path: root/drivers/block/ata_piix.h
2012-10-15sata.h: Make all sata/ata drivers include <sata.h>Pavel Herrmann
- block_dev_desc_t says that block_(read|write) take lbaint_t for blkcnt not ulong. - We also move the extern of sata_dev_desc into <sata.h> - Remove now duplicate declarations from driver-specific headers. Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-10-15ata_piix: sata_write must take a const void argument.Tom Rini
2012-10-15ata_piix: Fix checkpatch issuesTom Rini
While in here also: - Switch to debug from custom PRINTF for debugging. - Use mdelay rather than custom msleep. Signed-off-by: Tom Rini <trini@ti.com>
2009-09-04Misc SATA fixupsGraeme Russ
Cast first parameter to sata_cpy() In /drivers/block/ata_piix.h, ata_id_has_lba48(), ata_id_has_lba(), ata_id_has_dma(), ata_id_u32(), ata_id_u64() are all defined in include/libata.h which is included in ata.h which is included by all files which include ata_piix.h (only ata_piix.c) so these definitions are supurflous to (and conlict with) this in libata.h. Interestingly, my compiler complains about ata_id_u64 already being defined, but not ata_id_u32 ata_dump_id() is defined in include/libata.h and should not be static (maybe should even use ata_dump_id() in libata.c Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2008-04-13drivers: clean up the ata_piix.hDave Liu
Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-03-26ata: make the ata_piix driver using new SATA frameworkDave Liu
original ata_piix driver is using IDE framework, not real SATA framework. For now, the ata_piix driver is only used by x86 sc520_cdp board. This patch makes the ata_piix driver use the new SATA framework, so - remove the duplicated command stuff - remove the CONFIG_CMD_IDE define in the sc520_cdp.h - add the CONFIG_CMD_SATA define to sc520_cdp.h Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-03-26ata: merge the header of ata_piix driverDave Liu
move the sata.h from include/ to drivers/block/ata_piix.h Signed-off-by: Dave Liu <daveliu@freescale.com>
