path: root/drivers/dma
2016-02-23drivers: dma: ti-edma3: convert driver to adopt driver modelMugunthan V N
adopt ti-edma3 driver to device driver model Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-02-23dma: Kconfig: Add TI_EDMA3 entryMugunthan V N
Add TI_EDMA3 entry on Kconfig with help description. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-02-23dm: implement a DMA uclassMugunthan V N
Implement a DMA uclass so that the devices like ethernet, spi, mmc etc can offload the data transfers from/to the device and memory. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-01-24imx: apbh_dma: Update APBH-DMA for MX7DPeng Fan
Update APBH-DMA driver and head files to support i.MX7D Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2015-10-22dma: keystone_nav: Fix linkram sizeVitaly Andrianov
Fix Linkram size. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-08-18dma: lpc32xx: add DMA driverSylvain Lemieux
Incorporate DMA driver from legacy LPCLinux NXP BSP. The files taken from the legacy patch are: - lpc32xx DMA driver - lpc3250 header file DMA registers definition. The legacy driver was updated and clean-up as part of the integration with the latest u-boot. Signed-off-by: Sylvain Lemieux <slemieux@tycoint.com> Acked-by: Marek Vasut <marex@denx.de> Tested-by: Vladimir Zapolskiy <vz@mleia.com>
2015-08-17dma: ti-edma3: Add helper function to support edma3 transferVignesh R
Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2014-11-06dma: keystone_nav: remove spurious qm_cfg verificationKhoronzhuk, Ivan
The verification qm_cfg existence is done at ksnav_init(). So, there is no need to verify it after initialization. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-10-23dma: ti-edma3: introduce edma3 driverKhoronzhuk, Ivan
The EDMA3 controller’s primary purpose is to service data transfers that you program between two memory-mapped slave endpoints on the device. Typical usage includes, but is not limited to the following: - Servicing software-driven paging transfers (e.g., transfers from external memory, such as SDRAM to internal device memory, such as DSP L2 SRAM) - Servicing event-driven peripherals, such as a serial port - Performing sorting or sub-frame extraction of various data structures - Offloading data transfers from the main device DSP(s) - See the device-specific data manual for specific peripherals that are accessible via the EDMA3 controller Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-23dma: keystone_nav: generalize driver usageKhoronzhuk, Ivan
The keystone_nav driver is general driver intended to be used for working with queue manager and pktdma for different IPs like NETCP, AIF, FFTC, etc. So the it's API shouldn't be named like it works only with one of them, it should be general names. The names with prefix like netcp_* rather do for drivers/net/keystone_net.c driver. So it's good to generalize this driver to be used for different IP's and delete confusion with real NETCP driver. The current netcp_* functions of keystone navigator can be used for other settings of pktdma, not only for NETCP. The API of this driver is used by the keystone_net driver to work with NETCP, so net driver also should be corrected. For convenience collect pkdma configurations in drivers/dma/keystone_nav_cfg.c. Acked-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-23dma: keystone_nav: move keystone_nav driver to driver/dma/Khoronzhuk, Ivan
The keystone_nav is used by drivers/net/keystone_net.c driver to send and receive packets, but currently it's placed at keystone arch sources. So it should be in the drivers directory also. It's separate driver that can be used for sending and receiving pktdma packets by others drivers also. This patch just move this driver to appropriate directory and doesn't add any functional changes. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-09-24cosmetic: replace MIN, MAX with min, maxMasahiro Yamada
The macro MIN, MAX is defined as the aliase of min, max, respectively. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24kconfig: add blank Kconfig filesMasahiro Yamada
This would be useful to start moving various config options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-08-09omap: clean-up dead configsMasahiro Yamada
The following configs are not defined at all. - CONFIG_OMAP1510 - CONFIG_OMAP_1510P1 - CONFIG_OMAP_SX1 - CONFIG_OMAP3_DMA - CONFIG_OMAP3_ZOOM2 - CONFIG_OMAP_INNOVATOR Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com>
2013-10-31drivers: convert makefiles to Kbuild styleMasahiro Yamada
2013-08-09dma: apbh: Add special circular mode for LCDMarek Vasut
Add special function that executes a specially crafted circular DMA descriptor. The function doesn't wait for the descriptor to finish the transfer, since the descritor never finishes. This is useful when operating a SmartLCD through the LCDIF interface, as the LCDIF does not give us any means to have continuous refresh of the SmartLCD. Instead, the RUN bit in the LCDIF CTRL register must be triggered manually. This can be worked around by starting an DMA transfer which continuously sets the RUN bit. This function allows starting exactly such transfer. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-04-22dma: Add i.MX6 support to drivers/dma/apbh_dma.cStefan Roese
This will be used by the i.MX6 NAND support. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2013-04-22imx: Move some header files from arch-mxs to imx-commonStefan Roese
The following headers are moved to a i.MX common location: - regs-common.h - regs-apbh.h - regs-bch.h - regs-gpmi.h - dma.h This way this header can be re-used also by other i.MX platforms. For example the i.MX6 which will need it for the upcoming NAND support. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2013-01-28mxs: dma: Fix APBH DMA driver for MX23Marek Vasut
