path: root/drivers/demo
2018-02-18sandbox: Add 64-bit sandboxMario Six
To debug device tree issues involving 32- and 64-bit platforms, it is useful to have a generic 64-bit platform available. Add a version of the sandbox that uses 64-bit integers for its physical addresses as well as a modified device tree. Signed-off-by: Mario Six <mario.six@gdsys.cc> Added CONFIG_SYS_TEXT_BASE to configs/sandbox64_defconfig Signed-off-by: Simon Glass <sjg@chromium.org>
2017-02-08dm: core: Replace of_offset with accessorSimon Glass
At present devices use a simple integer offset to record the device tree node associated with the device. In preparation for supporting a live device tree, which uses a node pointer instead, refactor existing code to access this field through an inline function. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-12drivers: hierarchize drivers Kconfig menuMasahiro Yamada
The menuconfig for drivers are getting more and more cluttered and unreadable because too many entries are displayed in a single flat menu. Use hierarchic menu for each category. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Update to apply again in a few places, drop USB hunk] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-04-18common: Make sure arch-specific map_sysmem() is definedJoe Hershberger
In the case where the arch defines a custom map_sysmem(), make sure that including just mapmem.h is sufficient to have these functions as they are when the arch does not override it. Also split the non-arch specific functions out of common.h Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Add Kconfig for driver/demoSimon Glass
Add a suitable Kconfig for this directory. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-01-29dm: demo: Add a simple GPIO demonstrationSimon Glass
Add a new 'demo light' command which uses GPIOs to control imaginary lights. Each light is assigned a bit number in the overall value. This provides an example driver for using the new GPIO API. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-24kbuild: refactor some makefilesMasahiro Yamada
[1] Move driver/core/, driver/input/ and drivers/input/ entries from the top Makefile to drivers/Makefile [2] Remove the conditional by CONFIG_DM in drivers/core/Makefile because the whole drivers/core directory is already selected by CONFIG_DM in the upper level [3] Likewise for CONFIG_DM_DEMO in drivers/demo/Makefile [4] Simplify common/Makefile - both CONFIG_DDR_SPD and CONFIG_SPD_EEPROM are boolean macros so they can directly select objects Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Marek Vasut <marex@denx.de>
2014-07-23dm: Give the demo uclass a nameSimon Glass
Uclasses should be named, so add a name for the demo uclass. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-20dm: Rename struct device_id to udevice_idSimon Glass
It is best to avoid having any occurence of 'struct device' in driver model, so rename to achieve this. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-27dm: rename device struct to udeviceHeiko Schocher
using UBI and DM together leads in compiler error, as both define a "struct device", so rename "struct device" in include/dm/device.h to "struct udevice", as we use linux code (MTD/UBI/UBIFS some USB code,...) and cannot change the linux "struct device" Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Marek Vasut <marex@denx.de>
2014-03-04dm: Add a demonstration/example driverSimon Glass
As an example of how to write a uclass and a driver, provide a demo version of each, accessible through the 'demo' command. To use these with driver model, define CONFIG_CMD_DEMO and CONFIG_DM_DEMO. The two demo drivers are enabled with CONFIG_DM_DEMO_SIMPLE and CONFIG_DM_DEMO_SHAPE. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com> Signed-off-by: Viktor Křivák <viktor.krivak@gmail.com> Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com>
