Initial Ceva Sata init code.
Add a block device cache to speed up repeated reads of block devices by
various filesystems.
This small amount of cache can dramatically speed up filesystem
operations by skipping repeated reads of common areas of a block
device (typically directory structures).
This has shown to have some benefit on FAT filesystem operations of
loading a kernel and RAM disk, but more dramatic benefits on ext4
filesystems when the kernel and/or RAM disk are spread across
multiple extent header structures as described in commit fc0fc50.
The cache is implemented through a minimal list (block_cache) maintained
in most-recently-used order and count of the current number of entries
(cache_count). It uses a maximum block count setting to prevent copies
of large block reads and an upper bound on the number of cached areas.
The maximum number of entries in the cache defaults to 32 and the maximum
number of blocks per cache entry has a default of 2, which has shown to
produce the best results on testing of ext4 and FAT filesystems.
The 'blkcache' command (enabled through CONFIG_CMD_BLOCK_CACHE) allows
changing these values and can be used to tune for a particular filesystem
layout.
Signed-off-by: Eric Nelson <eric@nelint.com>
Add a uclass for block devices. These provide block-oriented data access,
supporting reading, writing and erasing of whole blocks.
Add a uclass ID for a disk controller. This can be used by AHCI/SATA or
other controller types. There are no operations and no interface so far,
but it is possible to probe a SATA device.
This patch adds a new SATA driver for the Marvell Kirkwood and Armada
370 / XP SoC's.
This driver supports the SATA controller of some Mavell SoC's.
Here a (most likely incomplete) list of the supported SoC's:
- Kirkwood
- Armada 370
- Armada XP
This driver implementation is an alternative to the already available
driver via the "ide" commands interface (drivers/block/mvsata_ide.c).
But this driver only supports PIO mode and as this new driver also
supports transfer via DMA, its much faster.
Please note, that the newer SoC's (e.g. Armada 38x) are not supported
by this driver. As they have an AHCI compatible SATA controller
integrated.
The original version of this driver was sent by Tor Krill to the U-Boot
list a few years ago. Here the link:
http://lists.denx.de/pipermail/u-boot/2010-June/073147.html
Changes by Stefan:
- Coding-style cleanup
- Support for Armada XP added
- MBUS window setup added
- D-cache flush and invalidation added - works with dcache enabled on
Armada XP
- Removed mdelay() from ata_wait_register() and add timer based timeout
detection to speed up the transfer
Signed-off-by: Tor Krill <tor@excito.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
This driver was originally added to support the native IDE mode for
Intel chipset, however it has some bugs like not supporting ATAPI
devices, endianness issue, or even broken build when CONFIG_LAB48.
Given no board is using this driver as of today, rather than fixing
all these issues we just remove it from the source tree.
Provide a way to use any host file or device as a block device in U-Boot.
This can be used to provide filesystem access within U-Boot to an ext2
image file on the host, for example.
The support is plumbed into the filesystem and partition interfaces.
We don't want to print a message in the driver every time we find a missing
device. Pass the information back to the caller where a message can be printed
if desired.
Signed-off-by: Henrik Nordström <henrik@henriknordstrom.net>
- Removed change to part.c get_device_and_partition()
[trini: Fixup common/cmd_io.c]
This driver is unused and obsolete.
Cc: unsik Kim <donari75@gmail.com>
This driver is part of Freescale's LTIB for
MX5 / MX6.
Signed-off-by: Terry Lv <r65388@freescale.com>
CC: Fabio Estevam <fabio.estevam@freescale.com>
CC: Dirk Behme <dirk.behme@de.bosch.com>
Add the Silicon Image series PCI Express to
Serial ATA controller support, including Sil3132,
Sil3131 and Sil3124.
The SATA controller can be used to load kernel.
The features list:
- Supports 1-lane 2.5 Gbit/s PCI Express
- Supports one/two/four independent Serial ATA channels
- Supports Serial ATA Generation 2 transfer rate of 3.0 Gbit/s
- Supports LBA28 and LBA48
Signed-off-by: Tang Yuantian <b29983@freescale.com>
Signed-off-by: Aaron Williams <Aaron.Williams@cavium.com>
Tested-by: Lan Chunhe <b25806@freescale.com>
Faraday's ftide020_s is an IDE-AHB controller for SoC design.
This patch add the u-boot driver (PIO) of ftide020 ATA (IDE) driver.
IDE commands include read, info, and other functions has been implemented.
Because this IDE controller support AHB interface only which is differ
from other most IDE controller supports PCI interface. Some registers
access is required during CMD/DATA I/O. Hence a configuration
"CONFIG_IDE_AHB" is required to be defined according to the feature in
cmd_ide.c.
Signed-off-by: Macpaul Lin <macpaul@andestech.com>
Acked-by: Wolfgang Denk <wd@denx.de>
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
This driver only provides initialization code; actual driving
is done by cmd_ide.c using the ATA compatibility mode of the
Marvell SATAHC controller.
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
This patch adds a SATA harddisk driver for the canyonlands.
This patch is kernel driver's porting.
This patch corresponded to not cmd_scsi but cmd_sata.
This patch divided an unused member with ifndef __U_BOOT__ in the structure.
[environment variable, boot script]
setenv bootargs root=/dev/sda7 rw
setenv bootargs ${bootargs} console=ttyS0,115200
ext2load sata 0:2 0x400000 /canyonlands/uImage
ext2load sata 0:2 0x800000 /canyonlands/canyonlands.dtb
fdt addr 0x800000 0x4000
bootm 0x400000 - 0x800000
If you drive SATA-2 disk on Canyonlands, you must change parts from
PI2PCIE212 to PI2PCIE2212 on U25. We confirmed to boot by using
following disks:
1.Vendor: Fujitsu Type: MHW2040BS
2.Vendor: Fujitsu Type: MHW2060BK
3.Vendor: HAGIWARA SYS-COM:HFD25S-032GT
4.Vendor: WesternDigital Type: WD3200BJKT (CONFIG_LBA48 required)
5.Vendor: WesternDigital Type: WD3200BEVT (CONFIG_LBA48 required)
6.Vendor: Hitachi Type: HTS543232L9A300 (CONFIG_LBA48 required)
7.Vendor: Seagate Type: ST31000333AS (CONFIG_LBA48 required)
8.Vendor: Transcend Type: TS32GSSD25S-M
9.Vendor: MTRON Type: MSD-SATA1525-016
Signed-off-by: Kazuaki Ichinohe <kazuichi at fsi.co.jp>
Mflash is fusion memory device mainly targeted consumer eletronic and
mobile phone.
Internally, it have nand flash and other hardware logics and supports
some different operation (ATA, IO, XIP) modes.
IO mode is custom mode for the host that doesn't have IDE interface.
(Many mobile targeted SoC doesn't have IDE bus)
This driver support mflash IO mode.
Followings are brief descriptions about IO mode.
1. IO mode based on ATA protocol and uses some custom command. (read
confirm, write confirm)
2. IO mode uses SRAM bus interface.
Signed-off-by: unsik Kim <donari75@gmail.com>
This is a port of the Linux Blackfin on-chip ATAPI driver to U-Boot.
Signed-off-by: Sonic Zhang <Sonic.Zhang@analog.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Add the Freescale on-chip SATA controller driver to u-boot,
The SATA controller is used on the 837x and 8315 targets,
The driver can be used to load kernel, fs and dtb.
The features list:
- 1.5/3 Gbps link speed
- LBA48, LBA28 support
- DMA and FPDMA support
- Two ports support
Signed-off-by: Dave Liu <daveliu@freescale.com>
add simple libata support in u-boot
