path: root/drivers/ddr
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-14Revert "drivers/ddr/fsl: Dual-license DDR driver"Tom Rini
Upon further review, not all code authors are in favour of this change. This reverts commit ee3556bcafbb05e59aabdc31368984e76acaabc4. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-09drivers/ddr/fsl: Dual-license DDR driverYork Sun
To make this driver easier to be reused, dual-license DDR driver. Signed-off-by: York Sun <york.sun@nxp.com> CC: Simon Glass <sjg@chromium.org> CC: Tom Rini <trini@konsulko.com> CC: Heinrich Schuchardt <xypron.glpk@gmx.de> CC: Thomas Schaefer <thomas.schaefer@kontron.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Robert P. J. Day <rpjday@crashcourse.ca> CC: Alexander Merkle <alexander.merkle@lauterbach.com> CC: Joakim Tjernlund <joakim.tjernlund@transmode.se> CC: Curt Brune <curt@cumulusnetworks.com> CC: Valentin Longchamp <valentin.longchamp@keymile.com> CC: Wolfgang Denk <wd@denx.de> CC: Anatolij Gustschin <agust@denx.de> CC: Ira W. Snyder <iws@ovro.caltech.edu> CC: Marek Vasut <marek.vasut@gmail.com> CC: Kyle Moffett <Kyle.D.Moffett@boeing.com> CC: Sebastien Carlier <sebastien.carlier@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Peter Tyser <ptyser@xes-inc.com> CC: Paul Gortmaker <paul.gortmaker@windriver.com> CC: Peter Tyser <ptyser@xes-inc.com> CC: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2018-01-30drivers/ddr/fsl: Cleanup unused variableYork Sun
Variable "row_density" is no longer used. Drop it from DIMM structure. Signed-off-by: York Sun <york.sun@nxp.com>
2018-01-30drivers/ddr/fsl: Modify binding registers to save time on data initYork Sun
DDR controllers always use binding register to determine the memory space to perform data initialization. In case of controller interleaving, the space is doubled, resulting twice long wait. It wasn't too bad until the memory capacity increases. To reduce the wait time, reduce the binding space to half and restore it after data initialization. Three-way interleaving is no longer used and is removed. Signed-off-by: York Sun <york.sun@nxp.com>
2018-01-30drivers/ddr/fsl: Add calculation of register control wordsYork Sun
DDR4 RDIMM has some information in SPD to be used to calculate the control words for register chip. The rest can be found from JEDEC spec DDR4RCD02. Signed-off-by: York Sun <york.sun@nxp.com>
2018-01-30drivers/ddr/fsl: Add 3DS RDIMM supportYork Sun
On top of RDIMM support, add new register calculation to support 3DS RDIMMs. Only symmetrical 3DS is supported at this time. Signed-off-by: York Sun <york.sun@nxp.com>
2018-01-30drivers/ddr/fsl: Fix workaround for A009803York Sun
Wrong field was masked in this workaround due to wrong endianness. The impacted SoCs have big-endian. Signed-off-by: York Sun <york.sun@nxp.com>
2018-01-30drivers/ddr/fsl: Fix DDR4 RDIMM supportYork Sun
For DDR4, command/address delay in mode registers and parity latency in timing config register are only needed for UDIMMs, but not RDIMMs. Add additional register rcw_3 for DDR4 RDIMM. Fix mirrored bit for dual rank RDIMMs. Set sdram_cfg_3[DIS_MRS_PAR] for RDIMMs. Fix calculation of timing config registers. Use hexadecimal format for printing RCW (register control word) registers. Signed-off-by: York Sun <york.sun@nxp.com>
2018-01-27Merge git://git.denx.de/u-boot-socfpgaTom Rini
2018-01-26Merge git://git.denx.de/u-boot-spiTom Rini
2018-01-25ddr: altera: silence PHY calibration unless in debug modeGoldschmidt Simon
This driver has been using printf() including filename since it was added. Convert to using debug() instead. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
2018-01-24wait_bit: use wait_for_bit_le32 and remove wait_for_bitÁlvaro Fernández Rojas
wait_for_bit callers use the 32 bit LE version Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-01-23ddr: fsl: set cdr1 first in case 0.9v VDD is enabled for some SoCsRajesh Bhagat
Sets DDR configuration parameter cdr1 before all other settings to support case 0.9v VDD is enabled for some SoCs Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-19ddr: marvell: update ddr controller init and freqChris Packham
Update the calculation for tWR and tPD. This improves the DDR refresh interval and brings the initialization into line with the binary blobs currently being supplied by Marvell. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-01-19ddr: marvell: update additional ODT settingChris Packham
