path: root/drivers/block
2020-08-14xen: pvblock: Add initial support for para-virtualized block driverAnastasiia Lukianenko
Add initial infrastructure for Xen para-virtualized block device. This includes compile-time configuration and the skeleton for the future driver implementation. Add new class UCLASS_PVBLOCK which is going to be a parent for virtual block devices. Add new interface type IF_TYPE_PVBLOCK. Implement basic driver setup by reading XenStore configuration. Signed-off-by: Andrii Anisov <andrii_anisov@epam.com> Signed-off-by: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com> Signed-off-by: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com>
2020-08-06blkcache: Extend blkcache_init to cover CONFIG_NEEDS_MANUAL_RELOCOvidiu Panait
Extend manual relocation of block_cache list pointers to all platforms that enable CONFIG_NEEDS_MANUAL_RELOC. Remove m68k-specific checks and provide a single implementation that adds gd->reloc_off to the pre-relocation pointers. Acked-by: Angelo Dureghello <angelo.dureghello@timesys.com> Tested-by: Angelo Dureghello <angelo.dureghello@timesys.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Eric Nelson <eric@nelint.com> Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com> [trini: Add guard around DECLARE_GLOBAL_DATA_PTR to avoid size growth] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-08-06dm: blk: Use IS_ENABLED() instead of #ifdefs in blk_post_probeOvidiu Panait
Use IS_ENABLED() instead of #ifdef in blk_post_probe function. No functional change intended. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com> [trini: Fix thinko and use CONFIG_HAVE_BLOCK_DEVICE in IS_ENABLED()] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-05-18common: Drop linux/delay.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop part.h from common headerSimon Glass
2020-04-17block: ide: use definitions from include/libata.hHeinrich Schuchardt
Currently ATA commands are defined both in include/libata.h and include/ata.h. Use the command definitions from include/libata.h where applicable. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-02-05dm: core: Create a new header file for 'compat' featuresSimon Glass
At present dm/device.h includes the linux-compatible features. This requires including linux/compat.h which in turn includes a lot of headers. One of these is malloc.h which we thus end up including in every file in U-Boot. Apart from the inefficiency of this, it is problematic for sandbox which needs to use the system malloc() in some files. Move the compatibility features into a separate header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05dm: core: Require users of devres to include the headerSimon Glass
At present devres.h is included in all files that include dm.h but few make use of it. Also this pulls in linux/compat which adds several more headers. Drop the automatic inclusion and require files to include devres themselves. This provides a good indication of which files use devres. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Anatolij Gustschin <agust@denx.de>
2020-01-26common: fix regression on block cache initAngelo Durgehello
m68k needs block cache list initialized after relocation. Other architectures must not be involved. Fixing regression related to: commit 1526bcce0f7285087621e16e6720636d01839da8 ("common: add blkcache init") Signed-off-by: Angelo Durgehello <angelo.dureghello@timesys.com>
2020-01-25common: add blkcache initAngelo Durgehello
On m68k, block_cache list is relocated, but next and prev list pointers are not adjusted to the relocated struct list_head address, so the first iteration over the block_cache list hangs. This patch initializes the block_cache list after relocation. Signed-off-by: Angelo Durgehello <angelo.dureghello@timesys.com> Reviewed-by: Eric Nelson <eric@nelint.com>
2019-12-03blk: Make use of CONFIG_HAVE_BLOCK_DEVICE moreTom Rini
When we do not have CONFIG_BLK (or SPL/TPL) enabled there are very few cases where we need the blk_legacy code linked in. To catch these, build when we have CONFIG_HAVE_BLOCK_DEVICE set. In addition, we only need cmd/blk_common.o to be linked in when we have CONFIG_HAVE_BLOCK_DEVICE set, so make use of that directly. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-10-30blk: set log2blksz in blk_create_device()Heinrich Schuchardt
The ext4 file system requires log2blksz to be set. So when setting the block size on the block descriptor we should fill this field too. This fixes a problem with EFI block devices providing ext4 partitions, cf. https://lists.denx.de/pipermail/u-boot/2019-October/387702.html. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-10-08dm: core: Add device_foreach_child()Simon Glass
We have a 'safe' version of this function but sometimes it is not needed. Add a normal version too and update a few places that can use it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-08-30Revert "blk: Invalidate block cache when switching hwpart"Weijie Gao
This reverts commit 0ebe112d09b48230ba4be833cd3504b06997d9a4. Most block devices have only one hwpart. Multiple hwparts only found used by eMMC devices in u-boot. The mmc driver do blk_dselect_hwpart() at the beginning of mmc_bread() which causes block cache being invalidated too frequently and makes block cache useless. So it's not a good idea to put blkcache_invalidate() in the common functions. It should be called inside mmc_select_hwpart(). Signed-off-by: Weijie Gao <weijie.gao@mediatek.com> Tested-by: Felix Brack <fb@ltec.ch>
2019-07-18blk: Invalidate block cache when switching hwpartWeijie Gao
