path: root/drivers/ddr
2019-03-19mv_ddr: ddr3: only use active chip-selects when tuning ODTChris Packham
Inactive chip-selects will give invalid values for read_sample so don't consider them when trying to determine the overall min/max read sample. Signed-off-by: Chris Packham <chris.packham@alliedtelesis.co.nz> [https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell/pull/18] Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2019-03-19mv_ddr: ddr3: fix tRAS timimg parameterChris Packham
Based on the JEDEC standard JESD79-3F. The tRAS timings should include the highest speed bins at a given frequency. This is similar to commit 683c67b ("mv_ddr: ddr3: fix tfaw timimg parameter") where the wrong comparison was used in the initial implementation. Signed-off-by: Chris Packham <chris.packham@alliedtelesis.co.nz> [https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell/pull/15] Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2019-03-09ddr: socfpga: Clean up ddr_setup()Marek Vasut
Replace the current rather convoluted code using ad-hoc polling mechanism with a more straightforward code. Use wait_for_bit_le32() to poll the DDRCALSTAT register instead of local reimplementation. It makes no sense to pull for 5 seconds before giving up and trying to restart the EMIF, so instead wait 500 mSec for the calibration to complete and if this fails, restart the EMIF and try again. Perform this 32 times instead of 3 times as the original code did. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Cc: Tien Fong Chee <tien.fong.chee@intel.com>
2019-03-09ddr: socfpga: Clean up EMIF resetMarek Vasut
The EMIF reset code can well use wait_for_bit_le32() instead of all that convoluted polling code. Reduce the timeout from 100 seconds to 1 second, since if the EMIF fails to reset itself in 1 second, it's unlikely longer wait would help. Make sure to clear the EMIF reset request even if the SEQ2CORE_INT_RESP_BIT isn't asserted. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Cc: Tien Fong Chee <tien.fong.chee@intel.com>
2019-03-09ddr: socfpga: Fix EMIF clear timeoutMarek Vasut
The current EMIF clear timeout handling code was applying bitwise operations to signed data types and as it was, was extremely hard to read. Replace it with simple wait_for_bit(). Expand the error handling to make it more readable too. This patch also changes the timeout for emif_clear() from 14 hours to 1 second. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Cc: Tien Fong Chee <tien.fong.chee@intel.com>
2019-03-09ddr: socfpga: Fix newline in debug print on A10Marek Vasut
The debug print is missing a newline, add it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Cc: Tien Fong Chee <tien.fong.chee@intel.com>
2019-03-09ddr: socfpga: Fix IO in Arria10 DDR driverMarek Vasut
The Altera Arria10 DDR driver was using constants in a few places instead of reading registers associated with those constants, fix this. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Cc: Tien Fong Chee <tien.fong.chee@intel.com>
2019-03-03configs: fsl: move DDR specific defines to KconfigRajesh Bhagat
Moves below DDR specific defines to Kconfig: CONFIG_FSL_DDR_BIST CONFIG_FSL_DDR_FIRST_SLOT_QUAD_CAPABLE CONFIG_FSL_DDR_INTERACTIVE CONFIG_FSL_DDR_SYNC_REFRESH Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-02-19drivers/ddr/fsl: Update fsl_ddr_board_options as weak functionPriyanka Jain
fsl_ddr_board_options is generally defined in board board's ddr.c, but some boards like lx2160ardb board does not need this function. Defining fsl_ddr_board_options as weak function to resolve compilation errors for such boards. Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> [PK: Fix checkpatch warnings] Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-01-01drivers: ddr: introduce DDR driver for i.MX8MPeng Fan
Introduce DDR driver for i.MX8M. The driver will be used by SPL to initialze DDR PHY and DDR Controller. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-12-10Merge tag 'fsl-qoriq-for-v2019.01-rc2' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
Add TFA boot flow for some Layerscape platforms Add support for lx2160a SoC [trini: Add a bunch of missing MAINTAINERS entries] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-12-09ARM: mvebu: restore license information in mv_ddr_plat.{c,h}Chris Packham
