path: root/drivers/block
2010-08-08ide: add mvsata_ide driverAlbert Aribaud
This driver only provides initialization code; actual driving is done by cmd_ide.c using the ATA compatibility mode of the Marvell SATAHC controller. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-08-08ide: reorder object files alphabeticallyAlbert Aribaud
2010-07-13Blackfin: pata_bfin: convert to portmux frameworkMike Frysinger
Rather than bang MMRs directly, use the new portmux framework to handle the details. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-1285xx/fsl-sata: Use is_serdes_configured() to determine if SATA is enabledKumar Gala
On the MPC85xx platform if we have SATA its connected on SERDES. Determing if SATA is enabled via sata_initialize should not be board specific and thus we move it out of the MPC8536DS board code. Additionally, now that we have is_serdes_configured() we can determine if the given SATA port is enabled and error out if its not in the driver. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-26fsl_sata: Move the snoop bit to another placeDave Liu
For P1022 SATA host controller, the data snoop bit of DW3 in PRDT is moved to bit28. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-26fsl_sata: Add the workaround for errata SATA-A001Dave Liu
After power on, the SATA host controller of P1022 Rev1 is configured in legacy mode instead of the expected enterprise mode. Software needs to clear bit[28] of HControl register to change to enterprise mode after bringing the host offline. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-04Misc SATA fixupsGraeme Russ
Cast first parameter to sata_cpy() In /drivers/block/ata_piix.h, ata_id_has_lba48(), ata_id_has_lba(), ata_id_has_dma(), ata_id_u32(), ata_id_u64() are all defined in include/libata.h which is included in ata.h which is included by all files which include ata_piix.h (only ata_piix.c) so these definitions are supurflous to (and conlict with) this in libata.h. Interestingly, my compiler complains about ata_id_u64 already being defined, but not ata_id_u32 ata_dump_id() is defined in include/libata.h and should not be static (maybe should even use ata_dump_id() in libata.c Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-07-29Update Freescale copyrights to remove "All Rights Reserved"Kumar Gala
"All Rights Reserved" conflicts with the GPL. Signed-off-by: Kumar Gala <kumar.gala@freescale.com>
2009-07-23ahci: Fix gcc 4.4 compiler warningKumar Gala
ahci.c: In function 'ata_scsiop_read_capacity10': ahci.c:616: warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-20fsl_sata: Fix compiler warnings shown by gcc-4.4galak
Update fsl_sata to use common structures instead of casting back and forth between the fsl specific ones and the common ones (which are identical). fsl_sata.c: In function 'scan_sata': fsl_sata.c:550: warning: dereferencing pointer 'cfis' does break strict-aliasing rules fsl_sata.c:549: warning: dereferencing pointer 'cfis' does break strict-aliasing rules fsl_sata.c:548: warning: dereferencing pointer 'cfis' does break strict-aliasing rules fsl_sata.c:545: note: initialized from here fsl_sata.c:592: warning: dereferencing pointer 'cfis' does break strict-aliasing rules fsl_sata.c:590: warning: dereferencing pointer 'cfis' does break strict-aliasing rules fsl_sata.c:588: warning: dereferencing pointer 'cfis' does break strict-aliasing rules fsl_sata.c:586: warning: dereferencing pointer 'cfis' does break strict-aliasing rules fsl_sata.c:579: warning: dereferencing pointer 'cfis' does break strict-aliasing rules ... Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-19Canyonlands SATA harddisk driverKazuaki Ichinohe
This patch adds a SATA harddisk driver for the canyonlands. This patch is kernel driver's porting. This patch corresponded to not cmd_scsi but cmd_sata. This patch divided an unused member with ifndef __U_BOOT__ in the structure. [environment variable, boot script] setenv bootargs root=/dev/sda7 rw setenv bootargs ${bootargs} console=ttyS0,115200 ext2load sata 0:2 0x400000 /canyonlands/uImage ext2load sata 0:2 0x800000 /canyonlands/canyonlands.dtb fdt addr 0x800000 0x4000 bootm 0x400000 - 0x800000 If you drive SATA-2 disk on Canyonlands, you must change parts from PI2PCIE212 to PI2PCIE2212 on U25. We confirmed to boot by using following disks: 1.Vendor: Fujitsu Type: MHW2040BS 2.Vendor: Fujitsu Type: MHW2060BK 3.Vendor: HAGIWARA SYS-COM:HFD25S-032GT 4.Vendor: WesternDigital Type: WD3200BJKT (CONFIG_LBA48 required) 5.Vendor: WesternDigital Type: WD3200BEVT (CONFIG_LBA48 required) 6.Vendor: Hitachi Type: HTS543232L9A300 (CONFIG_LBA48 required) 7.Vendor: Seagate Type: ST31000333AS (CONFIG_LBA48 required) 8.Vendor: Transcend Type: TS32GSSD25S-M 9.Vendor: MTRON Type: MSD-SATA1525-016 Signed-off-by: Kazuaki Ichinohe <kazuichi at fsi.co.jp>
