path: root/drivers/clk/renesas
2019-08-09clk: renesas: Add R8A77980 V3H clock tablesMarek Vasut
Import R8A77980 V3H clock tables from Linux 5.2.7 , commit 5697a9d3d55f. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-04-09clk: renesas: Synchronize Gen3 tables with Linux 5.0Marek Vasut
Synchronize R-Car Gen3 clock tables with Linux 5.0, commit 1c163f4c7b3f621efff9b28a47abb36f7378d783 . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-04-09clk: renesas: Synchronize Gen2 tables with Linux 5.0Marek Vasut
Synchronize R-Car Gen2 clock tables with Linux 5.0, commit 1c163f4c7b3f621efff9b28a47abb36f7378d783 . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-04-09clk: renesas: Add R8A77965 clock tablesMarek Vasut
Add clock tables for R8A77965 from Linux 5.0 , except for the crit, R and Z clock, which are neither used nor supported by the U-Boot clock framework yet. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-03-25clk: renesas: Add support for setting MMCIF clock divider on Gen2Marek Vasut
Add code for configuring the MMC0CKCR/MMC1CKCR on Gen2 platforms. This allows the MMCIF driver to set higher clock rate if desired. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-03-25clk: renesas: Fix swapped div and mul in debug output on Gen2Marek Vasut
The $div and $mul values were swapped in the debug output, fix this. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-03-25clk: renesas: Fix SDH clock divider decoding on Gen2Marek Vasut
The gen2_clk_get_sdh_div() function is supposed to look up the $val value read out of the SDCKCR register in the supplied table and return the matching divider value. The current implementation was matching the value from SDCKCR on the divider value in the table, which is wrong. Fix this and rework the function a bit to make it more readable. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-02-25clk: rmobile: Drop def_bool per SoCMarek Vasut
Drop per SoC def_bool on each driver, since this is now implied by SoC Kconfig option instead. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-12-03clk: renesas: Allow reconfiguring SDHI clock on Gen3Marek Vasut
The SDHI clock must be configured differently for HS200/HS400/SDR104 modes. Add support for reconfiguring the SDHI clock settings into the clock driver. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-06-14clk: rmobile: Add R8A77995 RPC clockMarek Vasut
Add missing RPC entry into the R8A77995 clock driver tables. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-06-14clk: rmobile: Add R8A77990 RPC clockMarek Vasut
Add missing RPC entry into the R8A77990 clock driver tables. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-06-02Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
2018-06-01clk: renesas: Add R8A77990 E3 clock tablesMarek Vasut
Add clock tables for R8A77990 E3 SoC . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-06-01clk: renesas: Add PE clock handlingMarek Vasut
The PE clock have two parents, add support for picking the correct one and deriving the clock from it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-06-01clk: renesas: Add PLL1 and PLL3 dividersMarek Vasut
Add and use the PLL1 and PLL3 dividers. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-06-01clk: renesas: Pass clock rate around as 64bit number internallyMarek Vasut
The PLL rate could be in the GHz range, which could overflow a 32bit data type. Since the hardware is 64bit anyway, pass the clock rates as 64bit number internally to avoid this. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-06-01clk: renesas: Fix swapped arguments in debug messageMarek Vasut
The mul and div arguments were reported in reverse order in the debug message, swap them to fix this. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-05-02clk: renesas: Drop USB extal from the R8A7792 clock driverMarek Vasut
The R8A7792 does not have the USB extal, so drop it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-21clk: renesas: Minor clean up of the R8A7794 clock driverMarek Vasut
The initconst is not used in U-Boot, drop it. The r8a7794_crit_mod_clks is also not used in U-Boot, so drop it too. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-21clk: renesas: Minor clean up of the R8A7792 clock driverMarek Vasut
The initconst is not used in U-Boot, drop it. The r8a7792_crit_mod_clks is also not used in U-Boot, so drop it too. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-13clk: renesas: Minor clean up of the R8A7790 clock driverMarek Vasut
The initconst is not used in U-Boot, drop it. The r8a7790_crit_mod_clks is also not used in U-Boot, so drop it too. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-03-05clk: renesas: Add R8A77965 M3N entriesMarek Vasut
Add entries for the R8A77965 M3N SoC. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-02-16clk: rmobile: Assure SD-IF clock are configured correctlyMarek Vasut
The SD driver calls clk_set_rate() before clk_enable(), yet clk_set_rate() implementation in the clock driver does not set the SD-IF divider. Fix it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-27Merge branch 'rmobile-mx' of git://git.denx.de/u-boot-shTom Rini
2018-01-24clk: renesas: Import R8A7794 E2 clock tablesMarek Vasut
