsl_dma: Break out common memory initialization functionPeter Tyser
2009-07-018xxx: Rename dma_xfer() to dmacpy()Peter Tyser
Also update dmacpy()'s argument order to match memcpy's and use phys_addr_t/phy_size_t for address/size arguments Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-01fsl_dma: Fix Channel Start bug in dma_check()Peter Tyser
The Channel Start (CS) bit in the Mode Register (MR) should actually be cleared as the comment in the code suggests. Previously, CS was being set, not cleared. Assuming normal operation of the DMA engine, this change shouldn't have any real affect. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-01fsl_dma: Add support for arbitrarily large transfersPeter Tyser
Support DMA transfers larger than the DMA controller's limit of (2 ^ 26 - 1) bytes Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-01fsl_dma: Use proper I/O access functionsPeter Tyser
2009-07-01fsl_dma: Add bitfield definitions for common registersPeter Tyser
2009-07-018xxx: Break out DMA code to a common filePeter Tyser
DMA support is now enabled via the CONFIG_FSL_DMA define instead of the previous CONFIG_DDR_ECC Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-13drivers/dma: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-02-14Use #ifdef CONFIG_FSLDMAFECVlad Lungu
MCD_tasks.c lacks [subject] so compilation of mips targets (and more, probably) fails Signed-off-by: Vlad Lungu <vlad@comsys.ro>
2008-01-23Coding Style Cleanup; update CHANGELOGWolfgang Denk
2008-01-17ColdFire: Add MCF547x_8x dma code and header filesTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
2008-01-17ColdFire: Add MCF547x_8x dma code - 2TsiChungLiew
2008-01-17ColdFire: Add MCF547x_8x dma code - 1TsiChungLiew
