path: root/drivers/dfu
2018-02-21dfu: tftp: Fix arm64 build warningsMarek Vasut
Fix two build warnings when building for arm64: drivers/dfu/dfu_tftp.c: In function ‘dfu_tftp_write’: drivers/dfu/dfu_tftp.c:59:37: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] ret = dfu_write_from_mem_addr(dfu, (void *)addr, len); ^ and drivers/dfu/dfu_tftp.c: In function ‘dfu_tftp_write’: drivers/dfu/dfu_tftp.c:41:8: warning: format ‘%u’ expects argument of type ‘unsigned int’, but argument 4 has type ‘__kernel_size_t {aka long unsigned int}’ [-Wformat=] debug("%s: image name: %s strlen: %u\n", __func__, sb, strlen(sb)); ^ Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Lukasz Majewski <lukma@denx.de>
2018-02-21dfu: Rename _FUNCTION_DFU to DFU_OVER_Marek Vasut
Do the following to make the symbol names less confusing. sed -i "s/\([TU][^_]\+\)_FUNCTION_DFU/DFU_OVER_\1/g" \ `git grep _FUNCTION_DFU | cut -d ":" -f 1 | sort -u` Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Lukasz Majewski <lukma@denx.de>
2018-02-21dfu: Fix up the Kconfig messMarek Vasut
Clean up the screaming mess of configuration options that DFU is. It was impossible to configure DFU such that TFTP is enabled and USB is not, this patch fixes that and assures that DFU TFTP and DFU USB can be enabled separatelly and that the correct pieces of code are compiled in. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Lukasz Majewski <lukma@denx.de>
2018-01-26dfu: select HASHMaxime Ripard
The DFU code relies on the HASH config option. Make sure it is always there by selecting it. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-28dfu: add common function to initiate transactionPatrick Delaunay
- factorize code between read and write transaction - always use dfu_transaction_cleanup() to initialize the internal variable: easy maintenance - replace direct access by dfu_get_buf() and dfu_get_buf_size() Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-07-28dfu: factorize transaction cleanupPatrick Delaunay
rename cleanup function, as now called by read Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-07-28dfu: remove limitation on partition sizePatrick Delaunay
Change long (32 bits on arm) to u64 (same type than offset) for size and read offset r_left So partition and device used for DFU can be greater than 4GB Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-07-28dfu: allow dfu read on partition greater than 2GBPatrick Delaunay
solve issue on get_medium_size() function the detection of error is a simple test < 0 but for ARM platform, long is 32bits and 2GB = 0x80000000 is seen as error. I solve the issue by changing the prototype fo the function to separate size and result. This patch prepare the next patch with size change to u64. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-07-11dfu: dfu_nand: use get_nand_dev_by_index()Grygorii Strashko
As part of preparation for nand DM conversion the new API has been introduced to remove direct access to nand_info array. So, use it here instead of accessing to nand_info array directly. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
2017-06-03dfu: dfu_sf: Fix read offsetPhil Edworthy
The offset was applied to write, but not read, now its applied to both. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com>
2017-05-12common: dfu: ignore reset for spl-dfuB, Ravi
The SPL-DFU feature enable to load and execute u-boot from RAM over usb from PC using dfu-util. Hence dfu-reset should not be issued when dfu-util -R switch is issued. Signed-off-by: Ravi Babu <ravibabu@ti.com>
2016-11-03dfu: align array in dfu_get_dev_type with enum dfu_device_typePatrick Delaunay
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-09-01nand: Fix some more NULL name testsScott Wood
Now that nand_info[] is an array of pointers we need to test the pointer itself rather than using name as a proxy for NULLness. Fixes: b616d9b0a708eb9 ("nand: Embed mtd_info in struct nand_chip") Signed-off-by: Scott Wood <oss@buserror.net> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Tony Lindgren <tony@atomide.com> Acked-by: Tony Lindgren <tony@atomide.com>
2016-07-11dm: dfu: mmc: Support CONFIG_BLK in DFU for MMCSimon Glass
Update the method of accessing the block device so that it works with CONFIG_BLK enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-09dfu, nand, ubi: fix erasing after write finishHeiko Schocher
writting to ubi nand partitions need after write ends an erase of the remaining sectors. This fail, if dfu write size was not a multiple of erasesize, example log: Failure erase: -1 Fix this error. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-06-03nand: Embed mtd_info in struct nand_chipScott Wood
nand_info[] is now an array of pointers, with the actual mtd_info instance embedded in struct nand_chip. This is in preparation for syncing the NAND code with Linux 4.6, which makes the same change to struct nand_chip. It's in a separate commit due to the large amount of changes required to accommodate the change to nand_info[]. Signed-off-by: Scott Wood <oss@buserror.net>
