At present CONFIG_CMD_SATA enables the 'sata' command which also brings
in SATA support. Some boards may wish to enable SATA without the command.
Add a separate CONFIG to permit this.
This function is only defined by one driver and is empty. Move it into
the SCSI implementation itself. We could remove it, but it should be
useful for debugging.
This driver is for a PowerPC board that will likely be removed soon.
Rather than converting it to driver model, drop it.
CONFIG_SCSI
driver is not used anymore, so remove it.
Drop include of netdev.h as it's a SATA driver not a network driver.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
There was for long time no activity in the 8xx area.
We need to go further and convert to Kconfig, but it
turned out, nobody is interested anymore in 8xx,
so remove it (with a heavy heart, knowing that I remove
here the root of U-Boot).
Many devices support a child block device (e.g. MMC, USB). Add a
convenient way to get this device given the parent device.
The intention with block devices is that the device number (devnum field
in its descriptor) matches the alias of its parent device. For example,
with:
aliases {
mmc0 = "/sdhci@700b0600";
mmc1 = "/sdhci@700b0400";
we expect that the block devices for mmc0 and mmc1 would have device
numbers of 0 and 1 respectively.
Unfortunately this does not currently always happen. If there is another
MMC device earlier in the driver model data structures its block device
will be created first. It will therefore get device number 0 and mmc0
will therefore miss out. In this case the MMC device will have sequence
number 0 but its block device will not.
To avoid this, allow a device to request a device number and bump any
existing device number that is using it. This all happens during the
binding phase so it is safe to change these numbers around. This allows
device numbers to match the aliases in all circumstances.
Add a test to verify the behaviour.
At present this code is inline. Move it into a function to allow it to
be used elsewhere.
Sometimes it is useful to be able to find a block device without also
probing it. Add a function for this as well as the associated test.
At present devices use a simple integer offset to record the device tree
node associated with the device. In preparation for supporting a live
device tree, which uses a node pointer instead, refactor existing code to
access this field through an inline function.
These support the flat device tree. We want to use the dev_read_..()
prefix for functions that support both flat tree and live tree. So rename
the existing functions to avoid confusion.
In the end we will have:
1. dev_read_addr...() - works on devices, supports flat/live tree
2. devfdt_get_addr...() - current functions, flat tree only
3. of_get_address() etc. - new functions, live tree only
All drivers will be written to use 1. That function will in turn call
either 2 or 3 depending on whether the flat or live tree is in use.
Note this involves changing some dead code - the imx_lpi2c.c file.
At present IDE support is controlled by CONFIG_CMD_IDE. Add a separate
CONFIG_IDE option so that IDE support can be enabled without requiring
the 'ide' command.
Update existing users and move the ide driver into drivers/block since
it should not be in common/.
Implement a sata driver for Synopsys DWC sata device based on
U-boot driver model.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
After allocating sata->cmd_hdr_tbl_offset we have to check
this variable and not variable sata.
The problem was indicated by cppcheck.
These drivers have no user since commit ea3310e8aafa ("Blackfin:
Remove").
Acked-by: Michal Simek <michal.simek@xilinx.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
This patch adds the flags parameter to device_remove() and changes all
calls to this function to provide the default value of DM_REMOVE_NORMAL
for "normal" device removal.
This is in preparation for the driver specific pre-OS (e.g. DMA
cancelling) remove support.
This patch also includes ARM64 zynqmp changes:
- Remove platform non DM initialization
- Remove hardcoded sata base address
All sata based drivers are bind and corresponding block
device is created. Based on this find_scsi_device() is able
to get back block device based on scsi_curr_dev pointer.
intr_scsi() is commented now but it can be replaced by calling
find_scsi_device() and scsi_scan().
scsi_dev_desc[] is commented out but common/scsi.c heavily depends on
it. That's why CONFIG_SYS_SCSI_MAX_DEVICE is hardcoded to 1 and symbol
is reassigned to a block description allocated by uclass.
There is only one block description by device now but it doesn't need to
be correct when more devices are present.
scsi_bind() ensures corresponding block device creation.
uclass post_probe (scsi_post_probe()) is doing low level init.
SCSI/SATA DM based drivers requires to have 64bit base address as
the first entry in platform data structure to setup mmio_base.
This reverts commit 3edc0c252257e4afed163a3a74aba24a5509b198, reversing
changes made to bb135a0180c31fbd7456021fb9700b49bba7f533.
Series-to: sjg, agraf@suse.de
Series-cc: uboot
Series-version: 4
Series-changes: 2
- make ceva_init_sata static
- Move SATA_CEVA to defconfig
- Initalized max_lun and max_id platdata
Series-changes: 3
- Extend Kconfig help description
- sort dm.h
- Remove SPL undefinition from board file
- Fix Kconfig dependecies
Series-changes: 2
- Use CONFIG_DM_SCSI instead of mix of DM_SCSI and DM_SATA
Ceva sata has never used sata commands that's why keep it in
SCSI part only.
