path: root/drivers/ddr
2014-12-15driver/ddr/fsl: Fix MRC_CYC calculation for DDR3York Sun
For DDR controller version 4.7 or newer, MRC_CYC (mode register set cycle time) is max(tMRD, tMOD). tMRD is 4nCK, or 8nCK (RDIMM). tMOD is max(12nCK, 15ns) according to JEDEC spec. DDR4 is not affected by this change. Signed-off-by: York Sun <yorksun@freescale.com>
2014-12-11fsl/sleep: updated the deep sleep framework for QorIQ platformsTang Yuantian
With the introducing of generic board and ARM-based cores, current deep sleep framework doesn't work anymore. This patch will convert the current framework to adapt this change. Basically it does: 1. Converts all the Freescale's DDR driver to support deep sleep. 2. Added basic framework support for ARM-based and PPC-based cores separately. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05driver/ddr/fsl: Add workaround for faulty SPDYork Sun
Some UDIMMs have faulty SPD with wrong mapping for DQ[36-39]. Using raw card spec in case this error is detected. Signed-off-by: York Sun <yorksun@freescale.com>
2014-12-05driver/ddr/fsl: Adjust timing_cfg_0 to better support two DDR slotsYork Sun
Increase write-to-write and read-to-read turnaround time for two-slot DDR configurations. Previously only quad-rank and two dual-rank configurations have this additional turnaround time. A recent test on two single-rank DIMMs shows the shorter additional turnaround time is also needed. Signed-off-by: York Sun <yorksun@freescale.com>
2014-11-23linux/kernel.h: sync min, max, min3, max3 macros with LinuxMasahiro Yamada
U-Boot has never cared about the type when we get max/min of two values, but Linux Kernel does. This commit gets min, max, min3, max3 macros synced with the kernel introducing type checks. Many of references of those macros must be fixed to suppress warnings. We have two options: - Use min, max, min3, max3 only when the arguments have the same type (or add casts to the arguments) - Use min_t/max_t instead with the appropriate type for the first argument Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [trini: Fixup arch/blackfin/lib/string.c] Signed-off-by: Tom Rini <trini@ti.com>
2014-09-25driver/ddr/fsl: Fix DDR4 driverYork Sun
When accumulated ECC is enabled, the DQ_MAP for ECC[4:7] needs to be set to 0, i.e. 0->0, 1->1, etc., required by controller logic, even these pins are not actually connected. Also fix a bug when reading from DDR register to use proper accessor for correct endianess. Signed-off-by: York Sun <yorksun@freescale.com>
2014-09-25driver/ddr/fsl: Fix tXP and tCKEYork Sun
The driver was written using old DDR3 spec which only covers low speeds. The value would be suboptimal for higher speeds. Fix both timing according to latest DDR3 spec, remove tCKE as an config option. Signed-off-by: York Sun <yorksun@freescale.com>
2014-09-25driver/ddr: Restruct driver to allow standalone memory spaceYork Sun
U-boot has been initializing DDR for the main memory. The presumption is the memory stays as a big continuous block, either linear or interleaved. This change is to support putting some DDR controllers to separated space without counting into main memory. The standalone memory controller could use different number of DIMM slots. Signed-off-by: York Sun <yorksun@freescale.com>
2014-09-08driver/ddr/fsl: Add support of overriding chip select write levelingYork Sun
JEDEC spec allows DRAM vendors to use prime DQ for write leveling. This is not an issue unless some DQ pins are not connected. If a platform uses regular DIMMs but with reduced DDR ECC pins, the prime DQ may end up on those floating pins for the second rank. The workaround is to use a known good chip select for this purpose. Signed-off-by: York Sun <yorksun@freescale.com>
2014-09-08driver/ddr/freescale: Fix DDR3 driver for ARMYork Sun
Reading DDR register should use ddr_in32() for proper endianess. This patch fixes incorrect waiting time for ARM platforms. Signed-off-by: York Sun <yorksun@freescale.com>
2014-09-08driver/ddr/freescale: Add support of accumulate ECCYork Sun
If less than 8 ECC pins are used for DDR data bus width smaller than 64 bits, the 8-bit ECC code will be transmitted/received across several beats, and it will be used to check 64-bits of data once 8-bits of ECC are accumulated. Signed-off-by: York Sun <yorksun@freescale.com>
2014-07-22driver/ddr: Fix DDR register timing_cfg_8York Sun
The field wrtord_bg should add 2 clocks if on the fly chop is enabled, according to DDR controller manual for DDR4. Signed-off-by: York Sun <yorksun@freescale.com>
