With "clk dump" command, few clocks are showing up incorrect values
and some clocks are displayed as "unknown".
Add missing clocks to zynqmp clock driver to display proper
clocks rates.
Implement a simple way to get clock source, instead of calling
functions. Change existing functions to this simple mechanism.
Fix gem clock name "gem_rx" to "gem_tx" which was incorrect.
Change dbf_fpd & dbf_lpd clk names to dbg_fpd & dbg_lpd.
Signed-off-by: T Karthik Reddy <t.karthik.reddy@xilinx.com>
Add clock enable functionality in zynqmp clock driver to enable
clocks from peripheral drivers using clk_ops.
In the spirit of using the same base name for all of these related macros,
rename this to have the operation at the end. This is not widely used so
the impact is fairly small.
This construct is quite long-winded. In earlier days it made some sense
since auto-allocation was a strange concept. But with driver model now
used pretty universally, we can shorten this to 'auto'. This reduces
verbosity and makes it easier to read.
Coincidentally it also ensures that every declaration is on one line,
thus making dtoc's job easier.
The most of drivers are using '_' instead of '-' in driver name. That's why
sync up these names to be aligned. It looks quite bad to see both in use.
It is visible via dm tree command.
Move this header out of the common header.
At present dm/device.h includes the linux-compatible features. This
requires including linux/compat.h which in turn includes a lot of headers.
One of these is malloc.h which we thus end up including in every file in
U-Boot. Apart from the inefficiency of this, it is problematic for sandbox
which needs to use the system malloc() in some files.
Move the compatibility features into a separate header file.
At present devres.h is included in all files that include dm.h but few
make use of it. Also this pulls in linux/compat which adds several more
headers. Drop the automatic inclusion and require files to include devres
themselves. This provides a good indication of which files use devres.
Reviewed-by: Anatolij Gustschin <agust@denx.de>
Use prepared header instead of hardcoded values.
This patch fixed the same if/else part error by adding the required
source select on the basis of is_pre_src check.
Signed-off-by: Vipul Kumar <vipul.kumar@xilinx.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
We have a large number of places where while we historically referenced
gd in the code we no longer do, as well as cases where the code added
that line "just in case" during development and never dropped it.
New and old clk drivers are sharing IDs and descriptions.
This patch print pl clocks (pl0...pl3) and watchdog
clock using clk dump.
Signed-off-by: Vipul Kumar <vipulk@xilinx.com>
These macros and one variable is not used anywhere that's why
they should be removed.
Dont panic incase of mmio write/read failures instead return
error and let the peripheral driver take care of clock get
and set failures.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Add support for CCF, this CCF reads the ref clocks
from dt and checks all the required clock control
registers for its source , divisors and calculates
the clock from them. This supports clock and set
functions.
Panic when read/write fails.
This header includes things that are needed to make driver build. Adjust
existing users to include that always, even if other dm/ includes are
present
Add basic clock driver support for zynqmp which
sets the required clock for GEM controller
