Fixed some broken instances of "#ifdef CMD_CFG_IDE" too.
Those always evaluated TRUE, and thus were always compiled
even when IDE really wasn't defined/wanted.
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
Increase CFG_VIDEO_LOGO_MAX_SIZE on HH405 board.
Patch by Stefan Roese, 08 Oct 2005
Add support for gzip compressed bmp's (CONFIG_VIDEO_BMP_GZIP).
Add support for eeprom write-enable (CFG_EEPROM_WREN).
Patch by Stefan Roese, 22 Sep 2005
change timing for SM501 graphics controller on TQM5200 module
* Patch by Mark Jonas, 13 July 2004:
- Total5200 LCD now run in little endian mode. Endianess conversion
is done in hardware.
- Removed last reference to "console" environment variable.
* Patch by Sascha Hauer, 28 Jun:
- add generic support for Motorola i.MX architecture
- add support for mx1ads, mx1fs2 and scb9328 boards
* Patches by Marc Leeman, 23 Jul 2004:
- Add define for the PCI/Memory Buffer Configuration Register
- corrected comments in cpu/mpc824x/cpu_init.c
* Add support for multiple serial interfaces
(for example to allow modem dial-in / dial-out)
Fix sbc8260 environment variables
* Cleanup redundand "console" environment variable
* Patch by Mark Jonas, 05 Jul 2004:
add support for the Total5100's and Total5200's LCD screen
* Patches by Dan Eisenhut, 01 Jul 2004:
- README fixes.
- Move doc2000.h include to prevent compiler warning on some boards
- add bitmap command and splash screen support in cfb console
- add [optional] origin in the bitmap display command
* Patch by Travis Sawyer, 11 Mar 2004:
Fix ocotea board early init interrupt setup.
* Patch by Thomas Viehweger, 11 Mar 2004:
Remove redundand code; add PCI-specific bits to include/mpc8260.h
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
* Patch by Pierre Aubert, 20 Nov 2002
Add driver for Epson SED13806 graphic controller.
Add support for BMP logos in cfb_console driver.
