path: root/drivers/cs8900.h
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2003-03-14* Avoid flicker on the TRAB's VFD by synchronizing the enable withwdenk
the HSYNC/VSYNC. Requires new CPLD code (Version 101 for Rev. 100 boards, version 153 for Rev. 200 boards). * Patch by Vladimir Gurevich, 12 Mar 2003: Fix relocation problem of statically initialized string pointers in common/cmd_pci.c * Patch by Kai-Uwe Blöm, 12 Mar 2003: Cleanup & bug fixes for JFFS2 code: - the memory mangement was broken. It caused havoc on malloc by writing beyond the block boundaries. - the length calculation for files was wrong, sometimes resulting in short file reads. - data copying now optionally takes fragment version numbers into account, to avoid copying from older data. See doc/README.JFFS2 for details.
2003-03-06* Patches by David Müller, 31 Jan 2003:LABEL_2003_03_06_2255wdenk
- minimal setup for CardBus bridges - add EEPROM read/write support in the CS8900 driver - add support for the builtin I2C controller in the Samsung s3c24x0 chips - add support for MPL's VCMA9 (Samsung s3c2410 based) board * Patch by Steven Scholz, 04 Feb 2003: add support for RTC DS1307 * Patch by Reinhard Meyer, 5 Feb 2003: fix PLPRCR/SCCR init sequence on 8xx to allow for changes of EBDF by software * Patch by Vladimir Gurevich, 07 Feb 2003: "API-compatibility patch" for 4xx I2C driver
