path: root/drivers/bootcount/Makefile
2018-02-24Migrate generic bootcount to KconfigAlex Kiernan
Make generate boot counter selected in the same way as other boot count drivers Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-02-24Integrate AT91 bootcount driverAlex Kiernan
Integrate Boot counter for Atmel AT91SAM9XE into Kconfig Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-02-24Convert CONFIG_BOOTCOUNT_AM33XX to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_BOOTCOUNT_AM33XX Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2017-11-20bootcount: add support for bootcounter on EXT filesystemIan Ray
Add support for bootcounter on an EXT filesystem. Sync configuration whitelist. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk>
2017-04-05Blackfin: RemoveTom Rini
The architecture is currently unmaintained, remove. Cc: Benjamin Matthews <mben12@gmail.com> Cc: Chong Huang <chuang@ucrobotics.com> Cc: Dimitar Penev <dpn@switchfin.org> Cc: Haitao Zhang <hzhang@ucrobotics.com> Cc: I-SYST Micromodule <support@i-syst.com> Cc: M.Hasewinkel (MHA) <info@ssv-embedded.de> Cc: Marek Vasut <marex@denx.de> Cc: Martin Strubel <strubel@section5.ch> Cc: Peter Meerwald <devel@bct-electronic.com> Cc: Sonic Zhang <sonic.adi@gmail.com> Cc: Valentin Yakovenkov <yakovenkov@niistt.ru> Cc: Wojtek Skulski <info@skutek.com> Cc: Wojtek Skulski <skulski@pas.rochester.edu> Signed-off-by: Tom Rini <trini@konsulko.com>
2014-02-20i2c, bootcount: add support for bootcounter on i2c devicesHeiko Schocher
add support for bootcounter on an i2c device. And add a README for all bootcounter options. Signed-off-by: Heiko Schocher <hs@denx.de>
2013-11-11am33xx: Make SoC bootcount driver have its own symbolTom Rini
Some am33xx boards may not use the RTC block for bootcount (as it may not be wired up for the board) and use some other facility. So add another symbol for the bootcount driver for the IP block. Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2013-11-11bootcount: store bootcount var in environmentHeiko Schocher
If no softreset save registers are found on the hardware "bootcount" is stored in the environment. To prevent a saveenv on all reboots, the environment variable "upgrade_available" is introduced. If "upgrade_available" is 0, "bootcount" is always 0 therefore no need to save the environment on u-boot boot, if "upgrade_available" is 1 "bootcount" is incremented in the environment and environment gets written on u-boot start. So the Userspace Applikation must set the "upgrade_available" and "bootcount" variable to 0 (for example with fw_setenv), if a boot was successfully. Signed-off-by: Heiko Schocher <hs@denx.de>
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-01TI:am33xx: Add bootcount support to ti_am335x_common.hTom Rini
Enable the bootcount driver for am335x in general. We leave adding a bootlimit and altbootcmd to the environment to the board ports. Signed-off-by: Tom Rini <trini@ti.com>
2013-10-31drivers: convert makefiles to Kbuild styleMasahiro Yamada
2012-09-01Consolidate bootcount code into drivers/bootcountStefan Roese
This patch moves all bootcount implementations into a common directory: drivers/bootcount. The generic bootcount driver is now usable not only by powerpc platforms, but others as well. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Manfred Rudigier <manfred.rudigier@omicron.at> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Reinhard Meyer <reinhard.meyer@emk-elektronik.de> Tested-by: Valentin Longchamp <valentin.longchamp@keymile.com> Tested-by: Christian Riesch <christian.riesch@omicron.at> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