2009-07-17sata: namespace curr_device variableMike Frysinger
The curr_device variable really should be namespaced with a "sata_" prefix since it is only used by the sata code. It also avoids random conflicts with other pieces of code (like cmd_mmc): common/libcommon.a(cmd_sata.o):(.data.curr_device+0x0): multiple definition of `curr_device' common/libcommon.a(cmd_mmc.o):(.data.curr_device+0x0): first defined here Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-05Update CHANGELOG, coding style cleanup.Wolfgang Denk
2009-04-03mflash: Initial mflash supportunsik Kim
Mflash is fusion memory device mainly targeted consumer eletronic and mobile phone. Internally, it have nand flash and other hardware logics and supports some different operation (ATA, IO, XIP) modes. IO mode is custom mode for the host that doesn't have IDE interface. (Many mobile targeted SoC doesn't have IDE bus) This driver support mflash IO mode. Followings are brief descriptions about IO mode. 1. IO mode based on ATA protocol and uses some custom command. (read confirm, write confirm) 2. IO mode uses SRAM bus interface. Signed-off-by: unsik Kim <donari75@gmail.com>
2009-02-19sata_sil3114: fix compiler warningKim Phillips
judging from other printfs in the same file, it seems ata should be postpended with the interface number, not the address of the global port variable. Fixes this for current u-boot-mpc83xx tree: Configuring for MPC8349ITX board... sata_sil3114.c: In function 'sata_bus_softreset': sata_sil3114.c:99: warning: format '%u' expects type 'unsigned int', but argument 2 has type 'struct sata_port *' sata_sil3114.c:108: warning: format '%u' expects type 'unsigned int', but argument 2 has type 'struct sata_port *' Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-10drivers/block/ahci: Fix pci mapping bugBecky Bruce
The code assumes that the pci bus address and the virtual address used to access a region are the same, but they might not be. Fix this assumption. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-02-02Blackfin: add driver for on-chip ATAPI controllerSonic Zhang
This is a port of the Linux Blackfin on-chip ATAPI driver to U-Boot. Signed-off-by: Sonic Zhang <Sonic.Zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
2008-08-13drivers/block: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-07-14Code cleanup: fix old style assignment ambiguities like "=-" etc.Wolfgang Denk
2008-07-10silence misc printf formatting compiler warningsKim Phillips
2008-06-30sata: wait for device updating signature to hostDave Liu
The driver need wait for the device updating signature to host. If we don't wait for it, the driver can not detect the device(disk) when the system powers up. Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-06-29Add sata sil3114 supportTor Krill
Signed-off-by: Tor Krill <tor@excito.com>
2008-04-13ata: update the libata.h from ata.h of linux kernelDave Liu
Current libata.h of u-boot is out of sync from linux kernel, this patch make it be consistent with linux kernel. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Tor Krill <tor@excito.com>
2008-04-13drivers: code clean upDave Liu
2008-04-13drivers: clean up the ata_piix.hDave Liu
2008-03-27Coding style cleanup, update CHANGELOGWolfgang Denk
2008-03-26drivers: add the support for Freescale SATA controllerDave Liu
Add the Freescale on-chip SATA controller driver to u-boot, The SATA controller is used on the 837x and 8315 targets, The driver can be used to load kernel, fs and dtb. The features list: - 1.5/3 Gbps link speed - LBA48, LBA28 support - DMA and FPDMA support - Two ports support Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-03-26ata: add the libata supportDave Liu
add simple libata support in u-boot Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-03-26ata: make the ata_piix driver using new SATA frameworkDave Liu
original ata_piix driver is using IDE framework, not real SATA framework. For now, the ata_piix driver is only used by x86 sc520_cdp board. This patch makes the ata_piix driver use the new SATA framework, so - remove the duplicated command stuff - remove the CONFIG_CMD_IDE define in the sc520_cdp.h - add the CONFIG_CMD_SATA define to sc520_cdp.h Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-03-26ata: merge the header of ata_piix driverDave Liu
move the sata.h from include/ to drivers/block/ata_piix.h Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-03-26ata: merge the ata_piix driverDave Liu
move the cmd_sata.c from common/ to drivers/ata_piix.c, the cmd_sata.c have some part of ata_piix controller drivers. consolidate the driver to have better framework. Signed-off-by: Dave Liu <daveliu@freescale.com>
2007-11-25drivers/block : move block drivers to drivers/blockJean-Christophe PLAGNIOL-VILLARD