2016-06-03mtd: nand: Remove nand_info_t typedefScott Wood
This typedef serves no purpose other than causing confusion with struct nand_chip. Signed-off-by: Scott Wood <oss@buserror.net>
2016-05-17dm: mmc: Use the new select_hwpart() APISimon Glass
Avoid calling directly into the MMC code - use the new API call instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-06Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2016-05-06dfu: avoid memory leakPeng Fan
When dfu_fill_entity fail, need to free dfu to avoid memory leak. Reported by Coverity: " Resource leak (RESOURCE_LEAK) leaked_storage: Variable dfu going out of scope leaks the storage it points to. " Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: "Łukasz Majewski" <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2016-05-05Fix various typos, scattered over the code.Robert P. J. Day
Spelling corrections for (among other things): * environment * override * variable * ftd (should be "fdt", for flattened device tree) * embedded * FTDI * emulation * controller
2016-04-25dfu: ram: fix number base of RAM entity parametersStephen Warren
U-Boot typically interprets unprefixed numbers as base 16, and DFU RAM entity parsing has historically done so. Reverse the change to default to base 10, so that values in previously working command-lines aren't mis-parsed, causing RAM corruption, crashes, hangs, etc. Fixes: 6aeb877afef0 ("drivers: dfu: ram: fix a crash with dfu ram with invalid dfu_alt_info env") Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com> Tested-by: Mugunthan V N <mugunthanvnm@ti.com> [Test HW: AM335x BBB]
2016-04-25drivers: dfu: ram: fix a crash with dfu ram with invalid dfu_alt_info envMugunthan V N
U-Boot crashes when an invalid dfu_alt_info is set and tried using dfu command. Fixing this as it is handled in dfu-mmc. => dfu 0 ram 0 data abort pc : [<9ff893d6>] lr : [<9ff6edb9>] reloc pc : [<808323d6>] lr : [<80817db9>] sp : 9ef36cf0 ip : 00000158 fp : 9ffbc0b8 r10: 9ffbc0b8 r9 : 9ef36ed8 r8 : 00000000 r7 : 00000000 r6 : 9ffbc0c8 r5 : 9ef36cfc r4 : 9ef392c8 r3 : 00000004 r2 : 00000000 r1 : 9ff9a985 r0 : ffffffff Flags: Nzcv IRQs off FIQs on Mode SVC_32 Resetting CPU ... resetting ... Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14dm: part: Rename some partition functionsSimon Glass
Rename three partition functions so that they start with part_. This makes it clear what they relate to. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-01-13mmc: store hwpart in the block deviceStephen Warren
This will allow us to have multiple block device structs each referring to the same eMMC device, yet different HW partitions. For now, there is still a single block device per eMMC device. As before, this block device always accesses whichever HW partition was most recently selected. Clients wishing to make use of multiple block devices referring to different HW partitions can simply take a copy of this block device once it points at the correct HW partition, and use each one as they wish. This feature will be used by the next patch. In the future, perhaps get_device() could be enhanced to return a dynamically allocated block device struct, to avoid the client needing to copy it in order to maintain multiple block devices. However, this would require all users to be updated to free those block device structs at some point, which is rather a large change. Most callers of mmc_switch_part() wish to permanently switch the default MMC block device's HW partition. Enhance mmc_switch_part() so that it does this. This removes the need for callers to do this. However, common/env_mmc.c needs to save and restore the current HW partition. Make it do this more explicitly. Replace use of mmc_switch_part() with mmc_select_hwpart() in order to remove duplicate code that skips the call if that HW partition is already selected. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-13block: pass block dev not num to read/write/erase()Stephen Warren
This will allow the implementation to make use of data in the block_dev structure beyond the base device number. This will be useful so that eMMC block devices can encompass the HW partition ID rather than treating this out-of-band. Equally, the existence of the priv field is crying out for this patch to exist. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-03dfu: dfu_sf: Pass duplicate devstr to parse_devVignesh R
parse_dev() alters the string pointed by devstr parameter. Due to this subsequent parsing of sf entities will fail, as string pointed by devstr is no longer valid sf dev arguments. Fix this by passing pointer to the copy of the string to parse_dev instead of pointer to the actual devstr. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-19dfu: dfu_sf: Take the start address into accountFabio Estevam
