path: root/drivers/bus
2021-03-19bus: ti-sysc: change in a normal driverDario Binacchi
The module defines a duplicate uclass driver for UCLASS_SIMPLE_BUS, but it is not allowed. This breaks of-platdata and makes the result non-deterministic. The driver does not need to be an uclass driver, so lets remove it. I had turned it into an uclass driver because I thought wrongly it had to call the dm_scan_fdt_dev routine to work properly, but some tests on the board have shown otherwise. Signed-off-by: Dario Binacchi <dariobin@libero.it> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-01-12bus: ti: am33xx: add pwm subsystem driverDario Binacchi
The TI PWMSS driver is a simple bus driver for providing clock and power management for the PWM peripherals on TI AM33xx SoCs, namely eCAP, eHRPWM and eQEP. For DT binding details see Linux doc: - Documentation/devicetree/bindings/pwm/pwm-tipwmss.txt Signed-off-by: Dario Binacchi <dariobin@libero.it>
2021-01-12bus: ti: add minimal sysc interconnect target driverDario Binacchi
We can handle the sysc interconnect target module in a generic way for many TI SoCs. Initially let's just enable domain clocks before the children are probed. The code is loosely based on the drivers/bus/ti-sysc.c of the Linux kernel version 5.9-rc7. For DT binding details see: - Documentation/devicetree/bindings/bus/ti-sysc.txt Signed-off-by: Dario Binacchi <dariobin@libero.it>
2020-07-11bus: uniphier-system-bus: move hardware init from board filesMasahiro Yamada
Move the bus initialization code to this driver from board files. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2020-07-11bus: uniphier-system-bus: add UniPhier System Bus driverMasahiro Yamada
Since commit 1517126fdac2 ("ARM: uniphier: select DM_ETH"), DM-based drivers/net/smc911x.c is compiled, but it is never probed because the parent node lacks the DM-based driver. I need a skeleton driver to populate child devices (but the next commit will move more hardware settings to the this driver). I put this to drivers/bus/uniphier-system-bus.c because this is the same path as the driver in Linux kernel. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