This was unintentionally removed when syncing with upstream. Signed-off-by: Chris Packham <judge.packham@gmail.com>
2018-12-08ARM: mvebu: a38x: sync ddr training code with mv_ddr-armada-18.09.02Chris Packham
This syncs drivers/ddr/marvell/a38x/ with the mv_ddr-armada-18.09 branch of https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell.git. Specifically this syncs with commit 99d772547314 ("Bump mv_ddr to release armada-18.09.2"). The complete log of changes is best obtained from the mv-ddr-marvell.git repository but some relevant highlights are: ddr3: add missing txsdll parameter ddr3: fix tfaw timimg parameter ddr3: fix trrd timimg parameter merge ddr3 topology header file with mv_ddr_topology one mv_ddr: a38x: fix zero memory size scrubbing issue The upstream code is incorporated omitting the portions not relevant to Armada-38x and DDR3. After that a semi-automated step is used to drop unused features with unifdef find drivers/ddr/marvell/a38x/ -name '*.[ch]' | \ xargs unifdef -m -UMV_DDR -UMV_DDR_ATF -UCONFIG_DDR4 \ -UCONFIG_APN806 -UCONFIG_MC_STATIC \ -UCONFIG_MC_STATIC_PRINT -UCONFIG_PHY_STATIC \ -UCONFIG_64BIT -UCONFIG_A3700 -UA3900 -UA80X0 \ -UA70X0 Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2018-12-06armv8: lx2160a: Add LX2160A SoC SupportPriyanka Jain
LX2160A Soc is based on Layerscape Chassis Generation 3.2 architecture with features: 16 ARM v8 Cortex-A72 cores in 8 cluster, CCN508, SEC, 2 64-bit DDR4 memory controller, RGMII, 8 I2C controllers, 3 serdes modules, USB 3.0, SATA, 4 PL011 SBSA UARTs, 4 TZASC instances, etc. SoC personalites: LX2120A is SoC with Twelve 64-bit ARM v8 Cortex-A72 CPUs LX2080A is SoC with Eight 64-bit ARM v8 Cortex-A72 CPUs Signed-off-by: Bao Xiaowei <xiaowei.bao@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Signed-off-by: Meenakshi Aggarwal <meenakshi.aggarwal@nxp.com> Signed-off-by: Vabhav Sharma <vabhav.sharma@nxp.com> Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-09-15socfpga: stratix10: fix sdram_calculate_sizeDalon Westergreen
Incorrect type of size variable results in 0 being returned for sdram sizes greater than or equal to 4GB. Signed-off-by: Dalon Westergreen <dwesterg@gmail.com>
2018-07-26drivers/ddr/fsl: fix '__hwconfig without a buffer' messagesJeremy Gebben
Pass an empty buffer instead of NULL if the hwconfig environment variable isn't set. Signed-off-by: Jeremy Gebben <jgebben@sweptlaser.com> Cc: Stefano Babic <sbabic@denx.de> Cc: York Sun <york.sun@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-07-12ddr: altera: Add ECC DRAM scrubbing support for Arria10Marek Vasut
The SDRAM must first be rewritten by zeroes if ECC is used to initialize the ECC metadata. Make the CPU overwrite the DRAM with zeroes in such a case. This scrubbing implementation turns the caches on temporarily, then overwrites the whole RAM with zeroes, flushes the caches and turns them off again. This provides satisfactory performance. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org>
2018-07-12ddr: altera: Drop custom dram_bank_mmu_setup() on Arria10Marek Vasut
This function was never used in SPL and the default implementation of dram_bank_mmu_setup() does the same thing. The only difference is the part which configures OCRAM as cachable, which doesn't really work as it covers more than the OCRAM. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org>
2018-07-12ddr: altera: stratix10: Add DDR support for Stratix10 SoCLey Foon Tan
Add DDR support for Stratix SoC Signed-off-by: Chin Liang See <chin.liang.see@intel.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2018-05-20SPDX: Fixup SPDX tags in a few new filesTom Rini
2018-05-18configs: Add DDR Kconfig support for Arria 10Tien Fong Chee
This patch enables DDR Kconfig support for Arria 10. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Dinh Nguyen <dinguyen@kernel.org>
2018-05-18ARM: socfpga: Add DDR driver for Arria 10Tien Fong Chee
Add DDR driver support for Arria 10. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
2018-05-18ARM: socfpga: Rename the gen5 sdram driver to more specific nameTien Fong Chee
Current sdram driver is only applied to gen5 device, hence it is better to rename sdram driver to more specific name which is related to gen5 device. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
2018-05-15ARM: mvebu: a38x: Add missing SPDX license identfierChris Packham
