When dealing with filesystems that come from block devices we can get a
noticeable performance gain in some use cases from having the block
cache enabled. The code paths are valid in other cases when we have BLK
set and may provide wins in raw reads in some use cases, so have this be
default when BLK is enabled.
This driver is no longer used on any supported platform in U-Boot and
there is no interest in maintaining it further from people that have
used it historically.
Cc: Michal Simek <michal.simek@xilinx.com>
c: Alexey Brodkin <alexey.brodkin@gmail.com>
Acked-by: Michal Simek <michal.simek@xilinx.com>
config_fallbacks.h has some logic that sets HAVE_BLOCK_DEVICE
based on a list of enabled options. Moving HAVE_BLOCK_DEVICE to
Kconfig allows us to drastically shrink the logic in
config_fallbacks.h
[trini: Rename HAVE_BLOCK_DEVICE to CONFIG_BLOCK_DEVICE]
Migrate the base and sub-options to Kconfig. Note that we only enable
this in the base sandbox config now.
Cc: Alexey Brodkin <alexey.brodkin@gmail.com>
Is this driver still used anywhere? It's fishy that it's only enabled
in sandbox anymore.
At present if U-Boot proper uses driver model for MMC, then SPL has to
also. While this is desirable, it places a significant barrier to moving
to driver model in some cases. For example, with a space-constrained SPL
it may be necessary to enable CONFIG_SPL_OF_PLATDATA which involves
adjusting some drivers.
Add new SPL versions of the options for DM_MMC, DM_MMC_OPS and BLK. By
default these follow their non-SPL versions, but this can be changed by
boards which need it.
At present we have the SCSI drivers in the drivers/block and common/
directories. It is better to split them out into their own place. Use
drivers/scsi which is what Linux does.
At present we have the SATA and PATA drivers mixed up in the drivers/block
directory. It is better to split them out into their own place. Use
drivers/ata which is what Linux does.
At present CONFIG_CMD_SATA enables the 'sata' command which also brings
in SATA support. Some boards may wish to enable SATA without the command.
Add a separate CONFIG to permit this.
CONFIG_SCSI
At present IDE support is controlled by CONFIG_CMD_IDE. Add a separate
CONFIG_IDE option so that IDE support can be enabled without requiring
the 'ide' command.
Update existing users and move the ide driver into drivers/block since
it should not be in common/.
Implement a sata driver for Synopsys DWC sata device based on
U-boot driver model.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
This patch also includes ARM64 zynqmp changes:
- Remove platform non DM initialization
- Remove hardcoded sata base address
All sata based drivers are bind and corresponding block
device is created. Based on this find_scsi_device() is able
to get back block device based on scsi_curr_dev pointer.
intr_scsi() is commented now but it can be replaced by calling
find_scsi_device() and scsi_scan().
scsi_dev_desc[] is commented out but common/scsi.c heavily depends on
it. That's why CONFIG_SYS_SCSI_MAX_DEVICE is hardcoded to 1 and symbol
is reassigned to a block description allocated by uclass.
There is only one block description by device now but it doesn't need to
be correct when more devices are present.
scsi_bind() ensures corresponding block device creation.
uclass post_probe (scsi_post_probe()) is doing low level init.
SCSI/SATA DM based drivers requires to have 64bit base address as
the first entry in platform data structure to setup mmio_base.
This reverts commit 3edc0c252257e4afed163a3a74aba24a5509b198, reversing
changes made to bb135a0180c31fbd7456021fb9700b49bba7f533.
Series-to: sjg, agraf@suse.de
Series-cc: uboot
Series-version: 4
Series-changes: 2
- make ceva_init_sata static
- Move SATA_CEVA to defconfig
- Initalized max_lun and max_id platdata
Series-changes: 3
- Extend Kconfig help description
- sort dm.h
- Remove SPL undefinition from board file
- Fix Kconfig dependecies
Series-changes: 2
- Use CONFIG_DM_SCSI instead of mix of DM_SCSI and DM_SATA
Ceva sata has never used sata commands that's why keep it in
SCSI part only.
- Separate scsi_scan() for DM_SCSI and do not change cmd/scsi.c
- Extend platdata
Series-changes: 3
- Fix scsi_scan return path
- Fix header location uclass-internal.h
- Add scsi_max_devs under !DM_SCSI
- Add new header device-internal because of device_probe()
- Redesign block device creation algorithm
- Use device_unbind in error path
- Create block device with id and lun numbers (lun was there in v2)
- Cleanup dev_num initialization in block device description
with fixing parameters in blk_create_devicef
- Create new Kconfig menu for SATA/SCSI drivers
- Extend description for DM_SCSI
- Fix Kconfig dependencies
- Fix kernel doc format in scsi_platdata
- Fix ahci_init_one - vendor variable
Series-changes: 4
- Fix Kconfig entry
- Remove SPL ifdef around SCSI uclass
- Clean ahci_print_info() ifdef logic
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is
enabled.
This started as 'ahci' and was renamed to 'disk' during code review. But it
seems that this is too generic. Now that we have a 'blk' uclass, we can use
that as the generic piece, and revert to ahci for this.
Add a block device cache to speed up repeated reads of block devices by
various filesystems.
This small amount of cache can dramatically speed up filesystem
operations by skipping repeated reads of common areas of a block
device (typically directory structures).
This has shown to have some benefit on FAT filesystem operations of
loading a kernel and RAM disk, but more dramatic benefits on ext4
filesystems when the kernel and/or RAM disk are spread across
multiple extent header structures as described in commit fc0fc50.
The cache is implemented through a minimal list (block_cache) maintained
in most-recently-used order and count of the current number of entries
(cache_count). It uses a maximum block count setting to prevent copies
of large block reads and an upper bound on the number of cached areas.
The maximum number of entries in the cache defaults to 32 and the maximum
number of blocks per cache entry has a default of 2, which has shown to
produce the best results on testing of ext4 and FAT filesystems.
The 'blkcache' command (enabled through CONFIG_CMD_BLOCK_CACHE) allows
changing these values and can be used to tune for a particular filesystem
layout.
Signed-off-by: Eric Nelson <eric@nelint.com>
Add a uclass for block devices. These provide block-oriented data access,
supporting reading, writing and erasing of whole blocks.
Add a uclass ID for a disk controller. This can be used by AHCI/SATA or
other controller types. There are no operations and no interface so far,
but it is possible to probe a SATA device.
This would be useful to start moving various config options.
