path: root/drivers/block/blk-uclass.c
2018-12-12blk: Rework guard around part_init callTom Rini
The function part_init() will only be built when we have both CONFIG_PARTITIONS and CONFIG_HAVE_BLOCK_DEVICE set. Protect the call to this function with both of these tests now. Cc: Simon Glass <sjg@chromium.org> Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: York Sun <york.sun@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Stefan Roese <sr@denx.de> Cc: Marek BehĂșn <marek.behun@nic.cz> Cc: Vanessa Maegima <vanessa.maegima@nxp.com> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Adam Ford <aford173@gmail.com> Cc: Jagan Teki <jagan@amarulasolutions.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14blk: Introduce IF_TYPE_VIRTIOTuomas Tynkkynen
This adds a new block interface type for VirtIO block devices. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14blk: Make blk_next_free_devnum() publicBin Meng
blk_next_free_devnum() can be helpful in some cases. Make it a public API. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14blk: Drop blk_prepare_device()Bin Meng
With the post_probe() changes, this API is no longer needed. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14blk: Call part_init() in the post_probe() methodBin Meng
part_init() is currently called in every DM BLK driver, either in its bind() or probe() method. However we can use the BLK uclass driver's post_probe() method to do it automatically. Update all DM BLK drivers to adopt this change. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-28block: Add a function to find block device descriptorTien Fong Chee
Add a function to find the block device descriptor of the parent device. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> [trini: Move function declaration to avoid warning] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-13SystemACE: RemoveTom Rini
This driver is no longer used on any supported platform in U-Boot and there is no interest in maintaining it further from people that have used it historically. Cc: Simon Glass <sjg@chromium.org> Cc: Michal Simek <michal.simek@xilinx.com> c: Alexey Brodkin <alexey.brodkin@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2018-01-22efi_driver: EFI block driverHeinrich Schuchardt
This patch provides * a uclass for EFI drivers * a EFI driver for block devices For each EFI driver the uclass * creates a handle * adds the driver binding protocol The uclass provides the bind, start, and stop entry points for the driver binding protocol. In bind() and stop() it checks if the controller implements the protocol supported by the EFI driver. In the start() function it calls the bind() function of the EFI driver. In the stop() function it destroys the child controllers. The EFI block driver binds to controllers implementing the block io protocol. When the bind function of the EFI block driver is called it creates a new U-Boot block device. It installs child handles for all partitions and installs the simple file protocol on these. The read and write functions of the EFI block driver delegate calls to the controller that it is bound to. A usage example is as following: U-Boot loads the iPXE snp.efi executable. iPXE connects an iSCSI drive and exposes a handle with the block IO protocol. It calls ConnectController. Now the EFI block driver installs the partitions with the simple file protocol. iPXE uses the simple file protocol to load Grub or the Linux Kernel. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> [agraf: add comment on calloc len] Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-12dm: blk: Use uclass_find_first/next_device() in blk_first/next_device()Stefan Roese
This patch changes the calls to uclass_first/next_device() in blk_first/ next_device() to use uclass_find_first/next_device() instead. These functions don't prepare the devices, which is correct in this case. With this patch applied, the "usb storage" command now works again as expected: => usb storage Device 0: Vendor: SanDisk Rev: 1.00 Prod: Ultra Type: Removable Hard Disk Capacity: 58656.0 MB = 57.2 GB (120127488 x 512) Without this patch, it used to generate this buggy output: => usb storage Card did not respond to voltage select! mmc_init: -95, time 26 No storage devices, perhaps not 'usb start'ed..? Signed-off-by: Stefan Roese <sr@denx.de> Suggested-by: Simon Glass <sjg@chromium.org> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-15blk: Remove various places that do flush cache after readBin Meng
All these places seem to inherit the codes from the MMC driver where a FIXME was put in the comment. However the correct operation after read should be cache invalidate, not flush. The underlying drivers should be responsible for the cache operation. Remove these codes completely. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: York Sun <york.sun@nxp.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: York Sun <york.sun@nxp.com>