Import clock tables for R8A7794 E2 SoC from upstream Linux kernel v4.15-rc8, commit bebc6082da0a9f5d47a1ea2edc099bf671058bd4 . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24clk: renesas: Import R8A7792 V2H clock tablesMarek Vasut
Import clock tables for R8A7792 V2H SoC from upstream Linux kernel v4.15-rc8, commit bebc6082da0a9f5d47a1ea2edc099bf671058bd4 . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24clk: renesas: Import R8A7791/R8A7793 M2 clock tablesMarek Vasut
Import clock tables for R8A7791 M2W and R8A7793 M2N SoC from upstream Linux kernel v4.15-rc8, commit bebc6082da0a9f5d47a1ea2edc099bf671058bd4 . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24clk: renesas: Import R8A7790 H2 clock tablesMarek Vasut
Import clock tables for R8A7790 H2 SoC from upstream Linux kernel v4.15-rc8, commit bebc6082da0a9f5d47a1ea2edc099bf671058bd4 . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24clk: renesas: Add Gen2 clock coreMarek Vasut
Add common clock code for Renesas RCar Gen2 platforms. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24clk: renesas: Add DIV6P1 clock typeMarek Vasut
Add macros for the DIV6P1 clock type, which is used on Gen2 and optionally also on Gen3. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24clk: renesas: Split out code shared between Gen2 and Gen3Marek Vasut
Pull code which is common for RCar Gen2 and RCar Gen3 into separate source file. No functional change. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24clk: renesas: Make clock tables Kconfig configurableMarek Vasut
Add Kconfig entries for each SoC clock table, so they can be compiled in or out at build time. This can reduce the size of the binary if desired. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24clk: renesas: Split SMSTPCR and RMSTPCR tablesMarek Vasut
The Gen2 requires setting RMSTPCR before booting, while on Gen3 this is thus far always zero. Split the tables so the RMSTPCR can be set too. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24clk: renesas: Pull Gen3 specific bits into separate headerMarek Vasut
Extract the macros specific to Gen3 clock into a separate header. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24clk: renesas: Make PLL configurations per-SoCMarek Vasut
Not all SoCs have the same PLL configuration options, so make those PLL configuraion tables per-SoC. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24clk: renesas: Make clk_ids per-driverMarek Vasut
Not all drivers use the same IDs, so make those IDs per-driver. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24clk: renesas: Split RCar Gen3 driverMarek Vasut
Split the massive driver into smaller per-SoC drivers and pull the common code into a separate file. This would allow configuring out unnecessary clock drivers once the Kconfig changes are in and also allow adding more clock tables easily. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24wait_bit: use wait_for_bit_le32 and remove wait_for_bitÁlvaro Fernández Rojas
wait_for_bit callers use the 32 bit LE version Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-12-09clk: rmobile: Add R8A77995 D3 clock tablesMarek Vasut
Add clock tables for R8A77995 D3 SoC. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-12-09clk: rmobile: Add R8A77970 V3M clock tablesMarek Vasut
Add clock tables for R8A77970 V3M SoC. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-12-09clk: rmobile: Fix typo in R8A7796 RPC clock table entryMarek Vasut
Fix a copy-paste typo in the clock table entry, s/7795/7796/. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-11-30clk: rmobile: Add R8A7796 xHCI clockMarek Vasut
Add xHCI entry into the clock tables, so that the xHCI USB driver can enable the clock for the xHCI block via clock framework. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-11-30clk: rmobile: Move preboot clock shutdown to the driverMarek Vasut
The MSTP registers were poked in boards/renesas/rcar-common/common.c in arch_preboot_os hook thus far to shut down the clock before Linux takes over. With DM, this is no longer needed and we can do the same in the clock driver .remove callback. This patch adds such a .remove callback for R8A7795 and R8A7796. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-24clk: rmobile: Add RPC hyperflash clockMarek Vasut
Add missing RPC hyperflash entry into the clock driver tables. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-24clk: rmobile: Add support for setting SDxCKCRMarek Vasut
The SDxCKCR must be configured correctly, otherwise the SDIF can be unstable. This is done in board files thus far, but those are going away, so move the setting of SDxCKCR into the correct place. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-26clk: rmobile: Split R8A7795 and R8A7796 core clock tablesMarek Vasut
The R8A7795 and R8A7796 tables use different constants to identify clock in DT, so split the tables and use the correct constants on R8A7795. This fixes UART clock misconfiguration on R8A7795. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-03clk: rmobile: Add RCar Gen3 clock driverMarek Vasut
Add clock driver for the RCar Gen3 R8A7795 and R8A7796 SoCs . This driver allows reading out the clock configuration set by previous boot stages and enabling and disabling clock using the MSTP registers. Setting clock is not supported thus far. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
