path: root/drivers/dfu
2016-11-03dfu: align array in dfu_get_dev_type with enum dfu_device_typePatrick Delaunay
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-09-01nand: Fix some more NULL name testsScott Wood
Now that nand_info[] is an array of pointers we need to test the pointer itself rather than using name as a proxy for NULLness. Fixes: b616d9b0a708eb9 ("nand: Embed mtd_info in struct nand_chip") Signed-off-by: Scott Wood <oss@buserror.net> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Tony Lindgren <tony@atomide.com> Acked-by: Tony Lindgren <tony@atomide.com>
2016-07-11dm: dfu: mmc: Support CONFIG_BLK in DFU for MMCSimon Glass
Update the method of accessing the block device so that it works with CONFIG_BLK enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-09dfu, nand, ubi: fix erasing after write finishHeiko Schocher
writting to ubi nand partitions need after write ends an erase of the remaining sectors. This fail, if dfu write size was not a multiple of erasesize, example log: Failure erase: -1 Fix this error. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-06-03nand: Embed mtd_info in struct nand_chipScott Wood
nand_info[] is now an array of pointers, with the actual mtd_info instance embedded in struct nand_chip. This is in preparation for syncing the NAND code with Linux 4.6, which makes the same change to struct nand_chip. It's in a separate commit due to the large amount of changes required to accommodate the change to nand_info[]. Signed-off-by: Scott Wood <oss@buserror.net>
2016-06-03mtd: nand: Remove nand_info_t typedefScott Wood
This typedef serves no purpose other than causing confusion with struct nand_chip. Signed-off-by: Scott Wood <oss@buserror.net>
2016-05-17dm: mmc: Use the new select_hwpart() APISimon Glass
Avoid calling directly into the MMC code - use the new API call instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-06Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2016-05-06dfu: avoid memory leakPeng Fan
When dfu_fill_entity fail, need to free dfu to avoid memory leak. Reported by Coverity: " Resource leak (RESOURCE_LEAK) leaked_storage: Variable dfu going out of scope leaks the storage it points to. " Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: "Łukasz Majewski" <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2016-05-05Fix various typos, scattered over the code.Robert P. J. Day
Spelling corrections for (among other things): * environment * override * variable * ftd (should be "fdt", for flattened device tree) * embedded * FTDI * emulation * controller
2016-04-25dfu: ram: fix number base of RAM entity parametersStephen Warren
U-Boot typically interprets unprefixed numbers as base 16, and DFU RAM entity parsing has historically done so. Reverse the change to default to base 10, so that values in previously working command-lines aren't mis-parsed, causing RAM corruption, crashes, hangs, etc. Fixes: 6aeb877afef0 ("drivers: dfu: ram: fix a crash with dfu ram with invalid dfu_alt_info env") Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com> Tested-by: Mugunthan V N <mugunthanvnm@ti.com> [Test HW: AM335x BBB]
2016-04-25drivers: dfu: ram: fix a crash with dfu ram with invalid dfu_alt_info envMugunthan V N
U-Boot crashes when an invalid dfu_alt_info is set and tried using dfu command. Fixing this as it is handled in dfu-mmc. => dfu 0 ram 0 data abort pc : [<9ff893d6>] lr : [<9ff6edb9>] reloc pc : [<808323d6>] lr : [<80817db9>] sp : 9ef36cf0 ip : 00000158 fp : 9ffbc0b8 r10: 9ffbc0b8 r9 : 9ef36ed8 r8 : 00000000 r7 : 00000000 r6 : 9ffbc0c8 r5 : 9ef36cfc r4 : 9ef392c8 r3 : 00000004 r2 : 00000000 r1 : 9ff9a985 r0 : ffffffff Flags: Nzcv IRQs off FIQs on Mode SVC_32 Resetting CPU ... resetting ... Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14dm: part: Rename some partition functionsSimon Glass
Rename three partition functions so that they start with part_. This makes it clear what they relate to. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-01-13mmc: store hwpart in the block deviceStephen Warren
This will allow us to have multiple block device structs each referring to the same eMMC device, yet different HW partitions. For now, there is still a single block device per eMMC device. As before, this block device always accesses whichever HW partition was most recently selected. Clients wishing to make use of multiple block devices referring to different HW partitions can simply take a copy of this block device once it points at the correct HW partition, and use each one as they wish. This feature will be used by the next patch. In the future, perhaps get_device() could be enhanced to return a dynamically allocated block device struct, to avoid the client needing to copy it in order to maintain multiple block devices. However, this would require all users to be updated to free those block device structs at some point, which is rather a large change. Most callers of mmc_switch_part() wish to permanently switch the default MMC block device's HW partition. Enhance mmc_switch_part() so that it does this. This removes the need for callers to do this. However, common/env_mmc.c needs to save and restore the current HW partition. Make it do this more explicitly. Replace use of mmc_switch_part() with mmc_select_hwpart() in order to remove duplicate code that skips the call if that HW partition is already selected. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-13block: pass block dev not num to read/write/erase()Stephen Warren
