path: root/drivers/dfu
2013-03-16dfu: Add a partition type targetPantelis Antoniou
Dealing with raw block numbers with the dfu is very annoying. Introduce a partition method. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2012-09-21dfu:usb:fix: Read the "filesize" environment variable only when file readŁukasz Majewski
The "filesize" environment variable shall be read only when relevant file is read. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Marek Vasut <marex@denx.de>
2012-09-21dfu:usb: Support for ext4Łukasz Majewski
Support for ext4 file system handling at DFU. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Marek Vasut <marex@denx.de>
2012-09-01dfu: MMC specific routines for DFU operationLukasz Majewski
Support for MMC storage devices to work with DFU framework. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marex@denx.de>
2012-09-01dfu: DFU backend implementationLukasz Majewski
New, separate driver at ./drivers/dfu has been added. It allows platform and storage independent operation of DFU. It has been extended to use new MMC level of command abstraction. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marex@denx.de>