2014-07-22driver/ddr: Fix DDR4 driver for ARMYork Sun
Previously the driver was only tested on Power SoCs. Different barrier instructions are needed for ARM SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2014-06-05driver/ddr/fsl: Fix printing unspecified module info for DDR4York Sun
The offset of module information is at 128, different from DDR3. Signed-off-by: York Sun <yorksun@freescale.com>
2014-06-05powerpc/mpc85xx: Add workaround for DDR erratum A004508York Sun
When the DDR controller is initialized below a junction temperature of 0°C and then operated above a junction temperature of 65°C, the DDR controller may cause receive data errors, resulting ECC errors and/or corrupted data. This erratum applies to the following SoCs and their variants: MPC8536, MPC8569, MPC8572, P1010, P1020, P1021, P1022, P1023, P2020. Signed-off-by: York Sun <yorksun@freescale.com>
2014-05-29Add cli_ prefix to readline functionsSimon Glass
This makes it clear where the code resides. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29move CLI prototypes to cli.h and add commentsSimon Glass
Move the CLI prototypes from common.h to cli.h as part of an effort to reduce the size of common.h. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-04-22mpc85xx/t104x: Add deep sleep framework supportTang Yuantian
When T104x soc wakes up from deep sleep, control is passed to the primary core that starts executing uboot. After re-initialized some IP blocks, like DDRC, kernel will take responsibility to continue to restore environment it leaves before. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22drivers/ddr: Fix possible out of bounds errorYork Sun
This is a theoretical possible out of bounds error in DDR driver. Adding check before using array index. Also change some runtime conditions to pre-compiling conditions. Signed-off-by: York Sun <yorksun@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22driver/ddr/fsl: Add DDR4 support to Freescale DDR driverYork Sun
Mostly reusing DDR3 driver, this patch adds DDR4 SPD handling, register calculation and programming. Signed-off-by: York Sun <yorksun@freescale.com>
2014-02-21driver/ddr: Add 256 byte interleaving supportYork Sun
Freescale LayerScape SoCs support controller interleaving on 256 byte size. This interleaving is mandoratory. Signed-off-by: York Sun <yorksun@freescale.com>
2014-02-21Driver/ddr: Add support of different DDR base addressYork Sun
DDR base address has been the same from the view of core and DDR controllers. This has changed for Freescale ARM-based SoCs. Controllers setup DDR memory in a contiguous space and cores view it at separated locations. Signed-off-by: York Sun <yorksun@freescale.com>
2014-02-21driver/ddr: Change Freescale ARM DDR driver to support both big and little ↵York Sun
endian Initially it was believed the DDR controller on Freescale ARM would have big endian. But some platform will have little endian. Signed-off-by: York Sun <yorksun@freescale.com>
2014-01-21powerpc/mpc85xx: Revise workaround for DDR-A003York Sun
Existing workaround only handles one RDIMM on reference design. In case of two RDIMMs being used, the workaround requires two separate writes to DDR_SDRAM_MD_CNTL register. This patch also restores two debug registers changed by the workaround. Signed-off-by: York Sun <yorksun@freescale.com> CC: Ben Collins <ben.c@servergy.com> CC: James Yang <James.Yang@freescale.com>
2013-11-25Driver/DDR: Update DDR driver to allow non-zero base addressYork Sun
The DRAM base has been zero for Power SoCs. It could be non-zero for ARM SoCs. Use a macro instead of hard-coding to zero. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25powerpc/mpc8xxx: Extend DDR registers' fieldsYork Sun
Some DDR registers' fields have expanded to accommodate larger values. These changes are backward compatible. Some fields are removed for newer DDR controllers. Writing to those fields are safely ignored. TIMING_CFG_2 register is fixed. Additive latency is added to RD_TO_PRE automatically. It was a misunderstanding in commit c360ceac. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: Add Freescale DDR driver for ARMYork Sun
Make PowerPC specific code conditional so ARM SoCs can reuse this driver. Add DDR3 driver for ARM. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: combine ccsr_ddr for 83xx, 85xx and 86xxYork Sun
Fix ccsr_ddr structure to avoid using typedef. Combine DDR2 and DDR3 structure for 83xx, 85xx and 86xx. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