This will allow the implementation to make use of data in the block_dev structure beyond the base device number. This will be useful so that eMMC block devices can encompass the HW partition ID rather than treating this out-of-band. Equally, the existence of the priv field is crying out for this patch to exist. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-03dfu: dfu_sf: Pass duplicate devstr to parse_devVignesh R
parse_dev() alters the string pointed by devstr parameter. Due to this subsequent parsing of sf entities will fail, as string pointed by devstr is no longer valid sf dev arguments. Fix this by passing pointer to the copy of the string to parse_dev instead of pointer to the actual devstr. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-19dfu: dfu_sf: Take the start address into accountFabio Estevam
The dfu_alt_info_spl variable allows passing a starting point for the binary to be flashed in the SPI NOR. For example, if we have 'dfu_alt_info_spl=spl raw 0x400', this means that we want to flash the binary starting at address 0x400. In order to do so we need to erase the entire sector and write to the the subsequent SPI NOR sectors taking such start address into account for the address calculations. Tested by succesfully writing SPL binary into 0x400 offset and the u-boot.img at offset 64 kiB of a SPL NOR. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> [trini: Use lldiv for the math] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-19dfu: dfu_sf: Use the erase sector size for erase operationsFabio Estevam
SPI NOR flashes need to erase the entire sector size and we cannot pass any arbitrary length for the erase operation. To illustrate the problem: Copying data from PC to DFU device Download [=========================] 100% 478208 bytes Download done. state(7) = dfuMANIFEST, status(0) = No error condition is present state(10) = dfuERROR, status(14) = Something went wrong, but the device does not know what it was Done! In this case, the binary has 478208 bytes and the M25P32 SPI NOR has an erase sector of 64kB. 478208 = 7 entire sectors of 64kiB + 19456 bytes. Erasing the first seven 64 kB sectors works fine, but when trying to erase the remainding 19456 causes problem and the board hangs. Fix the issue by always erasing with the erase sector size. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2015-09-11dfu: mmc: buffer file reads tooStephen Warren
When writing to files in a filesystem on MMC, dfu_mmc.c buffers up the entire file content until the end of the transaction, at which point the file is written in one go. This allows writing files larger than the USB transfer size (CONFIG_SYS_DFU_DATA_BUF_SIZE); the maximum written file size is CONFIG_SYS_DFU_MAX_FILE_SIZE (the size of the temporary buffer). The current file reading code does not do any buffering, and so limits the maximum read file size to the USB transfer size. Enhance the code to do the same kind of buffering as the write path, so the same file size limits apply. Remove the size checking code from dfu_read() since all read paths now support larger files than the USB transfer buffer. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com>
2015-09-11dfu: don't keep freeing/reallocatingStephen Warren
DFU currently allocates buffer memory at the start of each data transfer operation and frees it at the end. Especially since memalign() is used to allocate the buffer, and various other allocations happen during the transfer, this can expose the code to heap fragmentation, which prevents the allocation from succeeding on subsequent transfers. Fix the code to allocate the buffer once when DFU mode is initialized, and free the buffer once when DFU mode is exited, to reduce the exposure to heap fragmentation. The failure mode is: // Internally to memalign(), this allocates a lot more than s to guarantee // that alignment can occur, then returns chunks of memory at the start/ // end of the allocated buffer to the heap. p = memalign(a, s); // Various other malloc()s occur here, some of which allocate the RAM // immediately before/after "p". // // DFU transfer is complete, so buffer is released. free(p); // By chance, no other malloc()/free() here, in DFU at least. // // A new DFU transfer starts, so the buffer is allocated again. // In theory this should succeed since we just free()d a buffer of the // same size. However, this fails because memalign() internally attempts // to allocate much more than "s", yet free(p) above only free()d a // little more than "s". p = memalign(a, s); Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com>