Some storage devices have multiple hw partitions and both address from zero, for example eMMC. However currently block cache invalidation only applies to block write/erase. This can cause a problem that data of current hw partition is cached before switching to another hw partition. And the following read operation of the latter hw partition will get wrong data when reading from the addresses that have been cached previously. To solve this problem, invalidate block cache after a successful select_hwpart operation. Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2019-07-10blk: Allow control of the block cache in TPLSimon Glass
Generally block devices are not enabled in TPL, but in case they are, add a Kconfig option for the block cache. This allows the setting (default off) to be found with CONFIG_IS_ENABLED(). Signed-off-by: Simon Glass <sjg@chromium.org>
2019-01-15blk: Increase cache element sizeMarek Vasut
Cache up to 4 kiB entries. 4 kiB is the default block size on ext4, yet the underlying block layer devices usually report support for 512B . In most cases, the 512B support is emulated (ie. SD cards, SSDs, USB sticks etc.) and the real block size of those devices is much bigger. To avoid performance degradation with such devices and FS setup, bump the maximum cache entry size to 4 kiB. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-12-12blk: Rework guard around part_init callTom Rini
The function part_init() will only be built when we have both CONFIG_PARTITIONS and CONFIG_HAVE_BLOCK_DEVICE set. Protect the call to this function with both of these tests now. Cc: Simon Glass <sjg@chromium.org> Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: York Sun <york.sun@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Stefan Roese <sr@denx.de> Cc: Marek BehĂșn <marek.behun@nic.cz> Cc: Vanessa Maegima <vanessa.maegima@nxp.com> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Adam Ford <aford173@gmail.com> Cc: Jagan Teki <jagan@amarulasolutions.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14blk: Introduce IF_TYPE_VIRTIOTuomas Tynkkynen
This adds a new block interface type for VirtIO block devices. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14blk: Make blk_next_free_devnum() publicBin Meng
blk_next_free_devnum() can be helpful in some cases. Make it a public API. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14blk: Drop blk_prepare_device()Bin Meng
With the post_probe() changes, this API is no longer needed. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14blk: Call part_init() in the post_probe() methodBin Meng
part_init() is currently called in every DM BLK driver, either in its bind() or probe() method. However we can use the BLK uclass driver's post_probe() method to do it automatically. Update all DM BLK drivers to adopt this change. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14sandbox: blk: Switch to use platdata_auto_alloc_size for the driver dataBin Meng
Currently the sandbox block driver uses priv_auto_alloc_size for the driver data, however that's only available after the device probe phase. In order to make it accessible in an earlier phase, switch to use platdata_auto_alloc_size instead. This patch is the prerequisite for the follow up patch of DM BLK driver changes to work with Sandbox. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-09blk: Support block drivers in TPLSimon Glass
At present it is not possible to enable/disable block drivers in TPL. This is needed to provide sandbox support. Add a Kconfig option and adjust the Makefile. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-28block: Add a function to find block device descriptorTien Fong Chee
Add a function to find the block device descriptor of the parent device. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> [trini: Move function declaration to avoid warning] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-06-18block: Add SPL_BLOCK_CACHE and default nAdam Ford
When enabling BLOCK_CACHE on devices with limited RAM during SPL, some devices may not boot. This creates an option to enable block caching in SPL by defaults off. It is dependent on SPL_BLK Fixes: 46960ad6d09b ("block: Have BLOCK_CACHE default to y in some cases") Signed-off-by: Adam Ford <aford173@gmail.com>
2018-06-07block: Have BLOCK_CACHE default to y in some casesTom Rini
When dealing with filesystems that come from block devices we can get a noticeable performance gain in some use cases from having the block cache enabled. The code paths are valid in other cases when we have BLK set and may provide wins in raw reads in some use cases, so have this be default when BLK is enabled. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-13SystemACE: RemoveTom Rini
This driver is no longer used on any supported platform in U-Boot and there is no interest in maintaining it further from people that have used it historically. Cc: Simon Glass <sjg@chromium.org> Cc: Michal Simek <michal.simek@xilinx.com> c: Alexey Brodkin <alexey.brodkin@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2018-02-08Move most CONFIG_HAVE_BLOCK_DEVICE to KconfigAdam Ford
config_fallbacks.h has some logic that sets HAVE_BLOCK_DEVICE based on a list of enabled options. Moving HAVE_BLOCK_DEVICE to Kconfig allows us to drastically shrink the logic in config_fallbacks.h Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rename HAVE_BLOCK_DEVICE to CONFIG_BLOCK_DEVICE] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-08block: Migrate SystemACE chip to KconfigTom Rini
Migrate the base and sub-options to Kconfig. Note that we only enable this in the base sandbox config now. Cc: Alexey Brodkin <alexey.brodkin@gmail.com> Cc: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com> --- Is this driver still used anywhere? It's fishy that it's only enabled in sandbox anymore.