2017-09-11blk: dm: make blk_create_device() take a number of block instead of a sizeJean-Jacques Hiblot
There is an overflow problem when taking the size instead of the number of blocks in blk_create_device(). This results in a wrong device size: the device apparent size is its real size modulo 4GB. Using the number of blocks instead of the device size fixes the problem and is more coherent with the internals of the block layer. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-10block: ide: Fix block read/write with driver modelBin Meng
This converts the IDE driver to driver model so that block read and write are fully functional. Fixes: b7c6baef ("x86: Convert MMC to driver model") Reported-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-08-17dm: blk: Update return value in blk_create_devicef()Simon Glass
This returns 'ret' but the value is always zero. Update it to simply return 0, for clarity. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-17dm: blk: Add a function to find an interface-type nameSimon Glass
Add a function to find the name of an interface type (e.g. "sata", "scsi") from the interface type enum. This is useful for generic code (not specific to SATA or SCSI, for example) that wants to display the type of interface it is dealing with. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-13dm: blk: part: Add UCLASS_NVME and IF_TYPE_NVMEZhikang Zhang
This adds a new uclass id and block interface type for NVMe. Signed-off-by: Zhikang Zhang <zhikang.zhang@nxp.com> Signed-off-by: Wenbin Song <wenbin.song@nxp.com> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jon Nettleton <jon@solid-run.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-09dm: blk: Add a way to obtain a block device from its parentSimon Glass
Many devices support a child block device (e.g. MMC, USB). Add a convenient way to get this device given the parent device. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-01dm: blk: Improve block device claimingSimon Glass
The intention with block devices is that the device number (devnum field in its descriptor) matches the alias of its parent device. For example, with: aliases { mmc0 = "/sdhci@700b0600"; mmc1 = "/sdhci@700b0400"; } we expect that the block devices for mmc0 and mmc1 would have device numbers of 0 and 1 respectively. Unfortunately this does not currently always happen. If there is another MMC device earlier in the driver model data structures its block device will be created first. It will therefore get device number 0 and mmc0 will therefore miss out. In this case the MMC device will have sequence number 0 but its block device will not. To avoid this, allow a device to request a device number and bump any existing device number that is using it. This all happens during the binding phase so it is safe to change these numbers around. This allows device numbers to match the aliases in all circumstances. Add a test to verify the behaviour. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: blk: Add a function to find the next block device numberSimon Glass
At present this code is inline. Move it into a function to allow it to be used elsewhere. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: blk: Allow finding block devices without probingSimon Glass
Sometimes it is useful to be able to find a block device without also probing it. Add a function for this as well as the associated test. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-04dm: core: Add flags parameter to device_remove()Stefan Roese
This patch adds the flags parameter to device_remove() and changes all calls to this function to provide the default value of DM_REMOVE_NORMAL for "normal" device removal. This is in preparation for the driver specific pre-OS (e.g. DMA cancelling) remove support. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2016-12-20dm: Add support for scsi/sata based devicesMichal Simek
All sata based drivers are bind and corresponding block device is created. Based on this find_scsi_device() is able to get back block device based on scsi_curr_dev pointer. intr_scsi() is commented now but it can be replaced by calling find_scsi_device() and scsi_scan(). scsi_dev_desc[] is commented out but common/scsi.c heavily depends on it. That's why CONFIG_SYS_SCSI_MAX_DEVICE is hardcoded to 1 and symbol is reassigned to a block description allocated by uclass. There is only one block description by device now but it doesn't need to be correct when more devices are present. scsi_bind() ensures corresponding block device creation. uclass post_probe (scsi_post_probe()) is doing low level init. SCSI/SATA DM based drivers requires to have 64bit base address as the first entry in platform data structure to setup mmio_base. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-09Revert "Merge branch 'master' of git://www.denx.de/git/u-boot-microblaze"Tom Rini
This reverts commit 3edc0c252257e4afed163a3a74aba24a5509b198, reversing changes made to bb135a0180c31fbd7456021fb9700b49bba7f533.