2015-09-07dfu: tftp: Kconfig: Add Kconfig entry for dfu tftp featureLukasz Majewski
The dfu tftp feature can be now enabled via Kconfig. This commit provides necessary code for it. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-07dfu: tftp: update: Add dfu_write_from_mem_addr() functionLukasz Majewski
This function allows writing via DFU data stored from fixed buffer address (like e.g. loadaddr env variable). Such predefined buffers are used in the update_tftp() code. In fact this function is a wrapper on the dfu_write() and dfu_flush(). Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-07dfu: tftp: update: Provide tftp support for the DFU subsystemLukasz Majewski
This commit adds initial support for using tftp for downloading and upgrading firmware on the device. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-07dfu: Delete superfluous initialization of the dfu_buf_size static variableLukasz Majewski
After extension of the dfu_get_buf() to also setup (implicitly) the dfu_buf_size variable it is not needed to set dfu_buf_size to CONFIG_SYS_DFU_DATA_BUF_SIZE. This variable is set in the dfu_get_buf() by not only considering CONFIG_SYS_DFU_DATA_BUF but more importantly the "dfu_bufsiz" env variable. Therefore, dfu_get_buf() should be used for initialization. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-07-27dfu: fix 64-bit compile warningsStephen Warren
Use %p to print pointers. The max value of (i_buf - i_buf_start) should be dfu_buf_size, which is an unsigned long, so cast the pointer difference to that type to print. Change-Id: Iee242df9f8eb091aecfe0cea4c282b28b547acfe Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-07-22usb: USB download gadget and functions config options coherent namingPaul Kocialkowski
This introduces a coherent scheme for naming USB download gadget and functions config options. The download USB gadget config option is moved to CONFIG_USB_GADGET_DOWNLOAD for better consistency with other gadgets and each function's config option is moved to a CONFIG_USB_FUNCTION_ prefix. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Tested-by: Lukasz Majewski <l.majewski@samsung.com> Test HW: Odroid_XU3 (Exynos5422), trats (Exynos4210)
2015-03-30dfu: nand: Verify writesPeter Tyser
Previously NAND writes were not verified and could fail silently. Add a verification step after all writes to NAND. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2015-03-09dfu: mmc: file buffer: remove static allocationPrzemyslaw Marczak
For writing files, DFU implementation requires the file buffer with the len at least of file size. For big files it requires the same big buffer. Previously the file buffer was allocated as a static variable, so it was a part of U-Boot .bss section. For 32MiB len of buffer we have 32MiB of additional space, required for this section. The .bss needs to be cleared after the relocation. This introduces an additional boot delay at every start, but usually the dfu feature is not required at the standard boot, so the buffer should be allocated only if required. This patch removes the static allocation of this buffer, and alloc it with memalign after first call of function: - dfu_fill_entity_mmc() and the buffer is freed on dfu_free_entity() call. This was tested on Trats2. A quick test with trace. Boot time from start to main_loop() entry: - ~888ms - before this change (arch memset enabled for .bss clear) - ~464ms - after this change Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Tom Rini <trini@konsulko.com> Cc: Marek Vasut <marek.vasut@gmail.com>
2015-02-25dfu: samsung: move call to set_dfu_alt_info() to dfu common codePrzemyslaw Marczak
This common call can be used for setting proper entities based on dfu command arguments. The config: CONFIG_SET_DFU_ALT_INFO, was used only for few configs, and now it is common. The board file should implement: - set_dfu_alt_info() function Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [Test HW: Odroid U3 (Exynos 4412)]
2014-12-18dfu: dfu_get_buf: check the value of env dfu_bufsiz before usePrzemyslaw Marczak
In function dfu_get_buf(), the size of allocated buffer could be defined by the env variable. The size from this variable was passed for memalign() without checking its value. And the the memalign will return non null pointer for size 0. This could possibly cause data abort, so now the value of var is checked before use. And if this variable is set to 0 then the default size will be used. This commit also changes the base passed to simple_strtoul() to 0. Now decimal and hex values can be used for the variable dfu_bufsiz. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [TestHW: Exynos4412-Trats2]