2018-01-22efi_driver: EFI block driverHeinrich Schuchardt
This patch provides * a uclass for EFI drivers * a EFI driver for block devices For each EFI driver the uclass * creates a handle * adds the driver binding protocol The uclass provides the bind, start, and stop entry points for the driver binding protocol. In bind() and stop() it checks if the controller implements the protocol supported by the EFI driver. In the start() function it calls the bind() function of the EFI driver. In the stop() function it destroys the child controllers. The EFI block driver binds to controllers implementing the block io protocol. When the bind function of the EFI block driver is called it creates a new U-Boot block device. It installs child handles for all partitions and installs the simple file protocol on these. The read and write functions of the EFI block driver delegate calls to the controller that it is bound to. A usage example is as following: U-Boot loads the iPXE snp.efi executable. iPXE connects an iSCSI drive and exposes a handle with the block IO protocol. It calls ConnectController. Now the EFI block driver installs the partitions with the simple file protocol. iPXE uses the simple file protocol to load Grub or the Linux Kernel. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> [agraf: add comment on calloc len] Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-12dm: blk: Use uclass_find_first/next_device() in blk_first/next_device()Stefan Roese
This patch changes the calls to uclass_first/next_device() in blk_first/ next_device() to use uclass_find_first/next_device() instead. These functions don't prepare the devices, which is correct in this case. With this patch applied, the "usb storage" command now works again as expected: => usb storage Device 0: Vendor: SanDisk Rev: 1.00 Prod: Ultra Type: Removable Hard Disk Capacity: 58656.0 MB = 57.2 GB (120127488 x 512) Without this patch, it used to generate this buggy output: => usb storage Card did not respond to voltage select! mmc_init: -95, time 26 No storage devices, perhaps not 'usb start'ed..? Signed-off-by: Stefan Roese <sr@denx.de> Suggested-by: Simon Glass <sjg@chromium.org> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-15blk: Remove various places that do flush cache after readBin Meng
All these places seem to inherit the codes from the MMC driver where a FIXME was put in the comment. However the correct operation after read should be cache invalidate, not flush. The underlying drivers should be responsible for the cache operation. Remove these codes completely. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: York Sun <york.sun@nxp.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: York Sun <york.sun@nxp.com>
2017-09-11blk: dm: make blk_create_device() take a number of block instead of a sizeJean-Jacques Hiblot
There is an overflow problem when taking the size instead of the number of blocks in blk_create_device(). This results in a wrong device size: the device apparent size is its real size modulo 4GB. Using the number of blocks instead of the device size fixes the problem and is more coherent with the internals of the block layer. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-10block: ide: Don't bother to create BLK device if no CDROM insertedBin Meng
When there is no CDROM inserted, the block size is zero hence there is no need to create a BLK device for it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-10block: ide: Fix block read/write with driver modelBin Meng
This converts the IDE driver to driver model so that block read and write are fully functional. Fixes: b7c6baef ("x86: Convert MMC to driver model") Reported-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-09-03block: Drop the ftide020 driverBin Meng
This is not used in U-Boot. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-03block: ide: Drop CONFIG_IDE_LEDBin Meng
This is actually not used. Drop it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-03block: ide: Drop CONFIG_IDE_INIT_POSTRESETBin Meng
This is not referenced anywhere. Drop it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-17dm: blk: Update return value in blk_create_devicef()Simon Glass
This returns 'ret' but the value is always zero. Update it to simply return 0, for clarity. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-17dm: blk: Add a function to find an interface-type nameSimon Glass
Add a function to find the name of an interface type (e.g. "sata", "scsi") from the interface type enum. This is useful for generic code (not specific to SATA or SCSI, for example) that wants to display the type of interface it is dealing with. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-13dm: blk: part: Add UCLASS_NVME and IF_TYPE_NVMEZhikang Zhang
This adds a new uclass id and block interface type for NVMe. Signed-off-by: Zhikang Zhang <zhikang.zhang@nxp.com> Signed-off-by: Wenbin Song <wenbin.song@nxp.com> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jon Nettleton <jon@solid-run.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-01Merge git://git.denx.de/u-boot-x86Tom Rini
2017-08-01block: ide: Fix build error when CONFIG_BLK is onBin Meng
Add missing #ifndef CONFIG_BLK to wrap dev_desc->block_read. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01dm: mmc: Allow disabling driver model in SPLSimon Glass
At present if U-Boot proper uses driver model for MMC, then SPL has to also. While this is desirable, it places a significant barrier to moving to driver model in some cases. For example, with a space-constrained SPL it may be necessary to enable CONFIG_SPL_OF_PLATDATA which involves adjusting some drivers. Add new SPL versions of the options for DM_MMC, DM_MMC_OPS and BLK. By default these follow their non-SPL versions, but this can be changed by boards which need it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-11scsi: Move drivers into new drivers/scsi directorySimon Glass
At present we have the SCSI drivers in the drivers/block and common/ directories. It is better to split them out into their own place. Use drivers/scsi which is what Linux does. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11sata: Move drivers into new drivers/ata directorySimon Glass
At present we have the SATA and PATA drivers mixed up in the drivers/block directory. It is better to split them out into their own place. Use drivers/ata which is what Linux does. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11Kconfig: Add CONFIG_SATA to enable SATASimon Glass
At present CONFIG_CMD_SATA enables the 'sata' command which also brings in SATA support. Some boards may wish to enable SATA without the command. Add a separate CONFIG to permit this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