The dfu_alt_info_spl variable allows passing a starting point for the binary to be flashed in the SPI NOR. For example, if we have 'dfu_alt_info_spl=spl raw 0x400', this means that we want to flash the binary starting at address 0x400. In order to do so we need to erase the entire sector and write to the the subsequent SPI NOR sectors taking such start address into account for the address calculations. Tested by succesfully writing SPL binary into 0x400 offset and the u-boot.img at offset 64 kiB of a SPL NOR. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> [trini: Use lldiv for the math] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-19dfu: dfu_sf: Use the erase sector size for erase operationsFabio Estevam
SPI NOR flashes need to erase the entire sector size and we cannot pass any arbitrary length for the erase operation. To illustrate the problem: Copying data from PC to DFU device Download [=========================] 100% 478208 bytes Download done. state(7) = dfuMANIFEST, status(0) = No error condition is present state(10) = dfuERROR, status(14) = Something went wrong, but the device does not know what it was Done! In this case, the binary has 478208 bytes and the M25P32 SPI NOR has an erase sector of 64kB. 478208 = 7 entire sectors of 64kiB + 19456 bytes. Erasing the first seven 64 kB sectors works fine, but when trying to erase the remainding 19456 causes problem and the board hangs. Fix the issue by always erasing with the erase sector size. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2015-09-11dfu: mmc: buffer file reads tooStephen Warren
When writing to files in a filesystem on MMC, dfu_mmc.c buffers up the entire file content until the end of the transaction, at which point the file is written in one go. This allows writing files larger than the USB transfer size (CONFIG_SYS_DFU_DATA_BUF_SIZE); the maximum written file size is CONFIG_SYS_DFU_MAX_FILE_SIZE (the size of the temporary buffer). The current file reading code does not do any buffering, and so limits the maximum read file size to the USB transfer size. Enhance the code to do the same kind of buffering as the write path, so the same file size limits apply. Remove the size checking code from dfu_read() since all read paths now support larger files than the USB transfer buffer. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com>
2015-09-11dfu: don't keep freeing/reallocatingStephen Warren
DFU currently allocates buffer memory at the start of each data transfer operation and frees it at the end. Especially since memalign() is used to allocate the buffer, and various other allocations happen during the transfer, this can expose the code to heap fragmentation, which prevents the allocation from succeeding on subsequent transfers. Fix the code to allocate the buffer once when DFU mode is initialized, and free the buffer once when DFU mode is exited, to reduce the exposure to heap fragmentation. The failure mode is: // Internally to memalign(), this allocates a lot more than s to guarantee // that alignment can occur, then returns chunks of memory at the start/ // end of the allocated buffer to the heap. p = memalign(a, s); // Various other malloc()s occur here, some of which allocate the RAM // immediately before/after "p". // // DFU transfer is complete, so buffer is released. free(p); // By chance, no other malloc()/free() here, in DFU at least. // // A new DFU transfer starts, so the buffer is allocated again. // In theory this should succeed since we just free()d a buffer of the // same size. However, this fails because memalign() internally attempts // to allocate much more than "s", yet free(p) above only free()d a // little more than "s". p = memalign(a, s); Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com>
2015-09-07dfu: tftp: Kconfig: Add Kconfig entry for dfu tftp featureLukasz Majewski
The dfu tftp feature can be now enabled via Kconfig. This commit provides necessary code for it. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-07dfu: tftp: update: Add dfu_write_from_mem_addr() functionLukasz Majewski
This function allows writing via DFU data stored from fixed buffer address (like e.g. loadaddr env variable). Such predefined buffers are used in the update_tftp() code. In fact this function is a wrapper on the dfu_write() and dfu_flush(). Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-07dfu: tftp: update: Provide tftp support for the DFU subsystemLukasz Majewski
This commit adds initial support for using tftp for downloading and upgrading firmware on the device. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-07dfu: Delete superfluous initialization of the dfu_buf_size static variableLukasz Majewski
After extension of the dfu_get_buf() to also setup (implicitly) the dfu_buf_size variable it is not needed to set dfu_buf_size to CONFIG_SYS_DFU_DATA_BUF_SIZE. This variable is set in the dfu_get_buf() by not only considering CONFIG_SYS_DFU_DATA_BUF but more importantly the "dfu_bufsiz" env variable. Therefore, dfu_get_buf() should be used for initialization. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-07-27dfu: fix 64-bit compile warningsStephen Warren
