path: root/drivers/crypto/fsl/jr.h
2019-06-11Revert "drivers/crypto/fsl: assign job-rings to non-TrustZone"Breno Matheus Lima
Commit 22191ac35344 ("drivers/crypto/fsl: assign job-rings to non-TrustZone") breaks HABv4 encrypted boot support in the following i.MX devices: - i.MX6UL - i.MX7S - i.MX7D - i.MX7ULP For preparing a HABv4 encrypted boot image it's necessary to encapsulate the generated DEK in a blob. In devices listed above the blob generation function takes into consideration the Job Ring TrustZone ownership configuration (JROWN_NS) and can be only decapsulated by the same configuration. The ROM code expects DEK blobs encapsulated by the Secure World environments which commonly have JROWN_NS = 0. As U-Boot is running in Secure World we must have JROWN_NS = 0 so the blobs generated by dek_blob tool can be decapsulated by the ROM code. Job-rings assignment is now handled in OP-TEE OS, this commit can be safely reverted. https://github.com/OP-TEE/optee_os/pull/2986 This reverts commit 22191ac353445ad8fafc5a78aefcd94e78963041. Signed-off-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Fabio Estevam <festevam@gmail.com> Acked-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org>
2018-02-09crypto/fsl: instantiate all rng state handlesLukas Auer
Extend the instantiate_rng() function and the corresponding CAAM job descriptor to instantiate all RNG state handles. This moves the RNG instantiation code in line with the CAAM kernel driver. Previously, only the first state handle was instantiated. The second one was instantiated by the CAAM kernel driver. This works if the kernel runs in secure mode, but fails in non-secure mode since the kernel driver uses DEC0 directly instead of over the job ring interface. Instantiating all RNG state handles in u-boot removes the need for using DEC0 in the kernel driver, making it possible to use the CAAM in non-secure mode. Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Tested-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org> Reviewed-by: York Sun <york.sun@nxp.com>
2018-02-04drivers/crypto/fsl: assign job-rings to non-TrustZoneBryan O'Donoghue
After enabling TrustZone various parts of the CAAM silicon become inaccessible to non TrustZone contexts. The job-ring registers are designed to allow non TrustZone contexts like Linux to still submit jobs to CAAM even after TrustZone has been enabled. The default job-ring permissions after the BootROM look like this for job-ring zero. ms=0x00008001 ls=0x00008001 The MS field is JRaMIDR_MS (job ring MID most significant). Referring to "Security Reference Manual for i.MX 7Dual and 7Solo Applications Processors, Rev. 0, 03/2017" section 8.10.4 we see that JROWN_NS controls whether or not a job-ring is accessible from non TrustZone. Bit 15 (TrustZone) is the logical inverse of bit 3 hence the above value of 0x8001 shows that JROWN_NS=0 and TrustZone=1. Clearly then as soon as TrustZone becomes active the job-ring registers are no longer accessible from Linux, which is not what we want. This patch explicitly sets all job-ring registers to JROWN_NS=1 (non TrustZone) by default and to the Non-Secure MID 001. Both settings are required to successfully assign a job-ring to non-secure mode. If a piece of TrustZone firmware requires ownership of job-ring registers it can unset the JROWN_NS bit itself. This patch in conjunction with a modification of the Linux kernel to skip HWRNG initialisation makes CAAM usable to Linux with TrustZone enabled. Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Peng Fan <peng.fan@nxp.com> Cc: Alex Porosanu <alexandru.porosanu@nxp.com> Cc: Ruchika Gupta <ruchika.gupta@nxp.com> Cc: Aneesh Bansal <aneesh.bansal@nxp.com> Link: https://github.com/OP-TEE/optee_os/issues/1408 Link: https://tinyurl.com/yam5gv9a Tested-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
2016-05-18crypto/fsl: add support for multiple SEC engines initializationAlex Porosanu
For SoCs that contain multiple SEC engines, each of them needs to be initialized (by means of initializing among others the random number generator). Signed-off-by: Alex Porosanu <alexandru.porosanu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29crypto/fsl: Make CAAM transactions cacheableSaksham Jain
This commit solves CAAM coherency issue on ls2080. When caches are enabled and CAAM's DMA's AXI transcations are not made cacheable, Core reads/writes data from/to caches and CAAM does from main memory. This forces data flushes to synchronize various data structures. But even if any data in proximity of these structures is read by core, these structures again are fetched in caches. To avoid this problem, either all the data that CAAM accesses can be made cache line aligned or CAAM transcations can be made cacheable. So, this commit makes CAAM transcations as write back with write and read allocate. Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-24drivers/crypto/fsl : Allocate output ring with size aligned to CACHELNE SIZERuchika Gupta
The output ring needs to be invalidated before enqueuing the job to SEC. While allocation of space to output ring, it should be taken care that the size is cacheline size aligned inorder to prevent invalidating valid data. The patch also correct the method of aligning end of structs while flushing caches Since start = align(start_of_struct), it is incorrect to assign end = align(start + struct_size). It should instead be, end = align(start_of_struct + struct_size). Signed-off-by: Saksham Jain <saksham@nxp.com> Signed-off-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-10-29crypto/fsl: SEC driver cleanup for 64 bit and endiannessAneesh Bansal
The SEC driver code has been cleaned up to work for 64 bit physical addresses and systems where endianess of SEC block is different from the Core. Changes: 1. Descriptor created on Core is modified as per SEC block endianness before the job is submitted. 2. The read/write of physical addresses to Job Rings will be depend on endianness of SEC block as 32 bit low and high part of the 64 bit address will vary. 3. The 32 bit low and high part of the 64 bit address in descriptor will vary depending on endianness of SEC. Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-08-03drivers/crypto/fsl: fix snooping for write transactionshoria.geanta@freescale.com
HW coherency won't work properly for CAAM write transactions if AWCACHE is left to default (POR) value - 4'b0001. It has to be programmed to 4'b0010. For platforms that have HW coherency support: -PPC-based: the update has no effect; CAAM coherency already works due to the IOMMU (PAMU) driver setting the correct memory coherency attributes -ARM-based: the update fixes cache coherency issues, since IOMMU (SMMU) driver is not programmed to behave similar to PAMU Fixes: b9eebfade974c ("fsl_sec: Add hardware accelerated SHA256 and SHA1") Signed-off-by: Horia Geantă <horia.geanta@freescale.com> Reviewed-by: Aneesh Bansal <aneesh.bansal@freescale.com> Reviewed-by: Mingkai Hu <Mingkai.Hu@freescale.com> Acked-by: Ruchika Gupta<ruchika.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-10-16fsl_sec: Add hardware accelerated SHA256 and SHA1Ruchika Gupta
SHA-256 and SHA-1 accelerated using SEC hardware in Freescale SoC's The driver for SEC (CAAM) IP is based on linux drivers/crypto/caam. The platforms needto add the MACRO CONFIG_FSL_CAAM inorder to enable initialization of this hardware IP. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