- Separate scsi_scan() for DM_SCSI and do not change cmd/scsi.c
- Extend platdata
Series-changes: 3
- Fix scsi_scan return path
- Fix header location uclass-internal.h
- Add scsi_max_devs under !DM_SCSI
- Add new header device-internal because of device_probe()
- Redesign block device creation algorithm
- Use device_unbind in error path
- Create block device with id and lun numbers (lun was there in v2)
- Cleanup dev_num initialization in block device description
with fixing parameters in blk_create_devicef
- Create new Kconfig menu for SATA/SCSI drivers
- Extend description for DM_SCSI
- Fix Kconfig dependencies
- Fix kernel doc format in scsi_platdata
- Fix ahci_init_one - vendor variable
Series-changes: 4
- Fix Kconfig entry
- Remove SPL ifdef around SCSI uclass
- Clean ahci_print_info() ifdef logic
This patch fixes the warnings about misaligned cache on Armada XP:
CACHE: Misaligned operation at range [7facb400, 7facb460]
Current get_desc() implementation is not able to succesfully
finish and return pointer to block device descriptor.
Also function always return non zero value even device is found.
The patch fills block device descriptor and return 0 if device is found.
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is
enabled.
To allow a board- / platform-specific ahci_port_base() function, this
patch removes "static inline" and adds __weak to this function. This
will be used by the upcoming Armada 7K/8K SATA / AHCI support, which
unfortunately needs a different port base address calculation.
Cc: Nadav Haklai <nadavh@marvell.com>
Cc: Neta Zur Hershkovits <neta@marvell.com>
Cc: Kostya Porotchkin <kostap@marvell.com>
Cc: Omri Itach <omrii@marvell.com>
Cc: Igal Liberman <igall@marvell.com>
Cc: Haim Boot <hayim@marvell.com>
Cc: Hanna Hawa <hannah@marvell.com>
Now, arch/${ARCH}/include/asm/errno.h and include/linux/errno.h have
the same content. (both just wrap <asm-generic/errno.h>)
Replace all include directives for <asm/errno.h> with <linux/errno.h>.
[trini: Fixup include/clk.]
Remove unneeded variables and assignments.
i.MX6DQPlus support sata interface, so not return failure
when CPU is i.MX6DQPlus.
In this patch, also use simpler runtime cpu dections macros to replace
is_cpu_type.
Signed-off-by: Peng Fan <van.freenix@gmail.com>
Cc: Tang Yuantian <Yuantian.Tang@freescale.com>
Cc: Shaohui Xie <Shaohui.Xie@freescale.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
The block device uclass does not currently support selecting a particular
hardware partition but this is needed for MMC. Add it so that the blk API
can support MMC properly.
Mark the device name as allocated so that it will be freed correctly when the
device is unbound.
Due to code ordering the block devices are not numbered sequentially. Fix
this.
Add support for CONFIG_BLK to the systemace driver.
Move the systemace_get_dev() function below systemace_read() so that we can
avoid a forward declaration.
Add a function that automatically builds the device name given the parent
and a supplied string. Most callers will want to do this, so putting this
functionality in one place makes more sense.
Allow a devnum parameter of -1 to indicate that the device number should be
alocated automatically. The next highest available device number for that
interface type is used.
This function is implemented by the legacy block functions now. Drop it.
This has nothing of consequence. Remove it and its only inclusion site.
Now that the MMC code accesses devices by number, we can implement this same
interface for driver model, allowing MMC to support using driver model for
block devices.
Add the required functions to the uclass.
Add a legacy block interface for sandbox host.
Add a legacy block interface for systemace.
There is quite a bit of duplicated common code related to block devices
in the IDE and SCSI implementations.
Create some helper functions that can be used to reduce the duplication.
These rely on a linker list of interface-type drivers
This option currently enables both the command and the SCSI functionality.
Rename the existing option to CONFIG_SCSI since most of the code relates
to the feature.
Add some functions needed by the SATA code. This allows it to be compiled
for sandbox, thus increasing build coverage.
Add some functions needed by the SCSI code. This allows it to be compiled
This started as 'ahci' and was renamed to 'disk' during code review. But it
seems that this is too generic. Now that we have a 'blk' uclass, we can use
that as the generic piece, and revert to ahci for this.
Bring this support back so that sandbox can be compiled with CONFIG_BLK. This
allows sandbox to have greater build coverage during the block-device
transition. This can be removed again later.
This reverts commit 33cf727b1634dbd9cd68a6ebc444a88f053822d7.
Ensure data the following sata command used is flushed out of dcache
and written to physical memory or timeout error may happen.
Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com>