The RD_SAMPLE_DELAY field is 5 bits so it needs to be masked with 0x1f instead of 0xf. Rather than checking the read sample delay for all DDR chip selects use the values for the chip selects that are actually configured. Finally continue searching for the max_phase value even if the current read_sample is the same as the max_read_sample. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-01-19ddr: marvell: use correct TREFI valueChris Packham
The ternary operation had the HIGH/LOW values the wrong way round. Update it to use the correct value. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-01-19ddr: marvell: only assert M_ODT[0] on write for a single CSChris Packham
When using only a single DDR chip select only assert M_ODT[0] on write. Do not assert it on read and do not assert M_ODT[1] at all. Also set tODT_OFF_WR to 0x9 which contradicts the recommendation from the functional spec but is what Marvell's binary training blob does and seems to give better results when ODT is active during writes. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-09-11armv8: ls1088a: Add NXP LS1088A SoC supportAshish Kumar
LS1088A is compliant with the Layerscape Chassis Generation 3 with eight ARM v8 Cortex-A53 cores in 2 cluster, CCI-400, one 64-bit DDR4 SDRAM memory controller with ECC, Data path acceleration architecture 2.0 (DPAA2), Ethernet interfaces (SGMIIs, RGMIIs, QSGMIIs, XFIs), QSPI, IFC, PCIe, SATA, USB, SDXC, DUARTs etc. Signed-off-by: Alison Wang <alison.wang@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Raghav Dogra <raghav.dogra@nxp.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> [YS: Revised commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-13arm: mvebu: ddr3_debug: remove self assignmentsxypron.glpk@gmx.de
Remove superfluous self assignements. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Stefan Roese <sr@denx.de>
2017-08-13arm: mvebu: remove self assignmentxypron.glpk@gmx.de
Assigning dev_num to itself is superfluous. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Stefan Roese <sr@denx.de>
2017-07-12driver/ddr: Add support for setting timing in hws_topology_mapMarek Behún
The DDR3 training code for Marvell A38X currently computes 1t timing when given board topology map of the Turris Omnia, but Omnia needs 2t. This patch adds support for enforcing the 2t timing in struct hws_topology_map, through a new enum hws_timing, which can assume following values: HWS_TIM_DEFAULT - default behaviour, compute whether to enable 2t from the number of CSs HWS_TIM_1T - enforce 1t HWS_TIM_2T - enforce 2t This patch also sets all the board topology maps (db-88f6820-amc, db-88f6820-gp, controlcenterdc and clearfog) to have timing set to HWS_TIM_DEFAULT. Signed-off-by: Marek Behun <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2017-06-16treewide: remove unneeded semicolonsMasahiro Yamada
2017-06-12driver: ddr: fsl: Fix compiling error for DDR2York Sun
Fix compiling error of "no member named 'taamin_ps'" for DDR2. Signed-off-by: York Sun <york.sun@nxp.com>
2017-06-05common: arm: freescale: layerscape: Move header files out of common.hSimon Glass
We should not have an arch-specific header file in common.h. Adjust the board files a little so it is not needed, and drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-05common: freescale: Move arch-specific declarationsSimon Glass
The declarations should not be in common.h. Move them to the arch-specific headers. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup thinko defined(FSL_LSCH3) -> defined(CONFIG_FSL_LSCH3)] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-18Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-04-18ddr: fsl: incorrect logical constraint in populate_memctl_optionsxypron.glpk@gmx.de
(pdimm[0].data_width >= 32) || (pdimm[0].data_width <= 40) is always true. We should use && here. The problem was indicated by cppcheck. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-04-17drivers: ddr: fsl: fix unused-const-variable warningsThomas Schaefer
Depending on DDR configuration, gcc-6.x will show up unused-const- variable messages. Use __maybe_unused specifier for all dynamic_odt variable definitions to remove these warnings. Memory footprint will not increase as gcc will optimize out unused constants. Signed-off-by: Thomas Schaefer <thomas.schaefer@kontron.com> Signed-off-by: York Sun <york.sun@nxp.com>
2017-04-14Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
2017-04-14arm: socfpga: Convert Altera DDR SDRAM driver to use KconfigLey Foon Tan