2014-12-18dfu: mmc: check if mmc device exists in mmc_block_op()Przemyslaw Marczak
The function mmc_block_op() is the last function before the physicall data write, but the mmc device pointer is not checked. If mmc device not exists, then data abort will occur. To avoid this, first the mmc device pointer is checked. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [TestHW: Exynos4412-Trats2]
2014-12-18usb, g_dnl: generalize DFU detach functionsRob Herring
In order to add detach functions for fastboot, make the DFU detach related functions common so they can be shared. Signed-off-by: Rob Herring <robh@kernel.org> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [TestHW: Exynos4412-Trats2]
2014-12-11Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
Conflicts: board/freescale/mx6sxsabresd/mx6sxsabresd.c Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23linux/kernel.h: sync min, max, min3, max3 macros with LinuxMasahiro Yamada
U-Boot has never cared about the type when we get max/min of two values, but Linux Kernel does. This commit gets min, max, min3, max3 macros synced with the kernel introducing type checks. Many of references of those macros must be fixed to suppress warnings. We have two options: - Use min, max, min3, max3 only when the arguments have the same type (or add casts to the arguments) - Use min_t/max_t instead with the appropriate type for the first argument Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [trini: Fixup arch/blackfin/lib/string.c] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-14dfu: thor: fix: Modify dfu_get_alt() function to support absolute pathsLukasz Majewski
Recently the ext4 file system imposed passing absolute path with its file name parameter. As a result dfu_alt_info env variable has been modified to provide absolute path when ext4 file system is accessed (e.g. /uImage ext4 0 2;). Unfortunately, lthor flashing program provides plain file name (like uImage) and hence those two file names do not match anymore. Presented commit also allows lthor to write files to sub directories (like /boot/bin/uImage). Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Reviewed-by: Marek Vasut <marex@denx.de>
2014-10-22dm: Add spi.h header to a few filesSimon Glass
Some files are using SPI functions but not explitly including the SPI header file. Fix this, since driver model needs it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-09-24kconfig: add blank Kconfig filesMasahiro Yamada
This would be useful to start moving various config options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-09-02dfu: Provide means to find difference between dfu-util -e and -RLukasz Majewski
This commit provides distinction between DFU device detach and reset. The -R behavior is preserved with proper handling of the dfu-util's -e switch, which detach the DFU device. By running dfu-util -e; one can force device to finish the execution of dfu command on target and execute some other scripted commands. Moreover, some naming has been changed - the dfu_reset() method now is known as dfu_detach(). New name better reflects the purpose of the code. It was also necessary to increase the number of usb_gadget_handle_interrupts() calls since we also must wait for detection of the USB reset event. Example usage: 1. -e (detach) switch dfu-util -a0 -D file1.bin;dfu-util -a3 -D uImage;dfu-util -e access to u-boot prompt. 2. -R (reset) switch dfu-util -a0 -D file1.bin;dfu-util -R -a3 -D uImage target board reset Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2014-08-09dfu: fix readback buffer overflow testStephen Warren
The buffer is too small if it's < size to read, not if it's <= the size. This fixes the 1MB test case on Tegra, which has a 1MB buffer. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-08-09dfu: add SF backendStephen Warren
This allows SPI Flash to be programmed using DFU. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-08-09dfu: add free_entity() to struct dfu_entityStephen Warren
This allows the backend to free any resources allocated during the relevant dfu_fill_entity_*() call. This will soon be used by the SF backend. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-08-09dfu: allow backend to specify a maximum buffer sizeStephen Warren
CONFIG_SYS_DFU_DATA_BUF_SIZE may be large to allow for FAT/ext layouts to transfer large files. However, this means that individual write operations will take a long time. Allow backends to specify a maximum buffer size, so that each write operation is limited to a smaller data block. This prevents the DFU protocol from timing out when e.g. writing to SPI flash. I would guess that NAND might benefit from setting this value too, but I can't test that. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-08-09dfu: defer parsing of device string to IO backendStephen Warren