mv_ddr_build_message.c is generated in Marvell's standalone mv_ddr code. When imported into u-boot we need to add the appropriate SPDX tag and re-format it slightly. Signed-off-by: Chris Packham <judge.packham@gmail.com>
2018-05-14ARM: mvebu: a38x: use non-zero size for ddr scrubbingChris Packham
Make ddr3_calc_mem_cs_size() global scope and use it in ddr3_new_tip_ecc_scrub to correctly initialize all of DDR memory. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-14ARM: mvebu: a38x: restore support for setting timingChris Packham
This restores support for configuring the timing mode based on the ddr_topology. This was originally implemented in commit 90bcc3d38d2b ("driver/ddr: Add support for setting timing in hws_topology_map") but was removed as part of the upstream sync. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-14ARM: mvebu: a38x: sync ddr training code with upstreamChris Packham
This syncs drivers/ddr/marvell/a38x/ with the mv_ddr-armada-17.10 branch of https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell.git. The upstream code is incorporated omitting the ddr4 and apn806 and folding the nested a38x directory up one level. After that a semi-automated step is used to drop unused features with unifdef find drivers/ddr/marvell/a38x/ -name '*.[ch]' | \ xargs unifdef -m -UMV_DDR -UMV_DDR_ATF -UCONFIG_DDR4 \ -UCONFIG_APN806 -UCONFIG_MC_STATIC \ -UCONFIG_MC_STATIC_PRINT -UCONFIG_PHY_STATIC \ -UCONFIG_64BIT INTER_REGS_BASE is updated to be defined as SOC_REGS_PHY_BASE. Some now empty files are removed and the ternary license is replaced with a SPDX GPL-2.0+ identifier. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-14ARM: mvebu: a38x: remove some unused codeChris Packham
No in-tree code defines SUPPORT_STATIC_DUNIT_CONFIG or STATIC_ALGO_SUPPORT. Remove ddr3_a38x_mc_static.h and use unifdef to remove unused sections in the rest of the ddr/marvell/a38x code. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-14ARM: mvebu: a38x: move sys_env_device_rev_getChris Packham
Move sys_env_device_rev_get() from the ddr training code to sys_env_lib.c (which currently resides with the serdes code). This brings sys_env_device_rev_get() into line with sys_env_device_id_get() and sys_env_model_get(). Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-14ARM: mvebu: a38x: move definition of PEX_CFG_DIRECT_ACCESSChris Packham
PEX_CFG_DIRECT_ACCESS was defined in ddr3_hws_hw_training_def.h despite only being used in the serdes code. Move this definition to ctrl_pex.h where all the other PEX defines are. Also remove the duplicate definition of PEX_DEVICE_AND_VENDOR_ID which is already defined in ctrl_pex.h. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-14Revert "drivers/ddr/fsl: Dual-license DDR driver"Tom Rini
Upon further review, not all code authors are in favour of this change. This reverts commit ee3556bcafbb05e59aabdc31368984e76acaabc4. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-09drivers/ddr/fsl: Dual-license DDR driverYork Sun
To make this driver easier to be reused, dual-license DDR driver. Signed-off-by: York Sun <york.sun@nxp.com> CC: Simon Glass <sjg@chromium.org> CC: Tom Rini <trini@konsulko.com> CC: Heinrich Schuchardt <xypron.glpk@gmx.de> CC: Thomas Schaefer <thomas.schaefer@kontron.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Robert P. J. Day <rpjday@crashcourse.ca> CC: Alexander Merkle <alexander.merkle@lauterbach.com> CC: Joakim Tjernlund <joakim.tjernlund@transmode.se> CC: Curt Brune <curt@cumulusnetworks.com> CC: Valentin Longchamp <valentin.longchamp@keymile.com> CC: Wolfgang Denk <wd@denx.de> CC: Anatolij Gustschin <agust@denx.de> CC: Ira W. Snyder <iws@ovro.caltech.edu> CC: Marek Vasut <marek.vasut@gmail.com> CC: Kyle Moffett <Kyle.D.Moffett@boeing.com> CC: Sebastien Carlier <sebastien.carlier@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Peter Tyser <ptyser@xes-inc.com> CC: Paul Gortmaker <paul.gortmaker@windriver.com> CC: Peter Tyser <ptyser@xes-inc.com> CC: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2018-01-30drivers/ddr/fsl: Cleanup unused variableYork Sun
Variable "row_density" is no longer used. Drop it from DIMM structure. Signed-off-by: York Sun <york.sun@nxp.com>
2018-01-30drivers/ddr/fsl: Modify binding registers to save time on data initYork Sun