The MX23 has less channels for the APBH DMA, sligtly different register layout and some bits in those registers are placed differently. Reflect this in the driver. This patch fixes MMC/DMA issue on MX23. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2012-09-01MX28: DMA: Prolong the DMA timeoutMarek Vasut
Load from SPI flash can create a long DMA chain, which can take long time to transfer. Change the DMA timeout to roughly 10s to prevent such long chains misreporting errors. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <festevam@gmail.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2012-09-01mxs: Convert sys_proto.h prefixes to 'mxs'Otavio Salvador
The sys_proto.h functions (except the boot modes) are compatible with i.MX233 and i.MX28 so we use 'mxs' prefix for its methods. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2012-09-01mxs: prefix register structs with 'mxs' prefixOtavio Salvador
2012-04-16DMA: Split the APBH DMA init into block and channel initMarek Vasut
This fixes the issue where mxs_dma_init() was called either twice or never, without introducing any new init hooks. The idea is to allow each and every device using the APBH DMA block to configure and request only the channels it uses, instead of making it call init for all the channels as is now. The common DMA block init part, which only configures the block, is then called from CPUs arch_cpu_init() call. NOTE: This patch depends on: http://patchwork.ozlabs.org/patch/150957/ Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-03-29i.MX28: Add cache support into the APBH DMA driverMarek Vasut
The desc_append() now flushes descriptors into RAM. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2011-12-06MXS: Add static annotations to dma driverMarek Vasut
Some functions were internal to the apbh dma driver, so annotate them static. Some of the functions weren't used at all so drop them. This makes the U-Boot binary smaller by about 1500 bytes. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-12-06apbh_dma: return error value on timeoutWolfram Sang
When a timeout occurs, the return value is prepared but never returned. Fix that. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Marek Vasut <marek.vasut@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-11-11iMX28: Add APBH DMA driverMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-10-27omap3: Add interface for omap3 DMASimon Schwarz
Adds an interface to use the OMAP3 DMA. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-07-06fsl_dma: fix support for 83xx DMA engineIra W. Snyder
Commit 359ec4931944adb885882deb9b781e4095eabc94 broke support for the Freescale DMA engine on the 83xx parts. This is due to using registers which do not exist on 83xx. Remove the attribute register accesses from the 83xx build. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Cc: York Sun <yorksun@freescale.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-08-31powerpc/8xxx: Fix dma for 36bit addressingYork Sun
Use more bits to support 36-bit addressing Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-26ColdFire: Fix compile warning messagesTsiChung Liew
Change %08lX to %08X in board.c. Remove unused variable 'oscillator' in mcf5227x/cpu_init.c and 'scm2' in mcf532x/cpu_init.c. Provide argument type cast in drivers/dma/MCD_dmaApi.c. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-07-0283xx: Add support for fsl_dma driverPeter Tyser
Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Reviewed-by: Ira W. Snyder <iws@ovro.caltech.edu> Tested-by: Ira W. Snyder <iws@ovro.caltech.edu> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-01fsl_dma: Make DMA transactions snoopablePeter Tyser
Make DMA transactions snoopable so that CPUs can keep caches up-to-date. This allows dma transactions to be used for operations such as memory copies without any additional cache control operations. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-01fsl_dma: Break out common memory initialization functionPeter Tyser
2009-07-018xxx: Rename dma_xfer() to dmacpy()Peter Tyser
Also update dmacpy()'s argument order to match memcpy's and use phys_addr_t/phy_size_t for address/size arguments Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-01fsl_dma: Fix Channel Start bug in dma_check()Peter Tyser
The Channel Start (CS) bit in the Mode Register (MR) should actually be cleared as the comment in the code suggests. Previously, CS was being set, not cleared. Assuming normal operation of the DMA engine, this change shouldn't have any real affect. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-01fsl_dma: Add support for arbitrarily large transfersPeter Tyser
Support DMA transfers larger than the DMA controller's limit of (2 ^ 26 - 1) bytes Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-01fsl_dma: Use proper I/O access functionsPeter Tyser
2009-07-01fsl_dma: Add bitfield definitions for common registersPeter Tyser
2009-07-018xxx: Break out DMA code to a common filePeter Tyser
DMA support is now enabled via the CONFIG_FSL_DMA define instead of the previous CONFIG_DDR_ECC Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-13drivers/dma: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-02-14Use #ifdef CONFIG_FSLDMAFECVlad Lungu
MCD_tasks.c lacks [subject] so compilation of mips targets (and more, probably) fails Signed-off-by: Vlad Lungu <vlad@comsys.ro>
2008-01-23Coding Style Cleanup; update CHANGELOGWolfgang Denk
2008-01-17ColdFire: Add MCF547x_8x dma code and header filesTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
2008-01-17ColdFire: Add MCF547x_8x dma code - 2TsiChungLiew
2008-01-17ColdFire: Add MCF547x_8x dma code - 1TsiChungLiew