Devices are not all identified by a single integer. To support this, defer the parsing of the device string to the IO backed, so that it can apply the appropriate rules. SPI devices are specified as controller:chip_select. SPI/SF support will be added soon. MMC devices can also be specified as controller[.hwpart][:partition] in many commands, although we don't support that syntax in DFU. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-08-09dfu: add write error handlingStephen Warren
Fix calls to dfu_write() and dfu_flush() to detect errors in the I/O itself. This could happen due to problems with the storage medium, or simply when trying to write a FAT/ext file that is larger than the buffer dfu_mmc.c maintains for this purpose. Signal the error by switching the DFU state/status. This will be picked up by the DFU client when it sends the next DFU request. Note that errors can't simply be returned from e.g. dnload_request_complete(), since that function has no way to pass errors back to the DFU client; a call to dnload_request_complete() simply means that a USB OUT completed. This error state/status needs to be cleared when the next DFU client connects. While there is a DFU_CLRSTATUS request, no DFU client seems to send this. Hence, clear this when selecting the USB alternate setting on the USB interface. Finally, dfu.c relies on a call to dfu_flush() to clear up the internal state of the write transaction. Now that errors in dfu_write() are detected, dfu_flush() may no longer be called for every transaction. Separate out the cleanup code into a new function, and call it whenever dfu_write() fails, as well as from any call to dfu_flush(). Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-08-09dfu: fix some issues with reads/uploadsStephen Warren
DFU read support appears to rely upon dfu->read_medium() updating the passed-by-reference len parameter to indicate the remaining size available for reading. dfu_read_medium_mmc() never does this, and the implementation of dfu_read_medium_nand() will only work if called just once; it hard-codes the value to the total size of the NAND device irrespective of read offset. I believe that overloading dfu->read_medium() is confusing. As such, this patch introduces a new function dfu->get_medium_size() which can be used to explicitly find out the medium size, and nothing else. dfu_read() is modified to use this function to set the initial value for dfu->r_left, rather than attempting to use the side-effects of dfu->read_medium() for this purpose. Due to this change, dfu_read() must initially set dfu->b_left to 0, since no data has been read. dfu_read_buffer_fill() must also be modified not to adjust dfu->r_left when simply copying data from dfu->i_buf_start to the upload request buffer. r_left represents the amount of data left to be read from HW. That value is not affected by the memcpy(), but only by calls to dfu->read_medium(). After this change, I can read from either a 4MB or 1.5MB chunk of a 4MB eMMC boot partion with CONFIG_SYS_DFU_DATA_BUF_SIZE==1MB. Without this change, attempting to do that would result in DFU read returning no data at all due to r_left never being set. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-06-11dfu: Disable default calculation of CRC32Lukasz Majewski
Patch (SHA1: bd694244db7bc969954) dfu: Introduction of the "dfu_hash_algo" env variable for checksum method setting already introduced more generic handling of the crc32 calculation. Up till now the CRC32 of received data was calculated unconditionally. This patch changes this and from now - by default the crc32 is NOT calculated anymore. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2014-06-01dfu: Introduction of the "dfu_hash_algo" env variable for checksum method ↵Lukasz Majewski
setting Up till now the CRC32 of received data was calculated unconditionally. The standard crc32 implementation causes long delay when large images were uploaded. The "dfu_hash_algo" environment variable gives the opportunity to disable on demand the hash (crc32) calculation. It can be done without the need to recompile the u-boot binary. By default the crc32 is calculated, which means that legacy behavior has been preserved. Tests results: 400 MiB ums.img file With crc32 calculation: 65 sec [avg 6.29 MB/s] Without crc32 calculation: 25 sec [avg 16.17 MB/s] Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2014-05-15dfu: mmc: Provide support for eMMC boot partition accessLukasz Majewski
Before this patch it was only possible to access the default eMMC HW partition. By partition selection I mean the access to eMMC via the ext_csd[179] register programming. It sometimes happens that it is necessary to write to other partitions. This patch adds extra attribute to "raw" sub type of the dfu_alt_info environment variable (e.g. boot-mmc.bin raw 0x0 0x200 mmcpart 1;) It saves the original boot value and restores it after storing the file. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
