path: root/drivers/core/fdtaddr.c
2018-06-01dm: core: add functions to get memory-mapped I/O addressesÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-01core: ofnode: Fix translation for #size-cells == 0Mario Six
Commit 286ede6 ("drivers: core: Add translation in live tree case") made dev_get_addr always use proper bus translations for addresses read from the device tree. But this leads to problems with certain busses, e.g. I2C busses, which run into an error during translation, and hence stop working. It turns out that of_translate_address() and fdt_translate_address() stop the address translation with an error when they're asked to translate addresses for busses where #size-cells == 0 (comment from drivers/core/of_addr.c): * Note: We consider that crossing any level with #size-cells == 0 to mean * that translation is impossible (that is we are not dealing with a value * that can be mapped to a cpu physical address). This is not really specified * that way, but this is traditionally the way IBM at least do things To fix this case, we check in both the live-tree and non-live tree-case, whether the bus of the device whose address is about to be translated has size-cell size zero. If this is the case, we just read the address as a plain integer and return it, and only apply bus translations if the size-cell size if greater than zero. Signed-off-by: Mario Six <mario.six@gdsys.cc> Signed-off-by: Martin Fuzzey <mfuzzey@parkeon.com> Reported-by: Martin Fuzzey <mfuzzey@parkeon.com> Fixes: 286ede6 ("drivers: core: Add translation in live tree case") Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: Rename dev_addr..() functionsSimon Glass
These support the flat device tree. We want to use the dev_read_..() prefix for functions that support both flat tree and live tree. So rename the existing functions to avoid confusion. In the end we will have: 1. dev_read_addr...() - works on devices, supports flat/live tree 2. devfdt_get_addr...() - current functions, flat tree only 3. of_get_address() etc. - new functions, live tree only All drivers will be written to use 1. That function will in turn call either 2 or 3 depending on whether the flat or live tree is in use. Note this involves changing some dead code - the imx_lpi2c.c file. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: core: Move dev_get_addr() etc. into a separate fileSimon Glass
Move this group of address-related functions into a new file. These use the flat device tree. Future work will provide new versions of these which can support the live tree. Signed-off-by: Simon Glass <sjg@chromium.org>
