path: root/drivers/cpu
2018-06-01cpu: bmips: convert to use live dtÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-21dm: cpu: bmips: add BCM6362 supportÁlvaro Fernández Rojas
2018-01-26dm: cpu: bmips: add BCM6318 supportÁlvaro Fernández Rojas
2018-01-26dm: cpu: bmips: add BCM6368 supportÁlvaro Fernández Rojas
2017-06-01dm: core: Update device_bind_driver_to_node() to use ofnodeSimon Glass
Adjust this function to us an ofnode instead of an offset, so it can be used with livetree. This involves updating all callers. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Rename dev_addr..() functionsSimon Glass
These support the flat device tree. We want to use the dev_read_..() prefix for functions that support both flat tree and live tree. So rename the existing functions to avoid confusion. In the end we will have: 1. dev_read_addr...() - works on devices, supports flat/live tree 2. devfdt_get_addr...() - current functions, flat tree only 3. of_get_address() etc. - new functions, live tree only All drivers will be written to use 1. That function will in turn call either 2 or 3 depending on whether the flat or live tree is in use. Note this involves changing some dead code - the imx_lpi2c.c file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-31dm: cpu: bmips: add BCM6338 supportÁlvaro Fernández Rojas
BCM6338 has a fixed CPU frequency of 240 MHz. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-31dm: cpu: bmips: add BCM3380 supportÁlvaro Fernández Rojas
As far as I know BCM3380 has a fixed CPU frequency since I couldn't find its PLL registers in any documentation. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-31dm: cpu: bmips: add BCM6348 supportÁlvaro Fernández Rojas
2017-05-31dm: cpu: bmips: rename cpu_desc specific functionsÁlvaro Fernández Rojas
Use a generic name for cpu_desc functions instead of using a specific SoC one. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-10cpu: add CPU driver for Broadcom MIPS SoCsÁlvaro Fernández Rojas
2016-10-19cpu: Add get_vendor callbackAlexander Graf
The CPU udevice already has a few callbacks to retreive information about the currently running CPUs. This patch adds a new get_vendor() call that returns the vendor of the main CPUs. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-14x86: Move MP initialization codes into a common placeBin Meng
Most of the MP initialization codes in arch/x86/cpu/baytrail/cpu.c is common to all x86 processors, except detect_num_cpus() which varies from cpu to cpu. Move these to arch/x86/cpu/cpu.c and implement the new 'get_count' method for baytrail and cpu_x86 drivers. Now we call cpu_get_count() in mp_init() to get the number of CPUs. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-14dm: cpu: Add a new get_count method to cpu uclassBin Meng
Introduce a new method 'get_count' in the UCLASS_CPU ops to get the number of CPUs in the system. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-14dm: cpu: Test against cpu_ops->get_info in cpu_get_info()Bin Meng
In cpu_get_info() it wrongly tests against cpu_ops->get_desc to see if it is NULL. It should test against cpu_ops->get_info. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-14dm: cpu: Fix undefined ENOSYS build errorBin Meng
Include <errno.h> otherwise ENOSYS is undefined. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29dm: Implement a CPU uclassSimon Glass
It is useful to be able to keep track of the available CPUs in a multi-CPU system. This uclass is mostly intended for use with SMP systems. The uclass provides methods for getting basic information about each CPU. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