Convert Altera DDR SDRAM driver to use Kconfig method. Enable ALTERA_SDRAM by default if it is on Gen5 target. Arria 10 will have different driver. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-04-13board_f: Rename initdram() to dram_init()Simon Glass
This allows us to use the same DRAM init function on all archs. Add a dummy function for arc, which does not use DRAM init here. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Dummy function on nios2] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05board_f: Drop return value from initdram()Simon Glass
At present we cannot use this function as an init sequence call without a wrapper, since it returns the RAM size. Adjust it to set the RAM size in global_data instead, and return 0 on success. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-01-04ddr: fsl: Merge macro CONFIG_NUM_DDR_CONTROLLERS and CONFIG_SYS_NUM_DDR_CTRLSYork Sun
These two macros are used for the same thing, the total number of DDR controllers for a given SoC. Use SYS_NUM_DDR_CTRLS in Kconfig and merge existing usage. Signed-off-by: York Sun <york.sun@nxp.com>
2017-01-04ddr: fsl: Move macro CONFIG_NUM_DDR_CONTROLLERS to KconfigYork Sun
Use option NUM_DDR_CONTROLLERS in ddr Kconfig and clean up existing usage in ls102xa and fsl-layerscape. Remove all powerpc macros in config header and board header files. Signed-off-by: York Sun <york.sun@nxp.com>
2017-01-04powerpc: mpc85xx: Move CONFIG_SYS_FSL_ERRATUM_* to KconfigYork Sun
Use Kconfig to select errata workaround. Signed-off-by: York Sun <york.sun@nxp.com>
2017-01-04arm: layerscape: Move CONFIG_SYS_FSL_ERRATUM_* to KconfigYork Sun
2017-01-04fsl_ddr: Move DDR config options to driver KconfigYork Sun
Create driver/ddr/fsl/Kconfig and move existing options. Clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-05fsl/ddr: Add erratum_a009942_check_cpo and clean related erratumShengzhou Liu
- add additional function erratum_a009942_check_cpo to check if the board needs tuning CPO calibration for optimal setting. - move ERRATUM_A009942(with revision to check cpo_sample option) from fsl_ddr_gen4.c to ctrl_regs.c for reuse on all DDR4/DDR3 parts. - move ERRATUM_A008378 from fsl_ddr_gen4.c to ctrl_regs.c - remove obsolete ERRATUM_A004934 which is replaced with ERRATUM_A009942. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> [YS: Replaced CONFIG_QEMU_E500 with CONFIG_ARCH_QEMU_E500] Reviewed-by: York Sun <york.sun@nxp.com>
2016-12-05fsl/ddr: Fix compiling warningShengzhou Liu
Fix following warning in case multiple erratum macro was not defined. warning: unused variable 'tmp' warning: unused variable 'ddr_freq' Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8555: Remove macro CONFIG_MPC8555York Sun
Replace CONFIG_MPC8555 with ARCH_MPC8555 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: mpc8541: Remove macro CONFIG_MPC8541York Sun
Replace CONFIG_MPC8541 with ARCH_MPC8541 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-10-27ddr: altera: Configuring SDRAM extra cycles timing parametersChin Liang See
To enable configuration of sdr.ctrlcfg.extratime1 register which enable extra clocks for read to write command timing. This is critical to ensure successful LPDDR2 interface Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2016-10-06Various, accumulated typos collected from around the tree.Robert P. J. Day
Fix various misspellings of: * deprecated * partition * preceding,preceded * preparation * its versus it's * export * existing * scenario * redundant * remaining * value * architecture Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Stefan Roese <sr@denx.de>
2016-09-26Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
trini: Drop local memset() from examples/standalone/mem_to_mem_idma2intr.c Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-26driver: ddr: fsl_mmdc: Pass board parameters through data structureYork Sun
Instead of using multiple macros, a data structure is used to pass board-specific parameters to MMDC DDR driver. Signed-off-by: York Sun <york.sun@nxp.com> CC: Shengzhou Liu <Shengzhou.Liu@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-23drivers: squash lines for immediate returnMasahiro Yamada
Remove unneeded variables and assignments. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-14ddr: fsl: fix a compile issueShaohui Xie
When CONFIG_SYS_FSL_ERRATUM_A009801 is defined but CONFIG_SYS_FSL_ERRATUM_A008511 not defined, there is compile error that temp32 undeclared, this patch fixes it. Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