DDR controllers always use binding register to determine the memory space to perform data initialization. In case of controller interleaving, the space is doubled, resulting twice long wait. It wasn't too bad until the memory capacity increases. To reduce the wait time, reduce the binding space to half and restore it after data initialization. Three-way interleaving is no longer used and is removed. Signed-off-by: York Sun <york.sun@nxp.com>
2018-01-30drivers/ddr/fsl: Add calculation of register control wordsYork Sun
DDR4 RDIMM has some information in SPD to be used to calculate the control words for register chip. The rest can be found from JEDEC spec DDR4RCD02. Signed-off-by: York Sun <york.sun@nxp.com>
2018-01-30drivers/ddr/fsl: Add 3DS RDIMM supportYork Sun
On top of RDIMM support, add new register calculation to support 3DS RDIMMs. Only symmetrical 3DS is supported at this time. Signed-off-by: York Sun <york.sun@nxp.com>
2018-01-30drivers/ddr/fsl: Fix workaround for A009803York Sun
Wrong field was masked in this workaround due to wrong endianness. The impacted SoCs have big-endian. Signed-off-by: York Sun <york.sun@nxp.com>
2018-01-30drivers/ddr/fsl: Fix DDR4 RDIMM supportYork Sun
For DDR4, command/address delay in mode registers and parity latency in timing config register are only needed for UDIMMs, but not RDIMMs. Add additional register rcw_3 for DDR4 RDIMM. Fix mirrored bit for dual rank RDIMMs. Set sdram_cfg_3[DIS_MRS_PAR] for RDIMMs. Fix calculation of timing config registers. Use hexadecimal format for printing RCW (register control word) registers. Signed-off-by: York Sun <york.sun@nxp.com>
2018-01-27Merge git://git.denx.de/u-boot-socfpgaTom Rini
2018-01-26Merge git://git.denx.de/u-boot-spiTom Rini
2018-01-25ddr: altera: silence PHY calibration unless in debug modeGoldschmidt Simon
This driver has been using printf() including filename since it was added. Convert to using debug() instead. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
2018-01-24wait_bit: use wait_for_bit_le32 and remove wait_for_bitÁlvaro Fernández Rojas
wait_for_bit callers use the 32 bit LE version Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-01-23ddr: fsl: set cdr1 first in case 0.9v VDD is enabled for some SoCsRajesh Bhagat
Sets DDR configuration parameter cdr1 before all other settings to support case 0.9v VDD is enabled for some SoCs Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-19ddr: marvell: update ddr controller init and freqChris Packham
Update the calculation for tWR and tPD. This improves the DDR refresh interval and brings the initialization into line with the binary blobs currently being supplied by Marvell. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-01-19ddr: marvell: update additional ODT settingChris Packham
The RD_SAMPLE_DELAY field is 5 bits so it needs to be masked with 0x1f instead of 0xf. Rather than checking the read sample delay for all DDR chip selects use the values for the chip selects that are actually configured. Finally continue searching for the max_phase value even if the current read_sample is the same as the max_read_sample. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-01-19ddr: marvell: use correct TREFI valueChris Packham
The ternary operation had the HIGH/LOW values the wrong way round. Update it to use the correct value. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-01-19ddr: marvell: only assert M_ODT[0] on write for a single CSChris Packham
When using only a single DDR chip select only assert M_ODT[0] on write. Do not assert it on read and do not assert M_ODT[1] at all. Also set tODT_OFF_WR to 0x9 which contradicts the recommendation from the functional spec but is what Marvell's binary training blob does and seems to give better results when ODT is active during writes. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-09-11armv8: ls1088a: Add NXP LS1088A SoC supportAshish Kumar
LS1088A is compliant with the Layerscape Chassis Generation 3 with eight ARM v8 Cortex-A53 cores in 2 cluster, CCI-400, one 64-bit DDR4 SDRAM memory controller with ECC, Data path acceleration architecture 2.0 (DPAA2), Ethernet interfaces (SGMIIs, RGMIIs, QSGMIIs, XFIs), QSPI, IFC, PCIe, SATA, USB, SDXC, DUARTs etc. Signed-off-by: Alison Wang <alison.wang@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Raghav Dogra <raghav.dogra@nxp.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> [YS: Revised commit message] Reviewed-by: York Sun <york.sun@nxp.com>
