path: root/drivers/block/pata_bfin.c
2016-03-14dm: part: Rename some partition functionsSimon Glass
Rename three partition functions so that they start with part_. This makes it clear what they relate to. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2014-11-24sata: implement reset_sata for dwc_ahsataNikita Kiryanov
Add reset_sata() to the sata driver interface and implement it for dwc_ahsata. This function cleans up after sata_init(), and therefore accepts a device number like sata_init() does. A dummy implementation is provided for the rest of the drivers. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de>
2014-02-20blackfin: Add <asm/clock.h> to numerous driversTom Rini
With d6a320d we moved some clock externs out of blackfin_local.h and into clock.h but now need to include <asm/clock.h> in more drivers to avoid warnings. Cc: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-05-01part/dev_desc: Add log2 of blocksize to block_dev_desc data structEgbert Eich
log2 of the device block size serves as the shift value used to calculate the block number to read in file systems when implementing avaiable block sizes. It is needed quite often in file systems thus it is pre-calculated and stored in the block device descriptor. Signed-off-by: Egbert Eich <eich@suse.com>
2012-10-15sata.h: Make all sata/ata drivers include <sata.h>Pavel Herrmann
- block_dev_desc_t says that block_(read|write) take lbaint_t for blkcnt not ulong. - We also move the extern of sata_dev_desc into <sata.h> - Remove now duplicate declarations from driver-specific headers. Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-10-15pata_bfin: Make sata_{read,write}() comply with <part.h>Tom Rini
These functions take lbaint_t for blkcnt. Signed-off-by: Tom Rini <trini@ti.com>
2012-02-12Blackfin: pata_bfin: fix printf warningMike Frysinger
pata_bfin.c: In function 'bfin_ata_identify': pata_bfin.c:887:2: warning: format '%x' expects type 'unsigned int', but argument 2 has type 'lbaint_t' Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: pata_bfin: convert to portmux frameworkMike Frysinger
Rather than bang MMRs directly, use the new portmux framework to handle the details. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-02-02Blackfin: add driver for on-chip ATAPI controllerSonic Zhang
This is a port of the Linux Blackfin on-chip ATAPI driver to U-Boot. Signed-off-by: Sonic Zhang <Sonic.Zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