2016-12-08dm: Add support for scsi/sata based devicesMichal Simek
All sata based drivers are bind and corresponding block device is created. Based on this find_scsi_device() is able to get back block device based on scsi_curr_dev pointer. intr_scsi() is commented now but it can be replaced by calling find_scsi_device() and scsi_scan(). scsi_dev_desc[] is commented out but common/scsi.c heavily depends on it. That's why CONFIG_SYS_SCSI_MAX_DEVICE is hardcoded to 1 and symbol is reassigned to a block description allocated by uclass. There is only one block description by device now but it doesn't need to be correct when more devices are present. scsi_bind() ensures corresponding block device creation. uclass post_probe (scsi_post_probe()) is doing low level init. SCSI/SATA DM based drivers requires to have 64bit base address as the first entry in platform data structure to setup mmio_base. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org> Series-changes: 2 - Use CONFIG_DM_SCSI instead of mix of DM_SCSI and DM_SATA Ceva sata has never used sata commands that's why keep it in SCSI part only. - Separate scsi_scan() for DM_SCSI and do not change cmd/scsi.c - Extend platdata Series-changes: 3 - Fix scsi_scan return path - Fix header location uclass-internal.h - Add scsi_max_devs under !DM_SCSI - Add new header device-internal because of device_probe() - Redesign block device creation algorithm - Use device_unbind in error path - Create block device with id and lun numbers (lun was there in v2) - Cleanup dev_num initialization in block device description with fixing parameters in blk_create_devicef - Create new Kconfig menu for SATA/SCSI drivers - Extend description for DM_SCSI - Fix Kconfig dependencies - Fix kernel doc format in scsi_platdata - Fix ahci_init_one - vendor variable Series-changes: 4 - Fix Kconfig entry - Remove SPL ifdef around SCSI uclass - Clean ahci_print_info() ifdef logic
2016-12-02dm: blk: Fix get_desc to return block device descriptorMichal Simek
Current get_desc() implementation is not able to succesfully finish and return pointer to block device descriptor. Also function always return non zero value even device is found. The patch fills block device descriptor and return 0 if device is found. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: blk: Add functions to select a hardware partitionSimon Glass
The block device uclass does not currently support selecting a particular hardware partition but this is needed for MMC. Add it so that the blk API can support MMC properly. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: blk: Free the block device name when unboundSimon Glass
Mark the device name as allocated so that it will be freed correctly when the device is unbound. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: blk: Fix allocation of block-device numberingSimon Glass
Due to code ordering the block devices are not numbered sequentially. Fix this. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: blk: Add a easier way to create a named block deviceSimon Glass
Add a function that automatically builds the device name given the parent and a supplied string. Most callers will want to do this, so putting this functionality in one place makes more sense. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: blk: Allow blk_create_device() to allocate the device numberSimon Glass
Allow a devnum parameter of -1 to indicate that the device number should be alocated automatically. The next highest available device number for that interface type is used. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: mmc: Add an implementation of the 'devnum' functionsSimon Glass
Now that the MMC code accesses devices by number, we can implement this same interface for driver model, allowing MMC to support using driver model for block devices. Add the required functions to the uclass. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-04-01drivers: block: add block device cacheEric Nelson
Add a block device cache to speed up repeated reads of block devices by various filesystems. This small amount of cache can dramatically speed up filesystem operations by skipping repeated reads of common areas of a block device (typically directory structures). This has shown to have some benefit on FAT filesystem operations of loading a kernel and RAM disk, but more dramatic benefits on ext4 filesystems when the kernel and/or RAM disk are spread across multiple extent header structures as described in commit fc0fc50. The cache is implemented through a minimal list (block_cache) maintained in most-recently-used order and count of the current number of entries (cache_count). It uses a maximum block count setting to prevent copies of large block reads and an upper bound on the number of cached areas. The maximum number of entries in the cache defaults to 32 and the maximum number of blocks per cache entry has a default of 2, which has shown to produce the best results on testing of ext4 and FAT filesystems. The 'blkcache' command (enabled through CONFIG_CMD_BLOCK_CACHE) allows changing these values and can be used to tune for a particular filesystem layout. Signed-off-by: Eric Nelson <eric@nelint.com>
2016-03-14dm: blk: Add a block-device uclassSimon Glass
Add a uclass for block devices. These provide block-oriented data access, supporting reading, writing and erasing of whole blocks. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