Use %p to print pointers. The max value of (i_buf - i_buf_start) should be dfu_buf_size, which is an unsigned long, so cast the pointer difference to that type to print. Change-Id: Iee242df9f8eb091aecfe0cea4c282b28b547acfe Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-07-22usb: USB download gadget and functions config options coherent namingPaul Kocialkowski
This introduces a coherent scheme for naming USB download gadget and functions config options. The download USB gadget config option is moved to CONFIG_USB_GADGET_DOWNLOAD for better consistency with other gadgets and each function's config option is moved to a CONFIG_USB_FUNCTION_ prefix. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Tested-by: Lukasz Majewski <l.majewski@samsung.com> Test HW: Odroid_XU3 (Exynos5422), trats (Exynos4210)
2015-03-30dfu: nand: Verify writesPeter Tyser
Previously NAND writes were not verified and could fail silently. Add a verification step after all writes to NAND. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2015-03-09dfu: mmc: file buffer: remove static allocationPrzemyslaw Marczak
For writing files, DFU implementation requires the file buffer with the len at least of file size. For big files it requires the same big buffer. Previously the file buffer was allocated as a static variable, so it was a part of U-Boot .bss section. For 32MiB len of buffer we have 32MiB of additional space, required for this section. The .bss needs to be cleared after the relocation. This introduces an additional boot delay at every start, but usually the dfu feature is not required at the standard boot, so the buffer should be allocated only if required. This patch removes the static allocation of this buffer, and alloc it with memalign after first call of function: - dfu_fill_entity_mmc() and the buffer is freed on dfu_free_entity() call. This was tested on Trats2. A quick test with trace. Boot time from start to main_loop() entry: - ~888ms - before this change (arch memset enabled for .bss clear) - ~464ms - after this change Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Tom Rini <trini@konsulko.com> Cc: Marek Vasut <marek.vasut@gmail.com>
2015-02-25dfu: samsung: move call to set_dfu_alt_info() to dfu common codePrzemyslaw Marczak
This common call can be used for setting proper entities based on dfu command arguments. The config: CONFIG_SET_DFU_ALT_INFO, was used only for few configs, and now it is common. The board file should implement: - set_dfu_alt_info() function Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [Test HW: Odroid U3 (Exynos 4412)]
2014-12-18dfu: dfu_get_buf: check the value of env dfu_bufsiz before usePrzemyslaw Marczak
In function dfu_get_buf(), the size of allocated buffer could be defined by the env variable. The size from this variable was passed for memalign() without checking its value. And the the memalign will return non null pointer for size 0. This could possibly cause data abort, so now the value of var is checked before use. And if this variable is set to 0 then the default size will be used. This commit also changes the base passed to simple_strtoul() to 0. Now decimal and hex values can be used for the variable dfu_bufsiz. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [TestHW: Exynos4412-Trats2]
2014-12-18dfu: mmc: check if mmc device exists in mmc_block_op()Przemyslaw Marczak
The function mmc_block_op() is the last function before the physicall data write, but the mmc device pointer is not checked. If mmc device not exists, then data abort will occur. To avoid this, first the mmc device pointer is checked. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [TestHW: Exynos4412-Trats2]
2014-12-18usb, g_dnl: generalize DFU detach functionsRob Herring
In order to add detach functions for fastboot, make the DFU detach related functions common so they can be shared. Signed-off-by: Rob Herring <robh@kernel.org> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [TestHW: Exynos4412-Trats2]
2014-12-11Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
Conflicts: board/freescale/mx6sxsabresd/mx6sxsabresd.c Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23linux/kernel.h: sync min, max, min3, max3 macros with LinuxMasahiro Yamada
U-Boot has never cared about the type when we get max/min of two values, but Linux Kernel does. This commit gets min, max, min3, max3 macros synced with the kernel introducing type checks. Many of references of those macros must be fixed to suppress warnings. We have two options: - Use min, max, min3, max3 only when the arguments have the same type (or add casts to the arguments) - Use min_t/max_t instead with the appropriate type for the first argument Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [trini: Fixup arch/blackfin/lib/string.c] Signed-off-by: Tom Rini <trini@ti.com>
