path: root/drivers/block
2008-08-13drivers/block: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-07-14Code cleanup: fix old style assignment ambiguities like "=-" etc.Wolfgang Denk
2008-07-10silence misc printf formatting compiler warningsKim Phillips
2008-06-30sata: wait for device updating signature to hostDave Liu
The driver need wait for the device updating signature to host. If we don't wait for it, the driver can not detect the device(disk) when the system powers up. Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-06-29Add sata sil3114 supportTor Krill
Signed-off-by: Tor Krill <tor@excito.com>
2008-04-13ata: update the libata.h from ata.h of linux kernelDave Liu
Current libata.h of u-boot is out of sync from linux kernel, this patch make it be consistent with linux kernel. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Tor Krill <tor@excito.com>
2008-04-13drivers: code clean upDave Liu
2008-04-13drivers: clean up the ata_piix.hDave Liu
2008-03-27Coding style cleanup, update CHANGELOGWolfgang Denk
2008-03-26drivers: add the support for Freescale SATA controllerDave Liu
Add the Freescale on-chip SATA controller driver to u-boot, The SATA controller is used on the 837x and 8315 targets, The driver can be used to load kernel, fs and dtb. The features list: - 1.5/3 Gbps link speed - LBA48, LBA28 support - DMA and FPDMA support - Two ports support Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-03-26ata: add the libata supportDave Liu
add simple libata support in u-boot Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-03-26ata: make the ata_piix driver using new SATA frameworkDave Liu
original ata_piix driver is using IDE framework, not real SATA framework. For now, the ata_piix driver is only used by x86 sc520_cdp board. This patch makes the ata_piix driver use the new SATA framework, so - remove the duplicated command stuff - remove the CONFIG_CMD_IDE define in the sc520_cdp.h - add the CONFIG_CMD_SATA define to sc520_cdp.h Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-03-26ata: merge the header of ata_piix driverDave Liu
move the sata.h from include/ to drivers/block/ata_piix.h Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-03-26ata: merge the ata_piix driverDave Liu
move the cmd_sata.c from common/ to drivers/ata_piix.c, the cmd_sata.c have some part of ata_piix controller drivers. consolidate the driver to have better framework. Signed-off-by: Dave Liu <daveliu@freescale.com>
2007-11-25drivers/block : move block drivers to drivers/blockJean-Christophe PLAGNIOL-VILLARD
